Zigbee2MQTT Add-on startet nicht
ich bin den Tutorials auf youtube gefolgt, um Zigbee2MQTT zu installieren.
Dazu habe ich in der Konfiguration des Add-ons folgendes eingetragen
port: >-
  /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_babf4273b78ded11b3cd04f6b86ce6f8-if00-port0
adapter: zstack
Wenn ich jetzt das Add-on starte, erscheint im Protokoll folgende Fehlermeldung
[13:05:43] INFO: Preparing to start...
[13:05:43] INFO: Socat not enabled
[13:05:43] INFO: Starting Zigbee2MQTT...
[2025-02-28 13:05:48] info: 	z2m: Logging to console, file (filename: log.log)
[2025-02-28 13:05:48] info: 	z2m: Starting Zigbee2MQTT version 2.1.1 (commit #unknown)
[2025-02-28 13:05:48] info: 	z2m: Starting zigbee-herdsman (3.2.5)
[2025-02-28 13:05:49] info: 	zh:zstack:znp: Opening SerialPort with {"path":"/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_babf4273b78ded11b3cd04f6b86ce6f8-if00-port0","baudRate":115200,"rtscts":false,"autoOpen":false}
[2025-02-28 13:05:49] info: 	zh:zstack:znp: Serialport opened
[2025-02-28 13:05:49] info: 	zh:zstack:znp: Writing CC2530/CC2531 skip bootloader payload
[2025-02-28 13:05:50] info: 	zh:zstack:znp: Skip bootloader for CC2652/CC1352
[2025-02-28 13:06:09] error: 	z2m: Error while starting zigbee-herdsman
[2025-02-28 13:06:09] error: 	z2m: Failed to start zigbee-herdsman
[2025-02-28 13:06:09] error: 	z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions
[2025-02-28 13:06:09] error: 	z2m: Exiting...
[2025-02-28 13:06:09] error: 	z2m: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
    at ZStackAdapter.start (/app/node_modules/.pnpm/zigbee-herdsman@3.2.5/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:113:27)
    at Controller.start (/app/node_modules/.pnpm/zigbee-herdsman@3.2.5/node_modules/zigbee-herdsman/src/controller/controller.ts:136:29)
    at Zigbee.start (/app/lib/zigbee.ts:69:27)
    at Controller.start (/app/lib/controller.ts:142:13)
    at start (/app/index.js:161:5)
[13:06:11] INFO: Preparing to start...
[13:06:11] INFO: Socat not enabled
[13:06:12] INFO: Starting Zigbee2MQTT...
[2025-02-28 13:06:17] info: 	z2m: Logging to console, file (filename: log.log)
[2025-02-28 13:06:17] info: 	z2m: Starting Zigbee2MQTT version 2.1.1 (commit #unknown)
[2025-02-28 13:06:17] info: 	z2m: Starting zigbee-herdsman (3.2.5)
[2025-02-28 13:06:17] info: 	zh:zstack:znp: Opening SerialPort with {"path":"/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_babf4273b78ded11b3cd04f6b86ce6f8-if00-port0","baudRate":115200,"rtscts":false,"autoOpen":false}
[2025-02-28 13:06:17] info: 	zh:zstack:znp: Serialport opened
[2025-02-28 13:06:17] info: 	zh:zstack:znp: Writing CC2530/CC2531 skip bootloader payload
[2025-02-28 13:06:19] info: 	zh:zstack:znp: Skip bootloader for CC2652/CC1352
[2025-02-28 13:06:37] error: 	z2m: Error while starting zigbee-herdsman
[2025-02-28 13:06:37] error: 	z2m: Failed to start zigbee-herdsman
[2025-02-28 13:06:37] error: 	z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions
[2025-02-28 13:06:37] error: 	z2m: Exiting...
[2025-02-28 13:06:37] error: 	z2m: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
[13:06:40] INFO: Preparing to start...
[13:06:40] INFO: Socat not enabled
[13:06:40] INFO: Starting Zigbee2MQTT...
