Hallo allerseits,
Wen man die Integration “Waste Collection Schedule” und auch " icalendar" gleichzeitig aus HACS verwendet, kann es dazu führen, dass Waste Collection schedule nicht mehr funktioniert. Das liegt daran, dass sich die Integrationen bezüglich einer Komponente ins Gehege kommen.
Eine Lösung wird hier beschrieben:
offen 05:07PM - 21 Oct 24 UTC
### I Have A Problem With:
A specific source
### What's Your Problem
2024-10-… 21 18:29:27.425 ERROR (SyncWorker_4) [custom_components.waste_collection_schedule.waste_collection_schedule.source_shell] source not found: kwu_de
### Source (if relevant)
kwu_de
### Logs
```Shell
2024-10-21 18:29:27.425 ERROR (SyncWorker_4) [custom_components.waste_collection_schedule.waste_collection_schedule.source_shell] source not found: kwu_de
### Relevant Configuration
_No response_
### Checklist Source Error
- [ ] Use the example parameters for your source (often available in the documentation) (don't forget to restart Home Assistant after changing the configuration)
- [X] Checked that the website of your service provider is still working
- [X] Tested my attributes on the service provider website (if possible)
- [X] I have tested with the latest version of the integration (master) (for HACS in the 3 dot menu of the integration click on "Redownload" and choose master as version)
### Checklist Sensor Error
- [ ] Checked in the Home Assistant Calendar tab if the event names match the types names (if types argument is used)
### Required
- [X] I have searched past (closed AND opened) issues to see if this bug has already been reported, and it hasn't been.
- [X] I understand that people give their precious time for free, and thus I've done my very best to make this problem as easy as possible to investigate.
Dazu muss jedoch man beim AddOn Advanced SSH & Web Terminal den gesicherten Modus abstellen.
Hendrik
