Könnt ihr mir helfen, was ist verkehrt. Wie verhext.
Konfiguration
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: "-d -d"
log: false
serial
port: /dev/ttyUSB0
Protokoll:
[2024-11-04 17:04:52] info: z2m: Logging to console, file (filename: log.log)
[2024-11-04 17:04:52] info: z2m: Starting Zigbee2MQTT version 1.41.0 (commit #unknown)
[2024-11-04 17:04:52] info: z2m: Starting zigbee-herdsman (2.1.7)
[2024-11-04 17:04:53] info: zh:zstack:znp: Opening SerialPort with {"path":"/dev/ttyUSB0","baudRate":115200,"rtscts":false,"autoOpen":false}
[2024-11-04 17:04:53] info: zh:zstack:znp: Serialport opened
[2024-11-04 17:04:53] info: zh:zstack:znp: Writing CC2530/CC2531 skip bootloader payload
[2024-11-04 17:04:54] info: zh:zstack:znp: Skip bootloader for CC2652/CC1352
[2024-11-04 17:05:13] error: z2m: Error while starting zigbee-herdsman
[2024-11-04 17:05:13] error: z2m: Failed to start zigbee
[2024-11-04 17:05:13] error: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
[2024-11-04 17:05:13] error: z2m: Exiting...
[2024-11-04 17:05:13] error: z2m: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
at ZStackAdapter.start (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:113:27)
at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:137:29)
at Zigbee.start (/app/lib/zigbee.ts:69:27)
at Controller.start (/app/lib/controller.ts:161:27)
at start (/app/index.js:154:5)
LvS21
4. November 2024 um 16:13
2
Es gibt immer wieder den Tipp, nicht über den “port: /dev/ttyUSB0” zu gehen, sondern das Gerät direkt anzusprechen.
Den Pfad kannst du unter Hardware / Gesamte Hardware finden:
Des weiteren wäre die Info Interessant zu wissen, welchen zigbee Stick zu versuchst einzubinden.
@LvS21
Als Zigbee Stick verwende ich einen SONOFF
Was meinst du denn mit direkt ansprechen?
Wo trage ich was ein?
LvS21
4. November 2024 um 16:22
4
den ganzen Pfad statt ttyUSB0 - also von /dev/ bis -port0
Noch eines - von den Sonoff Stick gibt es zwei Modelle P und E -je nachdem musst du ein anderes Protokoll konfigurieren.
Beim E-Modell wurde auch noch vor kurzem auf ember umgestellt, was aber eine aktuelle Firmware auf dem Stick benötigt.
Such mal hier im Forum, alle diese Infos und auch noch mehr Detailwissen ist in anderen Threads schon enthalten.
z.B. hier
seit meiner Umstellung auf ember beim Sonoff Dongle E kann ich beim Betrieb bisher keine Verbesserung / Verschlechterung feststellen. Das System läuft stabil und gut.
Ein Punkt der mich etwas irritiert ist das Lesen vom Log. Hier erscheinen teilweise nicht die Namen oder Adressen meiner Geräte, sondern Nummern:
[2024-05-25 20:19:48] info: zh:ember:ezsp: Received network/route error ROUTE_ERROR_MANY_TO_ONE_ROUTE_FAILURE for "27367".
[2024-05-25 20:19:53] info: zh:ember:ezsp: Received …
Leider nein
Serial:
port: >-
/dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_5e8ffbadce8bee11894afa018acbdcd8-if00-port0
[17:23:27] INFO: Preparing to start...
[17:23:27] INFO: Socat not enabled
[17:23:27] INFO: Starting Zigbee2MQTT...
[2024-11-04 17:23:29] info: z2m: Logging to console, file (filename: log.log)
[2024-11-04 17:23:29] info: z2m: Starting Zigbee2MQTT version 1.41.0 (commit #unknown)
[2024-11-04 17:23:29] info: z2m: Starting zigbee-herdsman (2.1.7)
[2024-11-04 17:23:30] info: zh:zstack:znp: Opening SerialPort with {"path":"/dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_5e8ffbadce8bee11894afa018acbdcd8-if00-port0","baudRate":115200,"rtscts":false,"autoOpen":false}
[2024-11-04 17:23:30] info: zh:zstack:znp: Serialport opened
[2024-11-04 17:23:30] info: zh:zstack:znp: Writing CC2530/CC2531 skip bootloader payload
[2024-11-04 17:23:31] info: zh:zstack:znp: Skip bootloader for CC2652/CC1352
[2024-11-04 17:23:50] error: z2m: Error while starting zigbee-herdsman
[2024-11-04 17:23:50] error: z2m: Failed to start zigbee
[2024-11-04 17:23:50] error: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
[2024-11-04 17:23:50] error: z2m: Exiting...
