Ich versuche hier die Zegbee2MQTT einzurichten, leider bisher ohne irgendwo stockt es, würde mich über eine kleine Unterstützung freuen…Protokoll:
NUC mit VM (Proxmox)
'2025-03-12 11:45:24] info: z2m: Started frontend on port 8099
[2025-03-12 11:45:24] error: z2m: Failed to call 'HomeAssistant' 'start' (TypeError: Cannot read properties of undefined (reading 'deviceIeeeAddress')
at HomeAssistant.getBridgeEntity (/app/lib/extension/homeassistant.ts:1943:78)
at HomeAssistant.start (/app/lib/extension/homeassistant.ts:440:28)
at Controller.callExtensions (/app/lib/controller.ts:368:17)
at Controller.start (/app/lib/controller.ts:186:9)
at start (/app/index.js:161:5))
[2025-03-12 11:45:24] info: z2m: Zigbee2MQTT started!
[2025-03-12 11:45:26] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload '{"state":"online"}'
[2025-03-12 11:54:58] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload '{"state":"offline"}'
[2025-03-12 11:54:58] info: z2m: Disconnecting from MQTT server
[2025-03-12 11:54:58] info: z2m: Stopping zigbee-herdsman...
[2025-03-12 11:55:04] error: zh:controller: Failed to disable join on stop: Error: SRSP - AF - dataRequestExt after 6000ms
[2025-03-12 11:55:11] info: zh:controller: Wrote coordinator backup to '/config/zigbee2mqtt/coordinator_backup.json'
[2025-03-12 11:55:11] info: zh:zstack:znp: closing
[2025-03-12 11:55:12] info: zh:zstack:znp: Port closed
[2025-03-12 11:55:12] info: z2m: Stopped zigbee-herdsman
[2025-03-12 11:55:12] info: z2m: Stopped Zigbee2MQTT
[11:55:12] INFO: Preparing to start...
[11:55:12] INFO: Socat not enabled
[11:55:12] INFO: Starting Zigbee2MQTT...
[2025-03-12 11:55:13] info: z2m: Logging to console, file (filename: log.log)
[2025-03-12 11:55:13] info: z2m: Starting Zigbee2MQTT version 2.1.3 (commit #unknown)
[2025-03-12 11:55:13] info: z2m: Starting zigbee-herdsman (3.2.7)
[2025-03-12 11:55:13] info: zh:zstack:znp: Opening SerialPort with {"path":"/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_64793900006bef11bcf8a3adc169b110-if00-port0","baudRate":115200,"rtscts":false,"autoOpen":false}
[2025-03-12 11:55:13] info: zh:zstack:znp: Serialport opened
[2025-03-12 11:55:16] info: z2m: zigbee-herdsman started (resumed)
[2025-03-12 11:55:16] info: z2m: Coordinator firmware version: '{"meta":{"maintrel":1,"majorrel":2,"minorrel":7,"product":1,"revision":20210708,"transportrev":2},"type":"zStack3x0"}'
[2025-03-12 11:55:16] info: z2m: Currently 0 devices are joined.
[2025-03-12 11:55:16] info: z2m: Connecting to MQTT server at mqtt://core-mosquitto:1883
[2025-03-12 11:55:16] info: z2m: Connected to MQTT server
[2025-03-12 11:55:16] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload '{"state":"online"}'
[2025-03-12 11:55:16] error: z2m: Failed to call 'Bridge' 'start' (TypeError: Cannot read properties of undefined (reading 'getDevice')
at Bridge.publishInfo (/app/lib/extension/bridge.ts:692:69)
at Bridge.start (/app/lib/extension/bridge.ts:179:9)
[2025-03-12 11:55:16] info: z2m: Started frontend on port 8099
[2025-03-12 11:55:16] error: z2m: Failed to call 'HomeAssistant' 'start' (TypeError: Cannot read properties of undefined (reading 'deviceIeeeAddress')
[2025-03-12 11:55:16] info: z2m: Zigbee2MQTT started!
[2025-03-12 11:55:18] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload '{"state":"online"}'
Okay vom Broker her gibts dort kein Problem dann scheint es aber trotzdem ein übergabe Problem zu geben.
Ich seh hier du hast den Sonoff Stick… Welchen denn -P oder -E? Bei dem -P kann ich noch etwas helfen. Denn -E hat bei mir auch nicht Funktioniert.
Gerne mal gleich die ganzen Infos zu dem Stick geben. (Version des Sticks, ob geflasht wurde und ob Updates gemacht sind.)
Okay Folgendes es gibt 2 wege um das jetzt zu lösen, die weitaus sinnvollere ist den Stick auf neuste Version zu Flashen. Allerdings sollte der Stick Plug and Play den Service starten und nutzen können. Heißt auspacken anstecken einstellen starten, hat bei dir aber nicht geklappt. Scheint in deinem fall so gewesen sein. Es könnte jetzt sein das du Zigbee2MQTT falsch eingestellt hast. Dazu solltest du dir dann nochmal die Einstellungen vornehmen.
Im Grunde solltest du aber etwas derartiges dort eingetragen haben.
adapter: zstack # Dort dann den passenden Adapter reinpacken.
port: >-
/dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_aab040e4aa6bef11ac6799adc169b110-if00-port0 # Hier eben einmal den port angeben in besten fall by-id verwenden.
Alternativ:
Installiere dir dieses Add-on dort musst du dann das passende für den Dongel-P Wählen.
Dort findest du dann deinen Stick und zugehörige Werte. Alternativ falls voher eh schon ZHA verwendet wurde dann hat ein Nutzer hier das in seiner JSON-Datei gefunden.
Aber ich denke es handelt sich um ein Update problem daher einfach dem folgen.
Meist hat das dann damit zu tun das der Stick schon verwendet wird. Dazu einmal alle adons die den stick nutzen könnten ausschalten und stick aus dem port entfernen. Kurz warten stick anstecken und nur mqtt Broker und zigbee starten.
Danach kannst du deine anderen Add-ons restarten fehler sollte weg sein zigbee sollte laufen!
