Zigbe2mqtt Sonoff 3.0 USB Dongle
ich bin mittlerweile am verzweifeln. Ich habe den USB Dogle 3.0 von Sonoff und wollte zigbee2mqtt installieren.
Ich habe alles eingerichtet, den dongle neu geflasht und wenn ich starte kommt immer ein fehler.
im Protokoll steht folgendes:
Onboarding page is available at http://0.0.0.0:8099/
[2026-01-17 20:49:52] info: 	z2m: Logging to console, file (filename: log.log)
[2026-01-17 20:49:52] info: 	z2m: Starting Zigbee2MQTT version 2.7.2 (commit #unknown)
[2026-01-17 20:49:52] info: 	z2m: Starting zigbee-herdsman (8.0.1)
[2026-01-17 20:49:53] info: 	zh:zstack:znp: Opening SerialPort with {"path":"/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_d22c949cc28aef118c542bccef8776e9-if00-port0","baudRate":115200,"rtscts":false,"autoOpen":false}
[2026-01-17 20:49:53] info: 	zh:zstack:znp: Serialport opened
[2026-01-17 20:49:53] info: 	zh:zstack:znp: Writing CC2530/CC2531 skip bootloader payload
[2026-01-17 20:50:30] error: 	z2m: Error while starting zigbee-herdsman
[2026-01-17 20:50:30] error: 	z2m: Failed to start zigbee-herdsman
[2026-01-17 20:50:30] error: 	z2m: Check  for possible solutions
[2026-01-17 20:50:30] error: 	z2m: Exiting...
[2026-01-17 20:50:30] error: 	z2m: TypeError: Cannot read properties of null (reading 'length')
    at AdapterNvMemory.init (/app/node_modules/.pnpm/zigbee-herdsman@8.0.1/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/adapter-nv-memory.ts:29:42)
    at ZnpAdapterManager.start (/app/node_modules/.pnpm/zigbee-herdsman@8.0.1/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:58:9)
    at ZStackAdapter.start (/app/node_modules/.pnpm/zigbee-herdsman@8.0.1/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:147:16)
    at Controller.start (/app/node_modules/.pnpm/zigbee-herdsman@8.0.1/node_modules/zigbee-herdsman/src/controller/controller.ts:143:29)
    at Zigbee.start (/app/lib/zigbee.ts:70:27)
    at Controller.start (/app/lib/controller.ts:101:13)
    at start (/app/index.js:149:5)
[20:50:31] INFO: Preparing to start...
[20:50:31] INFO: Socat not enabled
[20:50:32] INFO: Starting Zigbee2MQTT...
Kann mir irgendjemand helfen? hat irgendwer eine Idee was ich tun muss?
Die Anleitung bringt mir leider rein gar nichts, weil die ja voraussetzt das alles funktioniert. Ich komme nach dem Onboarding mit den Fehlern immer wieder auf die Onboarding Seite.
Hat sich erledigt, durch ein erneutes flashen läuft es jetzt endlich
