EcoFlowCloud - Integration lässt sich nicht installieren - 500 Internal Server Error Server
Liebe Community,
nachdem ich die EcoFlowCloud Version v1.2.0 erfolgreich heruntergeladen habe und die Integration hinzufügen möchte, bekomme ich die Fehlernachricht “Der Konfigurationsfluss konnte nicht geladen werden: 500 Internal Server Error Server got itself into trouble
Im Protokoll finde ich nach jedem Versuch den untenstehenden Eintrag. Kennt jemand eine Lösung für das Problem?
Vielen Dank im Voraus
suncase
Logger: aiohttp.server
Quelle: /usr/local/lib/python3.13/site-packages/aiohttp/web_protocol.py:451
Erstmals aufgetreten: 24. April 2025 um 23:57:03 (1 Vorkommnisse)
Zuletzt protokolliert: 24. April 2025 um 23:57:03
Error handling request from 127.0.0.1
  File "/usr/local/lib/python3.13/site-packages/aiohttp/web_protocol.py", line 480, in _handle_request
    resp = await request_handler(request)
  File "/usr/local/lib/python3.13/site-packages/aiohttp/web_app.py", line 569, in _handle
    return await handler(request)
  File "/usr/local/lib/python3.13/site-packages/aiohttp/web_middlewares.py", line 117, in impl
  File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 92, in security_filter_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 77, in forwarded_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 26, in request_context_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 86, in ban_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 242, in auth_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/headers.py", line 32, in headers_middleware
    response = await handler(request)
  File "/usr/src/homeassistant/homeassistant/helpers/http.py", line 73, in handle
    result = await handler(request, **request.match_info)
  File "/usr/src/homeassistant/homeassistant/components/http/decorators.py", line 81, in with_admin
    return await func(self, request, *args, **kwargs)
  File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 74, in wrapper
    return await method(view, request, data, *args, **kwargs)
  File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 182, in post
    return await self._post_impl(request, data)
  File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 189, in _post_impl
    return await super()._post_impl(request, data)
  File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 83, in _post_impl
    result = await self._flow_mgr.async_init(
    ...<2 lines>...
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 1455, in async_init
    flow, result = await self._async_init(flow_id, handler, context, data)
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 1480, in _async_init
    flow = await self.async_create_flow(handler, context=context, data=data)
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 1698, in async_create_flow
    handler = await _async_get_flow_handler(
        self.hass, handler_key, self._hass_config
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 3790, in _async_get_flow_handler
    await _load_integration(hass, domain, hass_config)
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 3767, in _load_integration
    await async_process_deps_reqs(hass, hass_config, integration)
  File "/usr/src/homeassistant/homeassistant/setup.py", line 581, in async_process_deps_reqs
    await requirements.async_get_integration_with_requirements(
        hass, integration.domain
  File "/usr/src/homeassistant/homeassistant/requirements.py", line 54, in async_get_integration_with_requirements
    return await manager.async_get_integration_with_requirements(domain)
  File "/usr/src/homeassistant/homeassistant/requirements.py", line 170, in async_get_integration_with_requirements
    await future
  File "/usr/src/homeassistant/homeassistant/requirements.py", line 159, in async_get_integration_with_requirements
    await self._async_process_integration(integration, done)
  File "/usr/src/homeassistant/homeassistant/requirements.py", line 182, in _async_process_integration
    await self.async_process_requirements(
        integration.domain, integration.requirements
  File "/usr/src/homeassistant/homeassistant/requirements.py", line 264, in async_process_requirements
    self._raise_for_failed_requirements(name, missing)
  File "/usr/src/homeassistant/homeassistant/requirements.py", line 292, in _raise_for_failed_requirements
    raise RequirementsNotFound(integration, [req])
homeassistant.requirements.RequirementsNotFound: Requirements for ecoflow_cloud not found: ['paho-mqtt==1.6.1'].