[2024-11-04 17:23:50] error: z2m: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
[17:23:56] INFO: Preparing to start...
[17:23:56] INFO: Socat not enabled
[17:23:56] INFO: Starting Zigbee2MQTT...
[2024-11-04 17:23:58] info: z2m: Logging to console, file (filename: log.log)
[2024-11-04 17:23:58] info: z2m: Starting Zigbee2MQTT version 1.41.0 (commit #unknown)
[2024-11-04 17:23:58] info: z2m: Starting zigbee-herdsman (2.1.7)
[2024-11-04 17:23:58] info: zh:zstack:znp: Opening SerialPort with {"path":"/dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_5e8ffbadce8bee11894afa018acbdcd8-if00-port0","baudRate":115200,"rtscts":false,"autoOpen":false}
[2024-11-04 17:23:59] info: zh:zstack:znp: Serialport opened
[2024-11-04 17:23:59] info: zh:zstack:znp: Writing CC2530/CC2531 skip bootloader payload
[2024-11-04 17:24:00] info: zh:zstack:znp: Skip bootloader for CC2652/CC1352
[2024-11-04 17:24:19] error: z2m: Error while starting zigbee-herdsman
[2024-11-04 17:24:19] error: z2m: Failed to start zigbee
[2024-11-04 17:24:19] error: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
[2024-11-04 17:24:19] error: z2m: Exiting...
[2024-11-04 17:24:19] error: z2m: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
[17:24:25] INFO: Preparing to start...
[17:24:25] INFO: Socat not enabled
[17:24:25] INFO: Starting Zigbee2MQTT...
[2024-11-04 17:24:27] info: z2m: Logging to console, file (filename: log.log)
[2024-11-04 17:24:27] info: z2m: Starting Zigbee2MQTT version 1.41.0 (commit #unknown)
[2024-11-04 17:24:27] info: z2m: Starting zigbee-herdsman (2.1.7)
[2024-11-04 17:24:27] info: zh:zstack:znp: Opening SerialPort with {"path":"/dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_5e8ffbadce8bee11894afa018acbdcd8-if00-port0","baudRate":115200,"rtscts":false,"autoOpen":false}
[2024-11-04 17:24:27] info: zh:zstack:znp: Serialport opened
[2024-11-04 17:24:28] info: zh:zstack:znp: Writing CC2530/CC2531 skip bootloader payload
[2024-11-04 17:24:29] info: zh:zstack:znp: Skip bootloader for CC2652/CC1352
[2024-11-04 17:24:47] error: z2m: Error while starting zigbee-herdsman
[2024-11-04 17:24:47] error: z2m: Failed to start zigbee
[2024-11-04 17:24:47] error: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
[2024-11-04 17:24:47] error: z2m: Exiting...
[2024-11-04 17:24:48] error: z2m: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
[17:24:54] INFO: Preparing to start...
[17:24:54] INFO: Socat not enabled
[17:24:54] INFO: Starting Zigbee2MQTT...
[2024-11-04 17:24:56] info: z2m: Logging to console, file (filename: log.log)
[2024-11-04 17:24:56] info: z2m: Starting Zigbee2MQTT version 1.41.0 (commit #unknown)
[2024-11-04 17:24:56] info: z2m: Starting zigbee-herdsman (2.1.7)
[2024-11-04 17:24:56] info: zh:zstack:znp: Opening SerialPort with {"path":"/dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_5e8ffbadce8bee11894afa018acbdcd8-if00-port0","baudRate":115200,"rtscts":false,"autoOpen":false}
[2024-11-04 17:24:56] info: zh:zstack:znp: Serialport opened
[2024-11-04 17:24:57] info: zh:zstack:znp: Writing CC2530/CC2531 skip bootloader payload
[2024-11-04 17:24:58] info: zh:zstack:znp: Skip bootloader for CC2652/CC1352
[2024-11-04 17:25:16] error: z2m: Error while starting zigbee-herdsman
[2024-11-04 17:25:17] error: z2m: Failed to start zigbee
[2024-11-04 17:25:17] error: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
[2024-11-04 17:25:17] error: z2m: Exiting...
