ZHA Migration auf Zigbee2MQTT, brauche Hilfe
ich brauche eure Hilfe beim Umzug von ZHA auf Z2M.
  • Als Coordinator verwende ich einen Home Assistant Connect ZBT-1.
  • mosquitto addon ist installiert und läuft
  • Zigbee2MQTT addon ist installiert und läuft
    • network_key, pan_id, extended_pan_id und channel habe ich aus ZHA übernommen
Allerdings werden keine Zigbee Devices erkannt, Z2M logs:
[22.11.2025, 20:46:33] frontend:api:bridge: Sending {"topic":"bridge/request/permit_join","payload":{"time":254,"device":null,"transaction":"6hwyf-1"}}
[22.11.2025, 20:46:33] z2m: Zigbee: allowing new devices to join.
[22.11.2025, 20:46:33] zh:ember: [STACK STATUS] Network opened.
[22.11.2025, 20:46:34] z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/response/permit_join', payload '{"data":{"time":254},"status":"ok","transaction":"6hwyf-1"}'
[22.11.2025, 20:50:10] zh:ember:ezsp: Received network/route error ROUTE_ERROR_MANY_TO_ONE_ROUTE_FAILURE for "3586".
[22.11.2025, 20:50:46] zh:ember: [STACK STATUS] Network closed.
[22.11.2025, 20:53:20] frontend:api:bridge: Sending {"topic":"bridge/request/permit_join","payload":{"time":254,"device":null,"transaction":"6hwyf-2"}}
[22.11.2025, 20:53:20] z2m: Zigbee: allowing new devices to join.
[22.11.2025, 20:53:20] zh:ember: [STACK STATUS] Network opened.
[22.11.2025, 20:53:20] z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/response/permit_join', payload '{"data":{"time":254},"status":"ok","transaction":"6hwyf-2"}'
[22.11.2025, 20:55:59] z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/health', payload '{"response_time":1763841358971,"os":{"load_average":[0.17,0.29,0.26],"memory_used_mb":1473.08,"memory_percent":74.8939},"process":{"uptime_sec":605,"memory_used_mb":64.24,"memory_percent":3.2662},"mqtt":{"connected":true,"queued":0,"published":38,"received":2},"devices":{}}'
[22.11.2025, 20:57:21] zh:ember:ezsp: Received network/route error ROUTE_ERROR_MANY_TO_ONE_ROUTE_FAILURE for "3586".
[22.11.2025, 20:57:33] zh:ember: [STACK STATUS] Network closed.
[22.11.2025, 21:00:03] zh:ember:ezsp: Received network/route error ROUTE_ERROR_MANY_TO_ONE_ROUTE_FAILURE for "3586".
[22.11.2025, 21:05:59] z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/health', payload '{"response_time":1763841958972,"os":{"load_average":[0.23,0.21,0.21],"memory_used_mb":1634.55,"memory_percent":83.1033},"process":{"uptime_sec":1205,"memory_used_mb":55.36,"memory_percent":2.8146},"mqtt":{"connected":true,"queued":0,"published":44,"received":2},"devices":{}}'
[22.11.2025, 21:06:27] frontend:api:bridge: Sending {"topic":"bridge/request/permit_join","payload":{"time":254,"device":null,"transaction":"6hwyf-3"}}
[22.11.2025, 21:06:27] z2m: Zigbee: allowing new devices to join.
[22.11.2025, 21:06:27] zh:ember: [STACK STATUS] Network opened.
[22.11.2025, 21:06:28] z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/response/permit_join', payload '{"data":{"time":254},"status":"ok","transaction":"6hwyf-3"}'
MQTT log:
2025-11-22 20:45:10: Opening ipv4 listen socket on port 1883.
2025-11-22 20:45:10: Opening ipv6 listen socket on port 1883.
2025-11-22 20:45:10: Opening websockets listen socket on port 1884.
2025-11-22 20:45:10: mosquitto version 2.0.22 running
2025-11-22 20:45:10: New connection from ::1:57898 on port 1883.
2025-11-22 20:45:10: Client <unknown> disconnected due to protocol error.
[20:45:11] INFO: Successfully send discovery information to Home Assistant.
[20:45:11] INFO: Successfully send service information to the Supervisor.
2025-11-22 20:45:16: New connection from 172.30.32.1:41807 on port 1883.
2025-11-22 20:45:16: New client connected from 172.30.32.1:41807 as 1anWKv6PtL0diuUUdga10a (p2, c1, k60, u'mqtt-user').
2025-11-22 20:45:51: New connection from 172.30.32.2:37682 on port 1883.
2025-11-22 20:45:51: Client <unknown> closed its connection.
2025-11-22 20:45:58: New connection from 172.30.33.2:40588 on port 1883.
2025-11-22 20:45:58: New client connected from 172.30.33.2:40588 as mqttjs_115d34e3 (p2, c1, k60, u'addons').
2025-11-22 20:47:51: New connection from 172.30.32.2:54152 on port 1883.
2025-11-22 20:47:51: Client <unknown> closed its connection.
2025-11-22 20:49:51: New connection from 172.30.32.2:53496 on port 1883.
2025-11-22 20:49:51: Client <unknown> closed its connection.
Was mache ich falsch? Das Z2M Addon hat laut docker die IP: 172.30.32.2
Update:
Entwarnung, es funktioniert doch. Allerdings muss ich alle Geräte neu anlernen :frowning:
Zudem habe ich den Adapter auf ezsp umgestellt. Später schaue ich ob es auch mit ember funktioniert.