[2025-02-28 13:06:45] info: 	z2m: Logging to console, file (filename: log.log)
[2025-02-28 13:06:45] info: 	z2m: Starting Zigbee2MQTT version 2.1.1 (commit #unknown)
[2025-02-28 13:06:45] info: 	z2m: Starting zigbee-herdsman (3.2.5)
[2025-02-28 13:06:45] info: 	zh:zstack:znp: Opening SerialPort with {"path":"/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_babf4273b78ded11b3cd04f6b86ce6f8-if00-port0","baudRate":115200,"rtscts":false,"autoOpen":false}
[2025-02-28 13:06:46] info: 	zh:zstack:znp: Serialport opened
[2025-02-28 13:06:46] info: 	zh:zstack:znp: Writing CC2530/CC2531 skip bootloader payload
[2025-02-28 13:06:47] info: 	zh:zstack:znp: Skip bootloader for CC2652/CC1352
Ich weiß nicht, wieso das Add-on nicht startet.
Was mir auch auffällt. Obwohl ich Watch-Dog aktiviert habe, startet er ohne Watch-Dog.
Es wäre super, wenn mir jemand von euch helfen könnte. Ich weiß leider nicht weiter. Und im Netz konnte ich leider nichts finden.
Vielen Dank im Voraus
Versuch es mal bitte mit
adapter: ezsp
Ich hatte das gleiche Problem wie der Threadersteller, wenn ich ezsb als Adapter eingetragen habe, hat er mir einen anderen Fehler geworfen und ich konnte die Konfiguration nicht speichern, habe dann weiter gesucht und gesehen, dass evtl:
ezsp gemeint sein könnte. Lies sich speichern und die Integration lies sich öffnen. Nun versuche ich mal die Geräte hinzuzufügen
Ja, mit ezsp schreibt das System einen anderen Fehler und startet auch nicht
[14:39:50] INFO: Preparing to start...
[14:39:51] INFO: Socat not enabled
[14:39:51] INFO: Starting Zigbee2MQTT...
[2025-02-28 14:39:56] info: 	z2m: Logging to console, file (filename: log.log)
[2025-02-28 14:39:56] info: 	z2m: Starting Zigbee2MQTT version 2.1.1 (commit #unknown)
[2025-02-28 14:39:56] info: 	z2m: Starting zigbee-herdsman (3.2.5)
[2025-02-28 14:39:56] warning: 	zh:ezsp: 'ezsp' driver is deprecated and will only remain to provide support for older firmware (pre 7.4.x). Migration to 'ember' is recommended. If using Zigbee2MQTT see https://github.com/Koenkk/zigbee2mqtt/discussions/21462
[2025-02-28 14:40:06] error: 	zh:ezsp:uart: --> Error: Error: {"sequence":-1} after 10000ms
[2025-02-28 14:40:06] error: 	zh:ezsp:ezsp: Connection attempt 1 error: Error: Failure to connect
[2025-02-28 14:40:22] error: 	zh:ezsp:uart: --> Error: Error: {"sequence":-1} after 10000ms
[2025-02-28 14:40:22] error: 	zh:ezsp:ezsp: Connection attempt 2 error: Error: Failure to connect
Du hast den Sonoff Stick, da würde ich erst mal ein Firmwareupdate machen und dann ember eintragen anstelle von ezsp. Das wird Dir ja auch in der Fehlermeldung angezeigt.
Bei mir hat es geklappt mit ezsp und nun sind auch alle Geräte konfiguriert und eingebunden. Jetzt nur noch mein Dashboard neu gestalten mit den weiteren Möglichkeiten durch Z2M und dann kann ich nachher mal schauen ob ich meine neuen Shellys auch sinnvoll einbauen und nutzen kann^^
Wie manfred52 schon sagte ist ezsp das richtige.
Ezsp wird auch nicht mehr weiterentwickelt
Vielen Dank für die Tipps.
Wenn ich das zusammenfasse, muss ich also die Firmware aktualisieren und auf ember umstellen.
Jetzt bin ich gerade nur auf ein nicht unerhebliches weiteres Problem gestoßen. Bei der Installation des Raspberry OS bin ich anscheinend von meinem Standard-Raspberry-User abgewichen und kann mich nicht über SSH anmelden, um die Firmware zu aktualisieren. Ich ärgere mich gerade so dermaßen über mich selbst.
Naja, also muss ich ein Backup des HA erstellen und das OS neu draufspielen. Das mach ich aber erst ab Montag. Dazu habe ich am Wochenende keine Lust und Zeit.
Ich melde mich dann Anfang der Woche wieder.
Bis dahin wünsche ich euch ein schönes selbiges.