[2024-11-04 17:25:17] error: z2m: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
[17:25:23] INFO: Preparing to start...
[17:25:23] INFO: Socat not enabled
[17:25:23] INFO: Starting Zigbee2MQTT...
[2024-11-04 17:25:25] info: z2m: Logging to console, file (filename: log.log)
[2024-11-04 17:25:25] info: z2m: Starting Zigbee2MQTT version 1.41.0 (commit #unknown)
[2024-11-04 17:25:25] info: z2m: Starting zigbee-herdsman (2.1.7)
[2024-11-04 17:25:25] info: zh:zstack:znp: Opening SerialPort with {"path":"/dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_5e8ffbadce8bee11894afa018acbdcd8-if00-port0","baudRate":115200,"rtscts":false,"autoOpen":false}
[2024-11-04 17:25:25] info: zh:zstack:znp: Serialport opened
[2024-11-04 17:25:26] info: zh:zstack:znp: Writing CC2530/CC2531 skip bootloader payload
[2024-11-04 17:25:27] info: zh:zstack:znp: Skip bootloader for CC2652/CC1352
LvS21
4. November 2024 um 16:27
6
Dann würde ich jetzt einen Blick auf das zu verwundene Protokoll richten und ggf. ein Firmwareupdate des Sticks machen.
Edit: Noch eines - oftmals klappt die Konfiguration über die GUI nicht richtig und das Ganze funktioniert erst, wenn du die configuration.yaml des zigbee2mqtt manuell veränderst.
Das ist übrigens die Info, welche Copilot mir zu folgender Frage “Welchen Adapter des sonoff muss ich bei zigbee2mqtt verwenden?” gibt:
" Für die Verwendung von Zigbee2MQTT mit einem Sonoff-Adapter gibt es zwei gängige Modelle: den Sonoff Zigbee 3.0 USB Dongle Plus P und den Sonoff Zigbee 3.0 USB Dongle Plus E .
Es ist wichtig, den richtigen Adaptertyp in der Konfiguration anzugeben, um eine reibungslose Kommunikation zu gewährleisten. Wenn du dir unsicher bist, welchen Adapter du hast, kannst du die Modellnummer auf dem Gerät überprüfen oder in der Produktbeschreibung nachsehen."
Wobei ich mir beim E-Model mit ember und ezsp unsicher bin.
LvS21
4. November 2024 um 17:06
8
Gute Frage - hier könnte besser jemand helfen, der selbst einen Sonoff-Stick unter zigbee2mqtt eingerichtet hat. Meiner läuft inzwischen mit Thread.
Ich kann nur eine Konfiguration für einen SLZB06 Stick anbieten. Aber vielleicht hilft das ja auch:
Eintrag in configuration.yaml (Wichtig: Verzeichnis zigbee2mqtt)
serial:
port: tcp://192.168.178.210:6638
baudrate: 115200
adapter: zstack
disable_led: false
wapjoe
4. November 2024 um 17:15
9
Hast du denn jetzt einen E- oder P-Dongle?
configuration.yaml
serial:
port: >-
/dev/serial/by-id/langer_pfad_zum_Dongle
adapter: zstack
E-Dongle (mit aktueller Firmware)
serial:
port: >-
adapter: ember
oder Konfiguration des Addons:
P-Dongle
Hallo @wapjoe ,
ich habe folgende Einstellungen Konfiguriert:
serial
port: >-
/dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_92dfb5ead58bee11a3dc03028acbdcd8-if00-port0
adapter: ezsp
also Adapter ember durch Adapter ezsp ersetzt. Und es läuft
Wenn ich das Protokoll richtig verstehe, sollte ich jetzt die Firmware updaten und dann den Adapter ember verwenden, oder?
Zusammenfassung
[19:19:46] INFO: Preparing to start...
[19:19:46] INFO: Socat not enabled
[19:19:46] INFO: Starting Zigbee2MQTT...
