Ich hab’s hinbekommen.
Musste einfach die “switch”-node erweitern und die Meldungsaufbereitung auf
4 Varianten erweitern.
Der obere Flow ist der neue, der untere war der alte.
[{"id":"12805c09244a9e90","type":"comment","z":"5e38a40b1ab38ea9","name":"DWD-Warnungen","info":"","x":150,"y":1322,"wires":[]},{"id":"4a1c096a280e5f0d","type":"api-call-service","z":"5e38a40b1ab38ea9","name":"Ausgabe","server":"a1aba8eb.bfd618","version":5,"debugenabled":false,"domain":"notify","service":"telegram_harald","areaId":[],"deviceId":[],"entityId":[],"data":"(msg.payload)","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1266.571533203125,"y":1383.7142333984375,"wires":[[]]},{"id":"cb5e1248fc37d1c4","type":"function","z":"5e38a40b1ab38ea9","name":"Message","func":"let payload = {\n \"message\": \"Es liegt eine Wetterwarnung vor: \" + (msg.data.attributes.warning_1_description)}\nreturn { payload };","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":531.1429443359375,"y":1398.5714111328125,"wires":[["bc1430f835c93119"]]},{"id":"83abbd668e554cc6","type":"api-current-state","z":"5e38a40b1ab38ea9","name":"DWD","server":"a1aba8eb.bfd618","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.dwd_weather_warnings_808121000_current_warning_level","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":482,"y":1332,"wires":[["b716f6665d30d81f"]]},{"id":"6b68a9d6fd4b16ca","type":"switch","z":"5e38a40b1ab38ea9","name":"Warnung","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"1","vt":"num"},{"t":"eq","v":"2","vt":"num"},{"t":"eq","v":"3","vt":"num"},{"t":"eq","v":"4","vt":"num"},{"t":"eq","v":"0","vt":"num"}],"checkall":"false","repair":false,"outputs":5,"x":336,"y":1468,"wires":[["cb5e1248fc37d1c4"],["7480f49c448fbe1e"],["ebca405674658eca"],["c59384348d7de1a7"],["6c4946b0883121e4"]]},{"id":"010080c483544834","type":"time-range-switch","z":"5e38a40b1ab38ea9","name":"tagsüber","lat":"49.0804","lon":"9.3104","startTime":"05:00","endTime":"22:00","startOffset":0,"endOffset":0,"x":1923.4287719726562,"y":1556.2857847213745,"wires":[["420b6b592c627853"],[]]},{"id":"420b6b592c627853","type":"alexa-remote-routine","z":"5e38a40b1ab38ea9","name":"Sprachausgabe","account":"1dc2bfdd622bc8d9","routineNode":{"type":"speak","payload":{"type":"announcement","text":{"type":"msg","value":"payload.message"},"devices":["G000RA0995260UQ8","G2A0P30774060QHW"]}},"x":2093.4287719726562,"y":1540.2857847213745,"wires":[[]]},{"id":"4bc72abf87ff6d37","type":"moment","z":"5e38a40b1ab38ea9","name":"Zeit formatieren","topic":"","input":"payload","inputType":"msg","inTz":"Europe/Berlin","adjAmount":"0","adjType":"minutes","adjDir":"add","format":"DD.MM.YYYY HH:mm","locale":"de","output":"payload","outputType":"msg","outTz":"Europe/Berlin","x":488,"y":1684,"wires":[["7ed261982de49710"]]},{"id":"7cddc7aa69f96405","type":"moment","z":"5e38a40b1ab38ea9","name":"Zeit formatieren","topic":"","input":"data.attributes.warning_1_start","inputType":"msg","inTz":"Europe/Berlin","adjAmount":"1","adjType":"minutes","adjDir":"add","format":"DD.MM.YYYY