ZG-227Z Sensor zeigt keine Werte an
Habe über Zigbee2MQTT in HA einen ZG-227Z eingebunden.
Hat auch funktioniert, allerdings werden keine Werte für Temperatur, Feuchtigkeit und Batterie angezeigt.
Kann mir bitte jemand helfen?
Danke, Uwe
Hallo und danke.
Hier ist die Log
[10.9.2026, 18:23:58] z2m: Zigbee: allowing new devices to join.
[10.9.2026, 18:23:58] z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/response/permit_join', payload '{"data":{"time":254},"status":"ok","transaction":"1b2au-2"}'
[10.9.2026, 18:24:09] zh:controller: Interview for '0xa4c138f6cd0d121e' started
[10.9.2026, 18:24:09] z2m: Device '0xa4c138f6cd0d121e' joined
[10.9.2026, 18:24:09] z2m: Starting interview of '0xa4c138f6cd0d121e'
[10.9.2026, 18:24:09] z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0xa4c138f6cd0d121e","ieee_address":"0xa4c138f6cd0d121e"},"type":"device_joined"}'
[10.9.2026, 18:24:09] z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0xa4c138f6cd0d121e","ieee_address":"0xa4c138f6cd0d121e","status":"started"},"type":"device_interview"}'
[10.9.2026, 18:24:09] z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0xa4c138f6cd0d121e","ieee_address":"0xa4c138f6cd0d121e"},"type":"device_announce"}'
[10.9.2026, 18:24:10] zh:controller:device: Device '0xa4c138f6cd0d121e' is only compliant to revision '21' of the Zigbee specification (current revision: 23).
[10.9.2026, 18:24:21] zh:controller: Succesfully interviewed '0xa4c138f6cd0d121e'
[10.9.2026, 18:24:21] z2m: Successfully interviewed '0xa4c138f6cd0d121e', device has successfully been paired
[10.9.2026, 18:24:21] z2m: Device '0xa4c138f6cd0d121e' is supported, identified as: HOBEIAN Temperature & humidity sensor (ZG-227Z)
[10.9.2026, 18:24:21] z2m: Configuring '0xa4c138f6cd0d121e'
[10.9.2026, 18:24:21] z2m:mqtt: MQTT publish: topic 'homeassistant/sensor/0xa4c138f6cd0d121e/temperature/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"default_entity_id":"sensor.0xa4c138f6cd0d121e_temperature","device":{"hw_version":1,"identifiers":["zigbee2mqtt_0xa4c138f6cd0d121e"],"manufacturer":"HOBEIAN","model":"Temperature & humidity sensor","model_id":"ZG-227Z","name":"0xa4c138f6cd0d121e","sw_version":"0123052026","via_device":"zigbee2mqtt_bridge_0x00124b003416e6d3"},"device_class":"temperature","enabled_by_default":true,"object_id":"0xa4c138f6cd0d121e_temperature","origin":{"name":"Zigbee2MQTT","sw":"2.14.1","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/0xa4c138f6cd0d121e","unique_id":"0xa4c138f6cd0d121e_temperature_zigbee2mqtt","unit_of_measurement":"°C","value_template":"{{ value_json[\"temperature\"] }}"}'
[10.9.2026, 18:24:21] z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"definition":{"description":"Temperature & humidity sensor","exposes":[{"access":1,"description":"Measured temperature value","label":"Temperature","name":"temperature","property":"temperature","type":"numeric","unit":"°C"},{"access":1,"description":"Measured relative humidity","label":"Humidity","name":"humidity","property":"humidity","type":"numeric","unit":"%"},{"access":3,"description":"Temperature unit","label":"Temperature unit","name":"temperature_unit","property":"temperature_unit","type":"enum","values":["celsius","fahrenheit"]},{"access":3,"description":"Temperature calibration","label":"Temperature calibration","name":"temperature_calibration","property":"temperature_calibration","type":"numeric","unit":"°C","value_max":2,"value_min":-2,"value_step":0.1},{"access":3,"description":"Humidity calibration","label":"Humidity calibration","name":"humidity_calibration","property":"humidity_calibration","type":"numeric","unit":"%","value_max":30,"value_min":-30,"value_step":1},{"access":1,"category":"diagnostic","description":"Remaining battery in %, can take up to 24 hours before reported","label":"Battery","name":"battery","property":"battery","type":"numeric","unit":"%","value_max":100,"value_min":0},{"access":1,"category":"diagnostic","description":"Link