ich versuche meinen Speedport Smart 3 Router der Telekom in mein HA einzubinden.
Ich habe dazu auch in HACS eine Integration gefunden.
Allerdings bekomme ich beim starten eine Fehlermeldung:
Der Konfigurationsfluss konnte nicht geladen werden: 500 Internal Server Error Server got itself in trouble
Was könnte hier falsch laufen. Muss ich im Speedport noch etwas freigeben?
Danke für Eure Hilfe.
Debugging als Text, da ich noch keine Anhänge erstellen darf
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun home-assistant (no readiness notification)
s6-rc: info: service legacy-services successfully started
2026-01-04 18:44:03.557 WARNING (SyncWorker_0) \[homeassistant.loader\] We found a custom integration speedport which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2026-01-04 18:44:03.559 WARNING (SyncWorker_0) \[homeassistant.loader\] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2026-01-04 18:44:03.559 WARNING (SyncWorker_0) \[homeassistant.loader\] We found a custom integration speedport which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2026-01-04 18:44:03.560 WARNING (SyncWorker_0) \[homeassistant.loader\] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2026-01-04 18:44:14.046 ERROR (MainThread) \[homeassistant.config_entries\] Error setting up entry Speedport for speedport
File “/usr/src/homeassistant/homeassistant/config_entries.py”, line 761, in \__async_setup_with_context
result = await component.async_setup_entry(hass, self)
File “/config/custom_components/speedport/**init**.py”, line 42, in async_setup_entry
hass.config_entries.async_forward_entry_setup(entry, platform)
AttributeError: ‘ConfigEntries’ object has no attribute ‘async_forward_entry_setup’. Did you mean: ‘async_forward_entry_setups’?
2026-01-04 18:44:14.706 ERROR (MainThread) \[ring_doorbell.stickup_cam\] Unknown kind: cocoa_camera_v2
2026-01-04 18:44:14.706 ERROR (MainThread) \[ring_doorbell.stickup_cam\] Unknown kind: stickup_cam_mini_ptz_v1
2026-01-04 18:44:14.707 ERROR (MainThread) \[ring_doorbell.stickup_cam\] Unknown kind: cocoa_camera_v2
2026-01-04 18:44:14.708 ERROR (MainThread) \[ring_doorbell.stickup_cam\] Unknown kind: cocoa_camera_v2
2026-01-04 18:44:14.708 ERROR (MainThread) \[ring_doorbell.stickup_cam\] Unknown kind: stickup_cam_mini_ptz_v1
2026-01-04 18:44:14.709 ERROR (MainThread) \[ring_doorbell.stickup_cam\] Unknown kind: cocoa_camera_v2
2026-01-04 18:44:14.726 ERROR (MainThread) \[ring_doorbell.stickup_cam\] Unknown kind: cocoa_camera_v2
2026-01-04 18:44:14.726 ERROR (MainThread) \[ring_doorbell.stickup_cam\] Unknown kind: stickup_cam_mini_ptz_v1
2026-01-04 18:44:14.727 ERROR (MainThread) \[ring_doorbell.stickup_cam\] Unknown kind: cocoa_camera_v2
2026-01-04 18:44:14.739 ERROR (MainThread) \[ring_doorbell.stickup_cam\] Unknown kind: cocoa_camera_v2
2026-01-04 18:44:14.740 ERROR (MainThread) \[ring_doorbell.stickup_cam\] Unknown kind: stickup_cam_mini_ptz_v1
2026-01-04 18:44:14.740 ERROR (MainThread) \[ring_doorbell.stickup_cam\] Unknown kind: cocoa_camera_v2
2026-01-04 18:44:14.743 ERROR (MainThread) \[ring_doorbell.stickup_cam\] Unknown kind: cocoa_camera_v2
2026-01-04 18:44:14.743 ERROR (MainThread) \[ring_doorbell.stickup_cam\] Unknown kind: stickup_cam_mini_ptz_v1
2026-01-04 18:44:14.744 ERROR (MainThread) \[ring_doorbell.stickup_cam\] Unknown kind: cocoa_camera_v2
2026-01-04 18:44:14.744 ERROR (MainThread) \[ring_doorbell.stickup_cam\] Unknown kind: stickup_cam_mini_ptz_v1
2026-01-04 18:44:15.017 ERROR (Thread-5) \[pychromecast.socket_client\] \[32PFS6402/12(c9ce519e-2356-ea1a-5eef-21431f6671a7.local.):8009\] Failed to connect to service MDNSServiceInfo(name=‘QM164E-c9ce519e2356ea1a5eef21431f6671a7.\_googlecast.\_tcp.local.’), retrying in 5.0s
2026-01-04 18:44:16.381 WARNING (MainThread) \[custom_components.hacs\] You have ‘Andre0512/speedport’ installed with HACS this repository has been removed from HACS, please consider removing it. Removal reason (Repository has been abandoned)
2026-01-04 18:44:36.233 ERROR (MainThread) \[homeassistant.config_entries\] Error setting up entry Speedport for speedport
2026-01-04 18:44:40.443 ERROR (MainThread) \[aiohttp.server\] Error handling request from 192.168.2.145
File “/usr/local/lib/python3.13/site-packages/aiohttp/web_protocol.py”, line 510, in \_handle_request
resp = await request_handler(request)
File “/usr/local/lib/python3.13/site-packages/aiohttp/web_app.py”, line 569, in \_handle
return await handler(request)
File “/usr/local/lib/python3.13/site-packages/aiohttp/web_middlewares.py”, line 117, in impl
File “/usr/src/homeassistant/homeassistant/components/http/security_filter.py”, line 92, in security_filter_middleware
File “/usr/src/homeassistant/homeassistant/components/http/forwarded.py”, line 87, in forwarded_middleware
File “/usr/src/homeassistant/homeassistant/components/http/request_context.py”, line 26, in request_context_middleware
File “/usr/src/homeassistant/homeassistant/components/http/ban.py”, line 86, in ban_middleware
File “/usr/src/homeassistant/homeassistant/components/http/auth.py”, line 242, in auth_middleware
File “/usr/src/homeassistant/homeassistant/components/http/headers.py”, line 41, in headers_middleware
response = await handler(request)
File “/usr/src/homeassistant/homeassistant/helpers/http.py”, line 73, in handle
result = await handler(request, \*\*request.match_info)
File “/usr/src/homeassistant/homeassistant/components/http/decorators.py”, line 83, in with_admin
return await func(self, request, \*args, \*\*kwargs)
File “/usr/src/homeassistant/homeassistant/components/config/config_entries.py”, line 272, in post
return await super().post(request)
File “/usr/src/homeassistant/homeassistant/components/http/data_validator.py”, line 74, in wrapper
return await method(view, request, data, \*args, \*\*kwargs)
File “/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py”, line 76, in post
return await self.\_post_impl(request, data)
File “/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py”, line 83, in \_post_impl
result = await self.\_flow_mgr.async_init(
…<2 lines>…
File “/usr/src/homeassistant/homeassistant/data_entry_flow.py”, line 316, in async_init
flow = await self.async_create_flow(handler, context=context, data=data)
File “/usr/src/homeassistant/homeassistant/config_entries.py”, line 3682, in async_create_flow
return handler.async_get_options_flow(entry)
File “/config/custom_components/speedport/config_flow.py”, line 86, in async_get_options_flow
return OptionsFlowHandler(config_entry)
File “/config/custom_components/speedport/config_flow.py”, line 100, in **init**
self.config_entry = config_entry
AttributeError: property ‘config_entry’ of ‘OptionsFlowHandler’ object has no setter