HH:mm","locale":"de","output":"payload","outputType":"msg","outTz":"Europe/Berlin","x":486,"y":1632,"wires":[["7ed261982de49710"]]},{"id":"7ed261982de49710","type":"join","z":"5e38a40b1ab38ea9","name":"","mode":"custom","build":"array","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":656,"y":1632,"wires":[["7ec6df3e6ef7fa21"]]},{"id":"7ec6df3e6ef7fa21","type":"switch","z":"5e38a40b1ab38ea9","name":"aktuell?","property":"payload[0]","propertyType":"msg","rules":[{"t":"eq","v":"payload[1]","vt":"msg"},{"t":"gt","v":"payload[1]","vt":"msg"}],"checkall":"true","repair":false,"outputs":2,"x":804,"y":1632,"wires":[["286b86dc29b0d2b3","faf479f296de97d1","1aecb61b250d183c"],["f3043e8ed07d0eb5"]]},{"id":"7c1b6bea3d464280","type":"api-current-state","z":"5e38a40b1ab38ea9","name":"DWD","server":"a1aba8eb.bfd618","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.dwd_weather_warnings_808121000_current_warning_level","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":318,"y":1632,"wires":[["7cddc7aa69f96405"]]},{"id":"5e17d134ce451f7b","type":"server-state-changed","z":"5e38a40b1ab38ea9","name":"Aktuelle Zeit","server":"a1aba8eb.bfd618","version":5,"outputs":1,"exposeAsEntityConfig":"","entityId":"sensor.time","entityIdType":"exact","outputInitially":true,"stateType":"str","ifState":"","ifStateType":"num","ifStateOperator":"is","outputOnlyOnStateChange":false,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"},{"property":"trigger","propertyType":"msg","value":"","valueType":"date"}],"x":140,"y":1682,"wires":[["7c1b6bea3d464280","4bc72abf87ff6d37"]]},{"id":"e3a62e6890212c08","type":"server-state-changed","z":"5e38a40b1ab38ea9","name":"DWD-Warungen","server":"a1aba8eb.bfd618","version":5,"outputs":1,"exposeAsEntityConfig":"","entityId":"sensor.dwd_weather_warnings_808121000_current_warning_level","entityIdType":"exact","outputInitially":true,"stateType":"num","ifState":"","ifStateType":"num","ifStateOperator":"is","outputOnlyOnStateChange":false,"for":"1","forType":"num","forUnits":"seconds","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":146,"y":1470,"wires":[["6b68a9d6fd4b16ca","1bc9613086394754"]]},{"id":"286b86dc29b0d2b3","type":"api-call-service","z":"5e38a40b1ab38ea9","name":"DWD Warnung Beginn","server":"a1aba8eb.bfd618","version":5,"debugenabled":false,"domain":"notify","service":"mobile_app_iphone_harald_privat","areaId":[],"deviceId":[],"entityId":[],"data":"{\"message\":\"DWD-Warnung ab jetzt\",\"data\":{\"type\":\"announce\"}}","dataType":"json","mergeContext":"Test","mustacheAltTags":true,"outputProperties":[],"queue":"all","x":1252.857177734375,"y":1444.5714111328125,"wires":[[]]},{"id":"1aecb61b250d183c","type":"api-call-service","z":"5e38a40b1ab38ea9","name":"DWD AN","server":"a1aba8eb.bfd618","version":5,"debugenabled":false,"domain":"input_boolean","service":"turn_on","areaId":[],"deviceId":[],"entityId":["input_boolean.dwd_warnungen"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1230.857177734375,"y":1498.5714111328125,"wires":[[]]},{"id":"6bc8c5980fc2e227","type":"api-call-service","z":"5e38a40b1ab38ea9","name":"DWD Warnung Ende","server":"a1aba8eb.bfd618","version":5,"debugenabled":false,"domain":"notify","service":"mobile_app_iphone_harald_privat","areaId":[],"deviceId":[],"entityId":[],"data":"{\"message\":\"DWD-Warnung beendet\",\"data\":{\"type\":\"announce\"}}","dataType":"json","mergeContext":"Test","mustacheAltTags":true,"outputProperties":[],"queue":"all","x":768.28564453125,"y":1509.142822265625,"wires":[[]]},{"id":"8f7ae4cb752b0e62","type":"api-call-service","z":"5e38a40b1ab38ea9","name":"DWD AUS","server":"a1aba8eb.bfd618","version":5,"debugenabled":false,"domain":"input_boolean","service":"turn_off","areaId":[],"deviceId":[],"entityId":["input_boolean.dwd_warnungen"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":736.5714111328125,"y":1563.142822265625,"wires":[[]]},{"id":"178bb5445060d660","type":"function","z":"5e38a40b1ab38ea9","name":"Message","func":"let