[2024-11-04 19:19:48] info: z2m: Logging to console, file (filename: log.log)
[2024-11-04 19:19:48] info: z2m: Starting Zigbee2MQTT version 1.41.0 (commit #unknown)
[2024-11-04 19:19:48] info: z2m: Starting zigbee-herdsman (2.1.7)
[2024-11-04 19:19:48] warning: zh:ezsp: 'ezsp' driver is deprecated and will only remain to provide support for older firmware (pre 7.4.x). Migration to 'ember' is recommended. If using Zigbee2MQTT see https://github.com/Koenkk/zigbee2mqtt/discussions/21462
[2024-11-04 19:19:52] info: z2m: zigbee-herdsman started (resumed)
[2024-11-04 19:19:52] info: z2m: Coordinator firmware version: '{"meta":{"maintrel":"3 ","majorrel":"6","minorrel":"10","product":8,"revision":"6.10.3.0 build 297"},"type":"EZSP v8"}'
[2024-11-04 19:19:52] info: z2m: Currently 0 devices are joined.
[2024-11-04 19:19:52] info: z2m: Zigbee: disabling joining new devices.
[2024-11-04 19:19:53] info: z2m: Connecting to MQTT server at mqtt://core-mosquitto:1883
[2024-11-04 19:19:53] info: z2m: Connected to MQTT server
[2024-11-04 19:19:53] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload '{"state":"online"}'
[2024-11-04 19:19:53] info: z2m: Started frontend on port 8099
[2024-11-04 19:19:53] info: z2m: Zigbee2MQTT started!
[2024-11-04 19:19:58] info: z2m:mqtt: MQTT publish: topic 'homeassistant/binary_sensor/1221051039810110150109113116116_0x8c65a3fffe54a654/connection_state/config', payload '{"device":{"hw_version":"EZSP v8 6.10.3.0 build 297","identifiers":["zigbee2mqtt_bridge_0x8c65a3fffe54a654"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"1.41.0"},"device_class":"connectivity","entity_category":"diagnostic","name":"Connection state","object_id":"zigbee2mqtt_bridge_connection_state","origin":{"name":"Zigbee2MQTT","sw":"1.41.0","url":"https://www.zigbee2mqtt.io"},"payload_off":"offline","payload_on":"online","state_topic":"zigbee2mqtt/bridge/state","unique_id":"bridge_0x8c65a3fffe54a654_connection_state_zigbee2mqtt","value_template":"{{ value_json.state }}"}'
wapjoe
4. November 2024 um 18:37
11
Lass dir die Infos doch nicht alle aus der Nase ziehen. Also hast du den Sonoff Plus-E Dongle . Mit dem E-Dongle kenne ich mich nicht aus, allerdings hab ich dazu mal aufgeschnappt, das mit neueren Firmwareupdates Ember als Eintritt nötig wird und Updates solltest du immer wieder machen, besonders bei Problemen.
Vielleicht kann dir noch jemand eine Empfehlung zum E-DONGLE geben oder du versuchst es bevor du dir ein Zigbee-Netz aufspannst.
Eine große Bitte: Wichtige Infos wie die Art des Dongles nicht erst per Zufall preisgeben, das macht der Community die Hilfestellung extrem einfacher.
Richtige Firmware?
so läuft das bei mir:
"serial": {
"adapter": "ember",
"disable_led": false,
"port": "/dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20230220092945-if00"
alternativ sollte auch
"serial": {
"adapter": "ember",
"port": "/dev/ttyACM0"
funktionieren
by HarryP: Codezeilen formatiert
LvS21
4. November 2024 um 20:28
14
Ja, dem ist so. „ezsp“ wird in Zukunft nicht mehr unterstützt und „ember“ läuft jetzt schon stabil. Versuch dich einfach mal den Adapter auf ember umzustellen. Wenn es nicht klappt, braucht der Stick noch ein Update.
Welche Firmware hast du denn?
Ich habe 6.10.3.0 build 297
Aktuell ist 7.4.4.0, flashen kannst Du ihn hier (da steht EZSP dran, das steht für EmberZNet Serial Protocol. In Z2M trägst Du ember ein).
wollte auch von ZHA zu Z2M wechseln.
