Backup nicht mehr vorhanden?
was bedeutet das hier?
2026-02-17 06:44:23.291 WARNING (SyncWorker_5) [supervisor.addons.validate] Add-on 'MQTT IO' uses deprecated 'codenotary' field in config. This field is no longer used and will be ignored. Please report this to the maintainer.
2026-02-17 06:44:23.296 WARNING (SyncWorker_5) [supervisor.addons.validate] Add-on 'Traccar' uses deprecated 'codenotary' field in config. This field is no longer used and will be ignored. Please report this to the maintainer.
2026-02-17 06:44:23.299 WARNING (SyncWorker_5) [supervisor.addons.validate] Add-on 'InfluxDB' uses deprecated 'codenotary' field in config. This field is no longer used and will be ignored. Please report this to the maintainer.
2026-02-17 06:44:23.310 WARNING (SyncWorker_5) [supervisor.addons.validate] Add-on 'Log Viewer' uses deprecated 'codenotary' field in config. This field is no longer used and will be ignored. Please report this to the maintainer.
2026-02-17 06:44:23.320 WARNING (SyncWorker_5) [supervisor.addons.validate] Add-on 'Glances' uses deprecated 'codenotary' field in config. This field is no longer used and will be ignored. Please report this to the maintainer.
2026-02-17 06:44:23.322 WARNING (SyncWorker_5) [supervisor.addons.validate] Add-on 'Nginx Proxy Manager' uses deprecated 'codenotary' field in config. This field is no longer used and will be ignored. Please report this to the maintainer.
2026-02-17 06:44:23.326 WARNING (SyncWorker_5) [supervisor.addons.validate] Add-on 'Folding@home' uses deprecated 'codenotary' field in config. This field is no longer used and will be ignored. Please report this to the maintainer.
2026-02-17 06:44:23.329 WARNING (SyncWorker_5) [supervisor.addons.validate] Add-on 'Overseerr' uses deprecated 'codenotary' field in config. This field is no longer used and will be ignored. Please report this to the maintainer.
2026-02-17 06:44:23.343 WARNING (SyncWorker_5) [supervisor.addons.validate] Add-on 'Grocy' uses deprecated 'codenotary' field in config. This field is no longer used and will be ignored. Please report this to the maintainer.
