bin komplett neu hier und auch mit HA (bisher mit IO-Broker gefahren).
Habe heute den Sonoff Stick mit Mosqitto und dann Z2M gem. YT Video auf einem Pi4 installiert. Läuft aber nicht. Hier das Log:
[18:17:46] INFO: Preparing to start...
[18:17:46] INFO: Socat not enabled
[18:17:46] INFO: Starting Zigbee2MQTT...
[2025-01-17 18:17:51] info: z2m: Logging to console, file (filename: log.log)
[2025-01-17 18:17:51] info: z2m: Starting Zigbee2MQTT version 2.0.0 (commit #unknown)
[2025-01-17 18:17:51] info: z2m: Starting zigbee-herdsman (3.2.1)
[2025-01-17 18:17:51] info: zh:adapter:discovery: Matched adapter: {"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"cc0139029fdbed11b2e8e72d62c613ac","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_cc0139029fdbed11b2e8e72d62c613ac-if00-port0","vendorId":"10c4","productId":"ea60"} => zstack: path=/dev/ttyUSB0, score=4
[2025-01-17 18:17:51] info: zh:zstack:znp: Opening SerialPort with {"path":"/dev/ttyUSB0","baudRate":115200,"rtscts":false,"autoOpen":false}
[2025-01-17 18:17:51] info: zh:zstack:znp: Serialport opened
[2025-01-17 18:17:51] info: zh:zstack:znp: Writing CC2530/CC2531 skip bootloader payload
[2025-01-17 18:17:53] info: zh:zstack:znp: Skip bootloader for CC2652/CC1352
[2025-01-17 18:17:54] error: z2m: Failed to call 'Frontend' 'stop' (TypeError: Cannot read properties of undefined (reading 'close')
at /app/lib/extension/frontend.ts:132:52
at new Promise (<anonymous>)
at Frontend.stop (/app/lib/extension/frontend.ts:132:15)
at Controller.callExtensions (/app/lib/controller.ts:368:17)
at Controller.stop (/app/lib/controller.ts:233:9)
at stop (/app/index.js:172:5)
at process.handleQuit (/app/index.js:180:13))
[2025-01-17 18:17:54] error: z2m: Not connected to MQTT server!
[2025-01-17 18:17:54] error: z2m: Cannot send message: topic: 'zigbee2mqtt/bridge/state', payload: '{"state":"offline"}
Firmware finde ich da nirgends… schaue mal weiter.
Update:
Adapter in Config auf ezsp geändert. Jetzt läuft es. Allerdings mit Warnung:
warning: zh:ezsp: 'ezsp' driver is deprecated and will only remain to provide support for older firmware (pre 7.4.x). Migration to 'ember' is recommended. If using Zigbee2MQTT see https://github.com/Koenkk/zigbee2mqtt/discussions/21462
Erstes Gerät wurde schon erkannt. Da werde ich mal weiter schauen.