quality (signal strength)","label":"Linkquality","name":"linkquality","property":"linkquality","type":"numeric","unit":"lqi","value_max":255,"value_min":0}],"model":"ZG-227Z","options":[{"access":2,"description":"Reply to Tuya-specific time synchronization requests: \"1970\" - Reply with seconds since 1970/01/01 (recommended, should stop the device from asking), \"2000\" - Reply with seconds since 2000/01/01 (use if the weekday is wrong with 1970), \"off\" - Don't reply (use if replying causes too much traffic). Default for this device: \"off\"","label":"Time start","name":"time_start","property":"time_start","type":"enum","values":["1970","2000","off"]},{"access":2,"description":"Calibrates the temperature value (absolute offset), takes into effect on next report of device.","label":"Temperature calibration","name":"temperature_calibration","property":"temperature_calibration","type":"numeric","value_step":0.1},{"access":2,"description":"Number of digits after decimal point for temperature, takes into effect on next report of device. This option can only decrease the precision, not increase it.","label":"Temperature precision","name":"temperature_precision","property":"temperature_precision","type":"numeric","value_max":3,"value_min":0},{"access":2,"description":"Calibrates the humidity value (absolute offset), takes into effect on next report of device.","label":"Humidity calibration","name":"humidity_calibration","property":"humidity_calibration","type":"numeric","value_step":0.1},{"access":2,"description":"Number of digits after decimal point for humidity, takes into effect on next report of device. This option can only decrease the precision, not increase it.","label":"Humidity precision","name":"humidity_precision","property":"humidity_precision","type":"numeric","value_max":3,"value_min":0}],"source":"native","supports_ota":false,"vendor":"HOBEIAN","version":"0.0.0"},"friendly_name":"0xa4c138f6cd0d121e","ieee_address":"0xa4c138f6cd0d121e","status":"successful","supported":true},"type":"device_interview"}'
[10.9.2026, 18:24:21] z2m:mqtt: MQTT publish: topic 'homeassistant/sensor/0xa4c138f6cd0d121e/humidity/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"default_entity_id":"sensor.0xa4c138f6cd0d121e_humidity","device":{"hw_version":1,"identifiers":["zigbee2mqtt_0xa4c138f6cd0d121e"],"manufacturer":"HOBEIAN","model":"Temperature & humidity sensor","model_id":"ZG-227Z","name":"0xa4c138f6cd0d121e","sw_version":"0123052026","via_device":"zigbee2mqtt_bridge_0x00124b003416e6d3"},"device_class":"humidity","enabled_by_default":true,"object_id":"0xa4c138f6cd0d121e_humidity","origin":{"name":"Zigbee2MQTT","sw":"2.14.1","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/0xa4c138f6cd0d121e","unique_id":"0xa4c138f6cd0d121e_humidity_zigbee2mqtt","unit_of_measurement":"%","value_template":"{{ value_json[\"humidity\"] }}"}'
[10.9.2026, 18:24:21] z2m:mqtt: MQTT publish: topic 'homeassistant/select/0xa4c138f6cd0d121e/temperature_unit/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"command_topic":"zigbee2mqtt/0xa4c138f6cd0d121e/set/temperature_unit","default_entity_id":"select.0xa4c138f6cd0d121e_temperature_unit","device":{"hw_version":1,"identifiers":["zigbee2mqtt_0xa4c138f6cd0d121e"],"manufacturer":"HOBEIAN","model":"Temperature & humidity sensor","model_id":"ZG-227Z","name":"0xa4c138f6cd0d121e","sw_version":"0123052026","via_device":"zigbee2mqtt_bridge_0x00124b003416e6d3"},"entity_category":"config","icon":"mdi:temperature-celsius","name":"Temperature unit","object_id":"0xa4c138f6cd0d121e_temperature_unit","options":["celsius","fahrenheit"],"origin":{"name":"Zigbee2MQTT","sw":"2.14.1","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/0xa4c138f6cd0d121e","unique_id":"0xa4c138f6cd0d121e_temperature_unit_zigbee2mqtt","value_template":"{{ value_json[\"temperature_unit\"] }}"}'
