Hallo Zusammen,
Ich hoffe die Community kann mir weiterhelfen. Ich habe mir einen Sonoff MG24 Zigbee Funkstick organisiert. Damit rüste ich meinen Home Assistant Yellow aus, um auf Zigbee2MQTT zu wechseln. Ich hatte bereits Probleme den Stick mit dem Sonoff Firmware Flashe (unter Home Assistant) sauber zu erkennen. daher habe ich die neuste Firmware am PC geflasht - ohne Probleme.
Nun erscheint beim Start von Zigbee2MQTT folgeder Fehler im Log:
[12:52:47] INFO: Preparing to start...
[12:52:47] INFO: Socat not enabled
[12:52:48] INFO: Starting Zigbee2MQTT...Starting Zigbee2MQTT without watchdog.
[2026-08-25 12:52:51] info: z2m: Logging to console, file (filename: log.log)
[2026-08-25 12:52:51] info: z2m: Starting Zigbee2MQTT version 2.13.0 (commit #unknown)
[2026-08-25 12:52:51] info: z2m: Starting zigbee-herdsman (10.8.0)
[2026-08-25 12:52:52] info: zh:adapter:discovery: Matched adapter=ember path=/dev/ttyUSB0, score=4
[2026-08-25 12:52:52] info: zh:ember: Using default stack config.
[2026-08-25 12:52:52] info: zh:ember: ======== Ember Adapter Starting ========
[2026-08-25 12:52:52] info: zh:ember:ezsp: ======== EZSP starting ========
[2026-08-25 12:52:52] info: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2026-08-25 12:52:52] info: zh:ember:uart:ash: RTS/CTS config is off, enabling software flow control.
[2026-08-25 12:52:52] info: zh:ember:uart:ash: Serial port opened
[2026-08-25 12:52:52] info: zh:ember:uart:ash: ======== ASH starting ========
[2026-08-25 12:52:57] info: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2026-08-25 12:52:57] info: zh:ember:uart:ash: ======== ASH starting ========
[2026-08-25 12:53:02] info: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2026-08-25 12:53:02] info: zh:ember:uart:ash: ======== ASH starting ========
[2026-08-25 12:53:07] info: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2026-08-25 12:53:07] info: zh:ember:uart:ash: ======== ASH starting ========
[2026-08-25 12:53:12] info: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2026-08-25 12:53:12] info: zh:ember:uart:ash: ======== ASH starting ========
[2026-08-25 12:53:17] error: z2m: Error while starting zigbee-herdsman
[2026-08-25 12:53:17] error: z2m: Failed to start zigbee-herdsman
[2026-08-25 12:53:17] error: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions
[2026-08-25 12:53:17] error: z2m: Exiting...
[2026-08-25 12:53:17] error: z2m: Error: Failed to start EZSP layer with status=HOST_FATAL_ERROR.
at EmberAdapter.initEzsp (/app/node_modules/.pnpm/zigbee-herdsman@10.8.0/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:666:19)
at async EmberAdapter.start (/app/node_modules/.pnpm/zigbee-herdsman@10.8.0/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:1544:24)
at async Controller.start (/app/node_modules/.pnpm/zigbee-herdsman@10.8.0/node_modules/zigbee-herdsman/src/controller/controller.ts:146:29)
at async Zigbee.start (/app/lib/zigbee.ts:70:27)
at async Controller.start (/app/lib/controller.ts:117:29)
at async start (/app/index.js:156:5)
Ich bekomme den Stick einfach nciht zum laufen. Es steht noch die Vermutung im Raum, dass der Serial Port irgendwie nicht mitspielt, da fehlt mir aber ehrlicherweise das Wissen um das auszuschließen.
ZHA und Bluetooth sind deaktiviert, den Stick habe ich mit und ohne USB Verlängerung getestet.
