evtl. habe ich nur den “falschen” Thread genommen, aber ich hänge mom. voll fest.
Was ich in der zwischenzeit auch schon probiert habe, alles fix zu verlöten, und nicht mit den Dupont zu verkabeln.
Auch andere CC1101 habe ich versucht. Leider alles ohne erfolg.
Evtl. Kann mir hier jemand helfen.
THX
edit
hier das log
[15.03.2026 - 18:44:42] D WEB: Received - Element ID: p10_log_refresh_btn = true
[15.03.2026 - 18:44:40] I CFG: config successfully saved to file: /config.json - Version: 2
[15.03.2026 - 18:44:40] D WEB: Received - Element ID: cfg_logger_enable = true
[15.03.2026 - 18:44:38] D WEB: Received - Element ID: p10_log_refresh_btn = true
[15.03.2026 - 18:44:33] D WEB: Received - Element ID: p10_log_refresh_btn = true
[15.03.2026 - 18:44:32] I CFG: config successfully saved to file: /config.json - Version: 2
[15.03.2026 - 18:44:31] D WEB: Received - Element ID: cfg_logger_enable = false
[15.03.2026 - 18:44:25] D WEB: Received - Element ID: p10_log_refresh_btn = true
[15.03.2026 - 18:43:28] D WEB: Received - Element ID: p10_log_refresh_btn = true
[15.03.2026 - 18:43:16] D WEB: Received - Element ID: p10_log_refresh_btn = true
[15.03.2026 - 18:39:59] D WEB: Received - Element ID: p10_log_refresh_btn = true
[15.03.2026 - 18:39:50] D WEB: updateAllElements()
[15.03.2026 - 18:39:50] I WEBUI: web-client connected - IP:192.168.154.***
[15.03.2026 - 18:39:50] D WEBUI: contend not changed: /user.js
[15.03.2026 - 18:39:50] D WEBUI: authentication disabled
[15.03.2026 - 18:39:50] D WEBUI: contend not changed: /lib.js
[15.03.2026 - 18:39:50] D WEBUI: contend not changed: /user.css
[15.03.2026 - 18:39:50] D WEBUI: contend not changed: /lib.css
[15.03.2026 - 18:39:09] D ESU-MRD: Cleared reset state
[15.03.2026 - 18:39:09] D ESU-MRD: Timeout reached, resetting count
[01.01.1970 - 01:00:00] I TELNET: Telnet Server running!
[01.01.1970 - 01:00:00] I JARO: read Device Counter from FLASH: 43
[01.01.1970 - 01:00:00] I JARO: CC1101 Transceiver connected!
[01.01.1970 - 01:00:00] I SETUP: IP address: 192.168.154.***
[01.01.1970 - 01:00:00] I SETUP: WiFi connected
[01.01.1970 - 01:00:00] I SETUP: Connected to AP successfully!
[01.01.1970 - 01:00:00] I JARO-LIB: start CC1101 setup
[01.01.1970 - 01:00:00] I JARO-LIB: Set base serial: 0x00010016
[01.01.1970 - 01:00:00] I JARO: initializing the CC1101 Transceiver
[01.01.1970 - 01:00:00] I SETUP: ESP-FlashChipSize: 4.00 MB
[01.01.1970 - 01:00:00] I SETUP: ESP-CpuFreq: 240
[01.01.1970 - 01:00:00] I SETUP: ESP-ChipRevision: 301
[01.01.1970 - 01:00:00] I SETUP: ESP-ChipModel: ESP32-D0WD-V3
[01.01.1970 - 01:00:00] I SETUP: ESP-ChipSeries: ESP32
[01.01.1970 - 00:00:00] I SETUP: WiFi Mode STA - Trying connect to: ******
[01.01.1970 - 00:00:00] I ESU-WDT: Watchdog timer initialized for Loop Task
[01.01.1970 - 00:00:00] I MSG: LogLevel: ESP_LOG_DEBUG
[01.01.1970 - 00:00:00] I CFG: LittleFS successfully started