[10.9.2026, 18:24:21] z2m:mqtt: MQTT publish: topic 'homeassistant/number/0xa4c138f6cd0d121e/temperature_calibration/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"command_topic":"zigbee2mqtt/0xa4c138f6cd0d121e/set/temperature_calibration","default_entity_id":"number.0xa4c138f6cd0d121e_temperature_calibration","device":{"hw_version":1,"identifiers":["zigbee2mqtt_0xa4c138f6cd0d121e"],"manufacturer":"HOBEIAN","model":"Temperature & humidity sensor","model_id":"ZG-227Z","name":"0xa4c138f6cd0d121e","sw_version":"0123052026","via_device":"zigbee2mqtt_bridge_0x00124b003416e6d3"},"entity_category":"config","icon":"mdi:wrench-clock","max":2,"min":-2,"name":"Temperature calibration","object_id":"0xa4c138f6cd0d121e_temperature_calibration","origin":{"name":"Zigbee2MQTT","sw":"2.14.1","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/0xa4c138f6cd0d121e","step":0.1,"unique_id":"0xa4c138f6cd0d121e_temperature_calibration_zigbee2mqtt","unit_of_measurement":"°C","value_template":"{{ value_json[\"temperature_calibration\"] }}"}'
[10.9.2026, 18:24:21] z2m:mqtt: MQTT publish: topic 'homeassistant/number/0xa4c138f6cd0d121e/humidity_calibration/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"command_topic":"zigbee2mqtt/0xa4c138f6cd0d121e/set/humidity_calibration","default_entity_id":"number.0xa4c138f6cd0d121e_humidity_calibration","device":{"hw_version":1,"identifiers":["zigbee2mqtt_0xa4c138f6cd0d121e"],"manufacturer":"HOBEIAN","model":"Temperature & humidity sensor","model_id":"ZG-227Z","name":"0xa4c138f6cd0d121e","sw_version":"0123052026","via_device":"zigbee2mqtt_bridge_0x00124b003416e6d3"},"entity_category":"config","icon":"mdi:wrench-clock","max":30,"min":-30,"name":"Humidity calibration","object_id":"0xa4c138f6cd0d121e_humidity_calibration","origin":{"name":"Zigbee2MQTT","sw":"2.14.1","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/0xa4c138f6cd0d121e","step":1,"unique_id":"0xa4c138f6cd0d121e_humidity_calibration_zigbee2mqtt","unit_of_measurement":"%","value_template":"{{ value_json[\"humidity_calibration\"] }}"}'
[10.9.2026, 18:24:21] z2m:mqtt: MQTT publish: topic 'homeassistant/sensor/0xa4c138f6cd0d121e/battery/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"default_entity_id":"sensor.0xa4c138f6cd0d121e_battery","device":{"hw_version":1,"identifiers":["zigbee2mqtt_0xa4c138f6cd0d121e"],"manufacturer":"HOBEIAN","model":"Temperature & humidity sensor","model_id":"ZG-227Z","name":"0xa4c138f6cd0d121e","sw_version":"0123052026","via_device":"zigbee2mqtt_bridge_0x00124b003416e6d3"},"device_class":"battery","enabled_by_default":true,"entity_category":"diagnostic","object_id":"0xa4c138f6cd0d121e_battery","origin":{"name":"Zigbee2MQTT","sw":"2.14.1","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/0xa4c138f6cd0d121e","unique_id":"0xa4c138f6cd0d121e_battery_zigbee2mqtt","unit_of_measurement":"%","value_template":"{{ value_json[\"battery\"] }}"}'
[10.9.2026, 18:24:21] z2m:mqtt: MQTT publish: topic 'homeassistant/sensor/0xa4c138f6cd0d121e/linkquality/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"default_entity_id":"sensor.0xa4c138f6cd0d121e_linkquality","device":{"hw_version":1,"identifiers":["zigbee2mqtt_0xa4c138f6cd0d121e"],"manufacturer":"HOBEIAN","model":"Temperature & humidity sensor","model_id":"ZG-227Z","name":"0xa4c138f6cd0d121e","sw_version":"0123052026","via_device":"zigbee2mqtt_bridge_0x00124b003416e6d3"},"enabled_by_default":false,"entity_category":"diagnostic","icon":"mdi:signal","name":"Linkquality","object_id":"0xa4c138f6cd0d121e_linkquality","origin":{"name":"Zigbee2MQTT","sw":"2.14.1","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/0xa4c138f6cd0d121e","unique_id":"0xa4c138f6cd0d121e_linkquality_zigbee2mqtt","unit_of_measurement":"lqi","value_template":"{{ value_json[\"linkquality\"] }}"}'
[10.9.2026, 18:24:23] z2m: Successfully configured '0xa4c138f6cd0d121e' (definition v0.0.0)
