Hi zusammen,
ich habe Homeassistant auf meinem Raspberry pi 4 neu installiert und versuche nun meinen Sonoff USB Dongle zu konfigurieren um Zha nutzen zu können.
Der Dongle wird erkannt aber nach dem ich im HA auf Neues Netzwerk konfigurieren klicke erscheint nur “Fehler”
Hoffe ihr könnt : /
Hier das Protokoll zum Fehler:
Protokolldetails (FEHLER)
Logger: aiohttp.server
Quelle: /usr/local/lib/python3.12/site-packages/aiohttp/web_protocol.py:421
Erstmals aufgetreten: 22:40:19 (7 Vorkommnisse)
Zuletzt protokolliert: 23:21:39
Error handling request
File “/usr/local/lib/python3.12/site-packages/zigpy_znp/api.py”, line 238, in load_network_info
await self._load_network_info(load_devices=load_devices)
File “/usr/local/lib/python3.12/site-packages/zigpy_znp/api.py”, line 105, in _load_network_info
nib = await self.nvram.osal_read(OsalNvIds.NIB, item_type=t.NIB)
File “/usr/local/lib/python3.12/site-packages/zigpy_znp/nvram.py”, line 171, in osal_read
raise KeyError(f"NV item does not exist: {nv_id!r}")
KeyError: ‘NV item does not exist: <OsalNvIds.NIB: 33>’
The above exception was the direct cause of the following exception:
File “/usr/local/lib/python3.12/site-packages/zigpy/application.py”, line 363, in form_network
await self.start_network()
File “/usr/local/lib/python3.12/site-packages/zigpy_znp/zigbee/application.py”, line 177, in start_network
await self.load_network_info()
File “/usr/local/lib/python3.12/site-packages/zigpy_znp/zigbee/application.py”, line 144, in load_network_info
await self._znp.load_network_info(load_devices=load_devices)
File “/usr/local/lib/python3.12/site-packages/zigpy_znp/api.py”, line 240, in load_network_info
raise NetworkNotFormed() from e
zigpy.exceptions.NetworkNotFormed
During handling of the above exception, another exception occurred:
File “/usr/local/lib/python3.12/site-packages/aiohttp/web_protocol.py”, line 452, in _handle_request
resp = await request_handler(request)
File “/usr/local/lib/python3.12/site-packages/aiohttp/web_app.py”, line 543, in _handle
resp = await handler(request)
File “/usr/local/lib/python3.12/site-packages/aiohttp/web_middlewares.py”, line 114, in impl
return await handler(request)
File “/usr/src/homeassistant/homeassistant/components/http/security_filter.py”, line 92, in security_filter_middleware
File “/usr/src/homeassistant/homeassistant/components/http/forwarded.py”, line 83, in forwarded_middleware
File “/usr/src/homeassistant/homeassistant/components/http/request_context.py”, line 26, in request_context_middleware
File “/usr/src/homeassistant/homeassistant/components/http/ban.py”, line 85, in ban_middleware
File “/usr/src/homeassistant/homeassistant/components/http/auth.py”, line 242, in auth_middleware
File “/usr/src/homeassistant/homeassistant/components/http/headers.py”, line 32, in headers_middleware
response = await handler(request)
File “/usr/src/homeassistant/homeassistant/helpers/http.py”, line 73, in handle
result = await handler(request, **request.match_info)
File “/usr/src/homeassistant/homeassistant/components/http/decorators.py”, line 81, in with_admin
return await func(self, request, *args, **kwargs)
File “/usr/src/homeassistant/homeassistant/components/config/config_entries.py”, line 222, in post
return await super().post(request, flow_id)
File “/usr/src/homeassistant/homeassistant/components/http/data_validator.py”, line 70, in wrapper
return await method(view, request, data, *args, **kwargs)
File “/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py”, line 122, in post
result = await self._flow_mgr.async_configure(flow_id, data)
File “/usr/src/homeassistant/homeassistant/data_entry_flow.py”, line 368, in async_configure
result = await self._async_configure(flow_id, user_input)
File “/usr/src/homeassistant/homeassistant/data_entry_flow.py”, line 410, in _async_configure
result = await self._async_handle_step(
File “/usr/src/homeassistant/homeassistant/data_entry_flow.py”, line 517, in _async_handle_step
result: _FlowResultT = await getattr(flow, method)(user_input)
File “/usr/src/homeassistant/homeassistant/components/zha/config_flow.py”, line 392, in async_step_form_initial_network
return await self.async_step_form_new_network(user_input)
File “/usr/src/homeassistant/homeassistant/components/zha/config_flow.py”, line 398, in async_step_form_new_network
await self._radio_mgr.async_form_network()
File “/usr/src/homeassistant/homeassistant/components/zha/radio_manager.py”, line 277, in async_form_network
await app.form_network()
File “/usr/local/lib/python3.12/site-packages/zigpy/application.py”, line 365, in form_network
await self.form_network(fast=True)
File “/usr/local/lib/python3.12/site-packages/zigpy/application.py”, line 418, in form_network
await self.backups.restore_backup(
File “/usr/local/lib/python3.12/site-packages/zigpy/backups.py”, line 171, in restore_backup
await self.app.write_network_info(
File “/usr/local/lib/python3.12/site-packages/zigpy_znp/zigbee/application.py”, line 171, in write_network_info
await self._znp.write_network_info(
File “/usr/local/lib/python3.12/site-packages/zigpy_znp/api.py”, line 381, in write_network_info
await self.nvram.osal_write(item, value, create=True)
File “/usr/local/lib/python3.12/site-packages/zigpy_znp/nvram.py”, line 128, in osal_write
await self.znp.request(
File “/usr/local/lib/python3.12/site-packages/zigpy_znp/api.py”, line 1068, in request
raise InvalidCommandResponse(
zigpy_znp.exceptions.InvalidCommandResponse: Expected SRSP response SYS.OSALNVItemInit.Rsp(Status=<Status.NV_ITEM_UNINIT: 9>), got SYS.OSALNVItemInit.Rsp(Status=<Status.NV_OPER_FAILED: 10>)