payload = {\n \"message\": \"Es liegt eine Wetterwarnung vor: \" + (msg.data.attributes.warning_1_description)}\nreturn { payload };","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1535.71435546875,"y":1496,"wires":[["cb39e3bf992fdb81"]]},{"id":"faf479f296de97d1","type":"api-current-state","z":"5e38a40b1ab38ea9","name":"DWD","server":"a1aba8eb.bfd618","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.dwd_weather_warnings_808121000_current_warning_level","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1230.857177734375,"y":1570.5714111328125,"wires":[["8e3d0fd006f1b6f9"]]},{"id":"1daad3e5871525bc","type":"function","z":"5e38a40b1ab38ea9","name":"Message","func":"let payload = {\n \"message\": \"Die Warnung beginnt: \" + (msg.payload) + \" Uhr.\"}\nreturn { payload };","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":831.4285888671875,"y":1331.142822265625,"wires":[["bd6fc7452f68b534"]]},{"id":"b716f6665d30d81f","type":"moment","z":"5e38a40b1ab38ea9","name":"Zeit formatieren","topic":"","input":"data.attributes.warning_1_start","inputType":"msg","inTz":"Europe/Berlin","adjAmount":"0","adjType":"minutes","adjDir":"add","format":"DD.MM.YYYY HH:mm","locale":"de","output":"payload","outputType":"msg","outTz":"Europe/Berlin","x":650.857177734375,"y":1331.1429443359375,"wires":[["1daad3e5871525bc"]]},{"id":"b88ef7b916081c30","type":"join","z":"5e38a40b1ab38ea9","name":"","mode":"custom","build":"string","property":"payload.message","propertyType":"msg","key":"topic","joiner":" ","joinerType":"str","accumulate":false,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":1124.5714111328125,"y":1383.7142333984375,"wires":[["4a1c096a280e5f0d"]]},{"id":"f3043e8ed07d0eb5","type":"api-current-state","z":"5e38a40b1ab38ea9","name":"Warung AUS","server":"a1aba8eb.bfd618","version":3,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_boolean.dwd_warnungen","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1002,"y":1638,"wires":[["faf479f296de97d1","286b86dc29b0d2b3","1aecb61b250d183c"],[]]},{"id":"6c4946b0883121e4","type":"api-current-state","z":"5e38a40b1ab38ea9","name":"Warung AN","server":"a1aba8eb.bfd618","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_boolean.dwd_warnungen","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":530,"y":1570,"wires":[["8f7ae4cb752b0e62","6bc8c5980fc2e227"],[]]},{"id":"bc1430f835c93119","type":"change","z":"5e38a40b1ab38ea9","name":"Text formatieren","rules":[{"t":"set","p":"payload","pt":"msg","to":"$trim($replace(payload, /\\(.*?\\)/, ''))","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":754,"y":1464,"wires":[["b88ef7b916081c30"]]},{"id":"bd6fc7452f68b534","type":"trigger","z":"5e38a40b1ab38ea9","name":"1 s","op1":"","op2":"","op1type":"nul","op2type":"pay","duration":"1","extend":true,"overrideDelay":true,"units":"s","reset":"stop","bytopic":"all","topic":"topic","outputs":1,"x":980.857177734375,"y":1330.5714111328125,"wires":[["b88ef7b916081c30"]]},{"id":"7480f49c448fbe1e","type":"function","z":"5e38a40b1ab38ea9","name":"Message","func":"let payload = {\n \"message\": \"Es liegt eine Wetterwarnung vor: \" + (msg.data.attributes.warning_2_description)}\nreturn { payload };","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":528,"y":1442,"wires":[["bc1430f835c93119"]]},{"id":"ebca405674658eca","type":"function","z":"5e38a40b1ab38ea9","name":"Message","func":"let payload = {\n \"message\": \"Es liegt eine Wetterwarnung vor: \" + (msg.data.attributes.warning_3_description)}\nreturn { payload };","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":528,"y":1482,"wires":[["bc1430f835c93119"]]},{"id":"c59384348d7de1a7","type":"function","z":"5e38a40b1ab38ea9","name":"Message","func":"let payload = {\n \"message\": \"Es liegt eine Wetterwarnung vor: \" + (msg.data.attributes.warning_4_description)}\nreturn { payload };","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":528,"y":1522,"wires":[["bc1430f835c93119"]]},{"id":"3c4d607a6e971d16","type":"function","z":"5e38a40b1ab38ea9","name":"Message","func":"let payload = {\n \"message\": \"Es liegt eine Wetterwarnung vor: \" + (msg.data.attributes.warning_2_description)}\nreturn { payload };","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":1537.9999389648438,"y":1540.000018119812,"wires":[["cb39e3bf992fdb81"]]},{"id":"4abd905a73757868","type":"function","z":"5e38a40b1ab38ea9","name":"Message","func":"let payload = {\n \"message\": \"Es liegt eine Wetterwarnung vor: \" + (msg.data.attributes.warning_3_description)}\nreturn { payload };","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":1537.9999389648438,"y":1580.000018119812,"wires":[["cb39e3bf992fdb81"]]},{"id":"51bbf82bdf91cb54","type":"function","z":"5e38a40b1ab38ea9","name":"Message","func":"let payload = {\n \"message\": \"Es liegt eine Wetterwarnung vor: \" + (msg.data.attributes.warning_4_description)}\nreturn { payload };","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":1537.9999389648438,"y":1620.000018119812,"wires":[["cb39e3bf992fdb81"]]},{"id":"cb39e3bf992fdb81","type":"change","z":"5e38a40b1ab38ea9","name":"Text formatieren","rules":[{"t":"set","p":"payload","pt":"msg","to":"$trim($replace(payload, /\\(.*?\\)/, ''))","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":1739.9999389648438,"y":1556.000018119812,"wires":[["010080c483544834"]]},{"id":"8e3d0fd006f1b6f9","type":"switch","z":"5e38a40b1ab38ea9","name":"Warnung","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"1","vt":"num"},{"t":"eq","v":"2","vt":"num"},{"t":"eq","v":"3","vt":"num"},{"t":"eq","v":"4","vt":"num"}],"checkall":"false","repair":false,"outputs":4,"x":1378,"y":1570,"wires":[["178bb5445060d660"],["3c4d607a6e971d16"],["4abd905a73757868"],["51bbf82bdf91cb54"]]},{"id":"1bc9613086394754","type":"switch","z":"5e38a40b1ab38ea9","name":"Warnung","property":"payload","propertyType":"msg","rules":[{"t":"gt","v":"0","vt":"num"}],"checkall":"false","repair":false,"outputs":1,"x":342,"y":1332,"wires":[["83abbd668e554cc6"]]},{"id":"a1aba8eb.bfd618","type":"server","name":"Home Assistant","version":5,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":30,"areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m","enableGlobalContextStore":true},{"id":"1dc2bfdd622bc8d9","type":"alexa-remote-account","name":"ALEXA","authMethod":"proxy","proxyOwnIp":"192.168.178.72","proxyPort":"3456","cookieFile":"/homeassistant/amazon.txt","refreshInterval":"3","alexaServiceHost":"layla.amazon.de","pushDispatchHost":"","amazonPage":"amazon.de","acceptLanguage":"de-DE","onKeywordInLanguage":"on","userAgent":"","autoInit":"on"}]
Damit kann ich erstmal gut leben. Muss zum vollständigen testen auf die nächste “echte” Wetterwarung warten.