Habe alles wie im Video soweit gemacht und Z2M ist auch über die Benutzeroberfläche lauffähig. Folgender fehler ist aber im Protokoll:
weiss jemand was falsch ist?
Abend zusammen,
ich habe gleiches Problem wie Thread Ersteller leider lösen eure Vorschläge mein Problem nicht.
Wichtig vorab scheint mir zu erwähnen das ich nicht das HAOS verwende sondern alle via Container auf einem PI läuft. (Es lief auch alles schon mal aber das ist eine lange andere Geschichte!) Ich habe also kein Addon Folder und aktuell weil zigbee2mqtt eh noch nicht läuft ist nicht mal ein HA Container am laufen.
Using '/app/data' as data directory
[2024-12-05 23:23:46] info: z2m: Logging to console, file (filename: log.log)
[2024-12-05 23:23:46] info: z2m: Starting Zigbee2MQTT version 1.42.0 (commit #861cba6)
[2024-12-05 23:23:46] info: z2m: Starting zigbee-herdsman (2.1.9)
[2024-12-05 23:23:47] info: zh:zstack:znp: Opening SerialPort with {"path":"/dev/ttyUSB0","baudRate":115200,"rtscts":false,"autoOpen":false}
[2024-12-05 23:23:47] info: zh:zstack:znp: Serialport opened
[2024-12-05 23:23:47] info: zh:zstack:znp: Writing CC2530/CC2531 skip bootloader payload
[2024-12-05 23:23:48] info: zh:zstack:znp: Skip bootloader for CC2652/CC1352
[2024-12-05 23:24:07] error: z2m: Error while starting zigbee-herdsman
[2024-12-05 23:24:07] error: z2m: Failed to start zigbee
[2024-12-05 23:24:07] error: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
[2024-12-05 23:24:07] error: z2m: Exiting...
[2024-12-05 23:24:07] error: z2m: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
Das ist die Fehlermeldung.
Was ich bisher gemacht habe bzw. weitere Infos
Ich habe habe ein Dongle-E aber nicht die V2
usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_78e5fdb2eedbed11837aed2d62c613ac-if00-port0
laut ITead’s “Sonoff Zigbee 3.0 USB Dongle Plus” model “ZBDongle-E” based on Silicon Labs EFR32MG21 +20dBm radio MCU/SoC (for EmberZNet/EZSP/Ember) · Koenkk/zigbee2mqtt · Discussion #13373 · GitHub müsste mein -E aber als Name V2 verwenden, merkwürdig.
ich habe die aktuellste Version 7.4.5 geflasht und habe es direkt via /dev/serial/ usw. als auch mit /dev/ttyUSB0 versucht. Auch, je Adresse, habe ich es mit ember und ezsp versucht.
zigbee2mqtt configuration.yml
homeassistant:
discovery_topic: homeassistant
legacy_entity_attributes: false
legacy_triggers: false
status_topic: hass/status
frontend:
port: 8080
mqtt:
base_topic: zigbee2mqtt
server: mqtt://192.168.178.32:1883
serial:
port: /dev/ttyUSB0
Adapter: ember
network_key:
- 0
- 108
- 196
- 91
- 228
- 121
- 231
- 120
- 55
- 250
- 126
- 188
- 152
- 18
- 33
- 121
pan_id: 18397
ext_pan_id:
- 129
- 143
- 7
- 39
- 149
- 118
- 157
- 165
homeassistant_legacy_entity_attributes: false
legacy_api: false
legacy_availability_payload: false
device_options:
legacy: false
die mosquitt.conf
listener 1883
socket_domain ipv4
allow_anonymous true
persistence true
persistence_location /mosquitto/data
Ich sitze jetzt seit 23 Stunden dran mein HA einfach nur wieder zum laufen zu bekommen, habe die SD Card mittlerweile 13 mal geflasht (auch in anderen Distros) ich bin rat los. Bitte, ich brauche Hilfe.
tarag
6. Dezember 2024 um 05:14
19
Schau doch mal in die Logs von HA / Supervisor, wie die Meldung vorschlägt.
Zeig mal was Du an Config zum Pfad und zum Adapter angegeben hast.
Woher hast Du die Pfade? Aus Deinem System?
Ja da war nichts. Hab HA 2mal neu gestartet und beim zweiten Mal war’s dann gut. Seltsame Wunderheilung
