Zgbee2mqtt startet nicht mehr
Zigbee2mqtt startet bei mir nicht mehr.
hier der log
danke im vorraus für eure Hilfe
[14:26:14] INFO: Preparing to start...
[14:26:14] INFO: Socat not enabled
[14:26:14] INFO: Starting Zigbee2MQTT...
[2026-02-22 14:26:15] debug: 	z2m: Removing old log directory '/config/zigbee2mqtt/log/2026-02-22.14-09-38'
[2026-02-22 14:26:15] info: 	z2m: Logging to console, file (filename: log.log)
[2026-02-22 14:26:15] debug: 	z2m: Loaded state from file /config/zigbee2mqtt/state.json
[2026-02-22 14:26:15] info: 	z2m: Starting Zigbee2MQTT version 2.8.0 (commit #unknown)
[2026-02-22 14:26:15] info: 	z2m: Starting zigbee-herdsman (9.0.2)
[2026-02-22 14:26:15] debug: 	z2m: Using zigbee-herdsman with settings: '"{\"network\":{\"panID\":39854,\"extendedPanID\":[43,156,221,19,238,92,150,43],\"channelList\":[11],\"networkKey\":\"HIDDEN\"},\"databasePath\":\"/config/zigbee2mqtt/database.db\",\"databaseBackupPath\":\"/config/zigbee2mqtt/database.db.backup\",\"backupPath\":\"/config/zigbee2mqtt/coordinator_backup.json\",\"serialPort\":{\"path\":\"/dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_709bb0b69812ef11b58278b8bf9df066-if00-port0\",\"adapter\":\"ember\"},\"adapter\":{\"disableLED\":false}}"'
[2026-02-22 14:26:15] debug: 	zh:adapter:discovery: Connected devices: [{"path":"/dev/ttyS0"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS3"}]
[2026-02-22 14:26:15] debug: 	zh:adapter:discovery: Unable to match USB adapter: ember | /dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_709bb0b69812ef11b58278b8bf9df066-if00-port0
[2026-02-22 14:26:15] info: 	zh:ember: Using default stack config.
[2026-02-22 14:26:15] debug: 	zh:controller: Starting with options '{"network":{"networkKeyDistribute":false,"networkKey":"HIDDEN","extendedPanID":[43,156,221,19,238,92,150,43],"panID":39854,"channelList":[11]},"serialPort":{"path":"/dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_709bb0b69812ef11b58278b8bf9df066-if00-port0","adapter":"ember"},"adapter":{"disableLED":false},"databasePath":"/config/zigbee2mqtt/database.db","databaseBackupPath":"/config/zigbee2mqtt/database.db.backup","backupPath":"/config/zigbee2mqtt/coordinator_backup.json"}'
[2026-02-22 14:26:15] info: 	zh:ember: ======== Ember Adapter Starting ========
[2026-02-22 14:26:15] info: 	zh:ember:ezsp: ======== EZSP starting ========
[2026-02-22 14:26:15] info: 	zh:ember:uart:ash: ======== ASH Adapter reset ========
[2026-02-22 14:26:15] info: 	zh:ember:uart:ash: RTS/CTS config is off, enabling software flow control.
[2026-02-22 14:26:15] debug: 	zh:ember:uart:ash: Opening serial port with {"path":"/dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_709bb0b69812ef11b58278b8bf9df066-if00-port0","baudRate":115200,"rtscts":false,"autoOpen":false,"parity":"none","stopBits":1,"xon":true,"xoff":true}
[2026-02-22 14:26:15] info: 	zh:ember:uart:ash: ASH COUNTERS since last clear:
[2026-02-22 14:26:15] info: 	zh:ember:uart:ash:   Total frames: RX=0, TX=0
[2026-02-22 14:26:15] info: 	zh:ember:uart:ash:   Cancelled   : RX=0, TX=0
[2026-02-22 14:26:15] info: 	zh:ember:uart:ash:   DATA frames : RX=0, TX=0
[2026-02-22 14:26:15] info: 	zh:ember:uart:ash:   DATA bytes  : RX=0, TX=0
[2026-02-22 14:26:15] info: 	zh:ember:uart:ash:   Retry frames: RX=0, TX=0
[2026-02-22 14:26:15] info: 	zh:ember:uart:ash:   ACK frames  : RX=0, TX=0
[2026-02-22 14:26:15] info: 	zh:ember:uart:ash:   NAK frames  : RX=0, TX=0
[2026-02-22 14:26:15] info: 	zh:ember:uart:ash:   nRdy frames : RX=0, TX=0
[2026-02-22 14:26:15] info: 	zh:ember:uart:ash:   CRC errors      : RX=0
[2026-02-22 14:26:15] info: 	zh:ember:uart:ash:   Comm errors     : RX=0
[2026-02-22 14:26:15] info: 	zh:ember:uart:ash:   Length < minimum: RX=0
[2026-02-22 14:26:15] info: 	zh:ember:uart:ash:   Length > maximum: RX=0
[2026-02-22 14:26:15] info: 	zh:ember:uart:ash:   Bad controls    : RX=0
[2026-02-22 14:26:15] info: 	zh:ember:uart:ash:   Bad lengths     : RX=0
[2026-02-22 14:26:15] info: 	zh:ember:uart:ash:   Bad ACK numbers : RX=0
[2026-02-22 14:26:15] info: 	zh:ember:uart:ash:   Out of buffers  : RX=0
[2026-02-22 14:26:15] info: 	zh:ember:uart:ash:   Retry dupes     : RX=0
[2026-02-22 14:26:15] info: 	zh:ember:uart:ash:   Out of sequence : RX=0
[2026-02-22 14:26:15] info: 	zh:ember:uart:ash:   ACK timeouts    : RX=0
[2026-02-22 14:26:15] info: 	zh:ember:uart:ash: ======== ASH stopped ========
[2026-02-22 14:26:15] error: 	zh:ember:uart:ash: Failed to init port with error Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_709bb0b69812ef11b58278b8bf9df066-if00-port0
[2026-02-22 14:26:15] error: 	z2m: Error while starting zigbee-herdsman
[2026-02-22 14:26:15] error: 	z2m: Failed to start zigbee-herdsman
[2026-02-22 14:26:15] error: 	z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions
[2026-02-22 14:26:15] error: 	z2m: Exiting...
[2026-02-22 14:26:15] error: 	z2m: Error: Failed to start EZSP layer with status=HOST_FATAL_ERROR.
    at EmberAdapter.initEzsp (/app/node_modules/.pnpm/zigbee-herdsman@9.0.2/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:666:19)
    at EmberAdapter.start (/app/node_modules/.pnpm/zigbee-herdsman@9.0.2/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:1538:24)
    at Controller.start (/app/node_modules/.pnpm/zigbee-herdsman@9.0.2/node_modules/zigbee-herdsman/src/controller/controller.ts:143:29)
    at Zigbee.start (/app/lib/zigbee.ts:70:27)
    at Controller.start (/app/lib/controller.ts:101:13)
    at start (/app/index.js:149:5)
Bitte zuerst Deine Z2M configuration.yaml aus /homeassistant/zigbee2mqtt hier posten und dann sieht man weiter.
Wenn ich die Fehlermeldung richtig deute, stimmt der Pfad zum Dongle nicht.
