bin neu im Forum, jede Hilfe willkommen.
Ich versuche seit einem Tag Zigbee2MQTT mit meinem neu gekauften Sonoff_Zigbee_3.0_USB_Dongle_Plus -P zum Laufen zu bringen - ohne Erfolg.
Anleitung von Simon gefolgt, mehrere Foren gelesen, mehrmals installiert und deinstalliert, Neustart zwischendurch, die yaml angepasst, ZHA ignoriert…
Folgende Fehlermeldung beim Starten:
[11:56:18] INFO: Preparing to start...
[11:56:18] INFO: Socat not enabled
[11:56:18] INFO: Starting Zigbee2MQTT...
[2025-01-25 11:56:20] info: z2m: Logging to console, file (filename: log.log)
[2025-01-25 11:56:20] info: z2m: Starting Zigbee2MQTT version 2.0.0 (commit #unknown)
[2025-01-25 11:56:20] info: z2m: Starting zigbee-herdsman (3.2.1)
[2025-01-25 11:56:20] info: zh:zstack:znp: Opening SerialPort with {"path":"/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_28c621a03739ec11b6d3e0680aac08d5-if00-port0","baudRate":115200,"rtscts":false,"autoOpen":false}
[2025-01-25 11:56:20] info: zh:zstack:znp: Serialport opened
[2025-01-25 11:56:20] info: zh:zstack:znp: Writing CC2530/CC2531 skip bootloader payload
[2025-01-25 11:56:21] info: zh:zstack:znp: Skip bootloader for CC2652/CC1352
[2025-01-25 11:56:40] error: z2m: Error while starting zigbee-herdsman
[2025-01-25 11:56:40] error: z2m: Failed to start zigbee-herdsman
[2025-01-25 11:56:40] error: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions
[2025-01-25 11:56:40] error: z2m: Exiting...
[2025-01-25 11:56:40] error: z2m: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
at ZStackAdapter.start (/app/node_modules/.pnpm/zigbee-herdsman@3.2.1/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:113:27)
at Controller.start (/app/node_modules/.pnpm/zigbee-herdsman@3.2.1/node_modules/zigbee-herdsman/src/controller/controller.ts:136:29)
at Zigbee.start (/app/lib/zigbee.ts:69:27)
at Controller.start (/app/lib/controller.ts:142:13)
at start (/app/index.js:161:5)
Die Konfig in Zigbee2MQTT:
Die yaml wie folgt:
Hat jemand eine Idee, was falsch ist?
Danke vorab.
