Zigbee2MQTT Fehlermeldung
[2025-02-13 15:23:31] info: 	z2m: Logging to console, file (filename: log.log)
[2025-02-13 15:23:31] info: 	z2m: Starting Zigbee2MQTT version 2.1.1 (commit #unknown)
[2025-02-13 15:23:31] info: 	z2m: Starting zigbee-herdsman (3.2.5)
[2025-02-13 15:23:31] info: 	zh:adapter:discovery: Matched adapter: {"path":"/dev/ttyUSB0","manufacturer":"Itead","serialNumber":"b411cb7a783aef11a87d301455516304","pnpId":"usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_b411cb7a783aef11a87d301455516304-if00-port0","vendorId":"10c4","productId":"ea60"} => zstack: path=/dev/ttyUSB0, score=4
[2025-02-13 15:23:31] info: 	zh:zstack:znp: Opening SerialPort with {"path":"/dev/ttyUSB0","baudRate":115200,"rtscts":false,"autoOpen":false}
[2025-02-13 15:23:31] info: 	zh:zstack:znp: Serialport opened
[2025-02-13 15:23:32] info: 	zh:zstack:znp: Writing CC2530/CC2531 skip bootloader payload
[2025-02-13 15:23:33] info: 	zh:zstack:znp: Skip bootloader for CC2652/CC1352
[2025-02-13 15:23:51] error: 	z2m: Error while starting zigbee-herdsman
[2025-02-13 15:23:51] error: 	z2m: Failed to start zigbee-herdsman
[2025-02-13 15:23:51] error: 	z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions
[2025-02-13 15:23:51] error: 	z2m: Exiting...
[2025-02-13 15:23:52] error: 	z2m: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
    at ZStackAdapter.start (/app/node_modules/.pnpm/zigbee-herdsman@3.2.5/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:113:27)
    at Controller.start (/app/node_modules/.pnpm/zigbee-herdsman@3.2.5/node_modules/zigbee-herdsman/src/controller/controller.ts:136:29)
    at Zigbee.start (/app/lib/zigbee.ts:69:27)
    at Controller.start (/app/lib/controller.ts:142:13)
    at start (/app/index.js:161:5)>
:crayon:by HarryP:
. Threadtitel angepasst
. Codezeilen formatiert (bitte immer in </> einbinden)
Und was möchtest Du uns mit diesem Log-Auszug sagen bzw. Wo liegt genau Dein Problem?
BTW:
Ein paar weitere Angaben zu Deinem System, Deiner Hardware, dem Softwarestand wären natürlich auch hilfreich. :wink:
Könnte evtl. an einem installierten ZHA liegen.
Oder vermutlich eher daran das er für einen Sonoff Dongle-E zstack statt ember benutzt. :slightly_smiling_face:
@Bass1972 Firmware auf dem Dongle-E aktualieren und dann als Adapter adapter: ember benutzen. Steht hier aber auch schon x-mal im Forum beschrieben.
wie mach ich das
mit der aktualisieren
Dort kannst den Stick updaten. Musst halt an deinen Windows Rechner z.B. ran hängen.
linux mint habe ich ! windos benutze ich schon 5 jahre nicht mehr
Ich glaub das Betriebssystem ist relativ egal. Wollte nur sagen, das du an deinen Rechner wechseln musst und nicht unter HA das flashen machen kannst über die Seite.
Und auf jeden Fall einen Browser nehmen, mit dem das funktioniert, z. B. Chrome. Mit dem Firefox funktioniert es nicht.
Du kannst auch per HA Addon updaten:
Wie beschrieben wurde ist Chrome und nicht Windows die Voraussetzung. Chromium wird nicht funktionieren, wenn ich mich nicht täusche.
