Welche HA installation
> version: 4
> mqtt:
> base_topic: zigbee2mqtt
> server: mqtt://192.168.20.11:18083
> serial:
> port: tcp://192.168.20.14:6638
> adapter: zstack
> advanced:
> channel: 15
> network_key:
> - 47
> - 11
> - 116
> - 198
> - 56
> - 134
> - 134
> - 220
> - 237
> - 101
> - 18
> - 45
> - 96
> - 107
> - 31
> - 159
> pan_id: 41143
> ext_pan_id:
> - 63
> - 167
> - 69
> - 56
zigbee2mqtt.service - zigbee2mqtt
Loaded: loaded (/etc/systemd/system/zigbee2mqtt.service; enabled; preset: enabled)
Active: active (running) since Sat 2025-10-04 20:58:40 CEST; 3min 2s ago
Main PID: 690 (MainThread)
Tasks: 23 (limit: 18952)
Memory: 128.2M
CPU: 1.888s
CGroup: /system.slice/zigbee2mqtt.service
├─690 node /usr/bin/pnpm start
├─701 sh -c “node index.js”
└─702 node index.js
Oct 04 20:58:40 zigbee2mqtt pnpm\[702\]: \[2025-10-04 20:58:40\] info:         z2m: Starting zigbee-herdsman (6.1.5)
Oct 04 20:58:40 zigbee2mqtt pnpm\[702\]: \[2025-10-04 20:58:40\] info:         zh:zstack:znp: Opening TCP socket with 192.168.20.14:6638
Oct 04 20:58:40 zigbee2mqtt pnpm\[702\]: \[2025-10-04 20:58:40\] info:         zh:zstack:znp: Socket connected
Oct 04 20:58:40 zigbee2mqtt pnpm\[702\]: \[2025-10-04 20:58:40\] info:         zh:zstack:znp: Socket ready
Oct 04 20:58:40 zigbee2mqtt pnpm\[702\]: \[2025-10-04 20:58:40\] info:         zh:zstack:znp: Writing CC2530/CC2531 skip bootloader payload
Oct 04 20:58:41 zigbee2mqtt pnpm\[702\]: \[2025-10-04 20:58:41\] info:         zh:zstack:znp: Skip bootloader for CC2652/CC1352
Oct 04 21:00:04 zigbee2mqtt pnpm\[702\]: \[2025-10-04 21:00:04\] info:         z2m: zigbee-herdsman started (restored)
Oct 04 21:00:04 zigbee2mqtt pnpm\[702\]: \[2025-10-04 21:00:04\] info:         z2m: Coordinator firmware version: '{“meta”:{“maintrel”:1,“majorrel”:2,"minorr>
Oct 04 21:00:04 zigbee2mqtt pnpm\[702\]: \[2025-10-04 21:00:04\] info:         z2m: Currently 0 devices are joined.
Oct 04 21:00:04 zigbee2mqtt pnpm\[702\]: \[2025-10-04 21:00:04\] info:         z2m: Connecting to MQTT server at mqtt://192.168.20.11:18083
Verbindung fehlgeschlagen
Firefox kann keine Verbindung zu dem Server unter 192.168.20.13:8080 aufbauen.
    Die Website könnte vorübergehend nicht erreichbar sein, versuchen Sie es bitte später nochmals.
    Wenn Sie auch keine andere Website aufrufen können, überprüfen Sie bitte die Netzwerk-/Internetverbindung.
    Wenn Ihr Computer oder Netzwerk von einer Firewall oder einem Proxy geschützt wird, stellen Sie bitte sicher, dass Firefox auf das Internet zugreifen darf.
