Hi, zusammen, seit heute macht mein Zha Netzwerk Probleme.
Ohne das ich irgendwas geändert habe.
Kann jemand mit dem log was anfangen?
Wenn ich den Nuc komplett neu starte geht es für ca. 10 Minuten… Dann wieder das gleiche
Logger: homeassistant.config_entries
Source: components/zha/core/gateway.py:205
First occurred: 14:56:39 (1 occurrences)
Last logged: 14:56:39
Error setting up entry SONOFF Zigbee 3.0 USB Dongle Plus V2 for zha
File “/usr/local/lib/python3.10/site-packages/serial/serialposix.py”, line 322, in open
self.fd = os.open(self.portstr, os.O_RDWR | os.O_NOCTTY | os.O_NONBLOCK)
FileNotFoundError: [Errno 2] No such file or directory: ‘/dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20221210194016-if00’
During handling of the above exception, another exception occurred:
File “/usr/src/homeassistant/homeassistant/config_entries.py”, line 383, in async_setup
result = await component.async_setup_entry(hass, self)
File “/usr/src/homeassistant/homeassistant/components/zha/init.py”, line 122, in async_setup_entry
await zha_gateway.async_initialize()
File “/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py”, line 220, in async_initialize
raise exc
File “/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py”, line 205, in async_initialize
self.application_controller = await app_controller_cls.new(
File “/usr/local/lib/python3.10/site-packages/zigpy/application.py”, line 216, in new
await app.startup(auto_form=auto_form)
File “/usr/local/lib/python3.10/site-packages/zigpy/application.py”, line 190, in startup
await self.connect()
File “/usr/local/lib/python3.10/site-packages/bellows/zigbee/application.py”, line 130, in connect
self._ezsp = await bellows.ezsp.EZSP.initialize(self.config)
File “/usr/local/lib/python3.10/site-packages/bellows/ezsp/init.py”, line 109, in initialize
await ezsp.connect(use_thread=zigpy_config[conf.CONF_USE_THREAD])
File “/usr/local/lib/python3.10/site-packages/bellows/ezsp/init.py”, line 126, in connect
self._gw = await bellows.uart.connect(self._config, self, use_thread=use_thread)
File “/usr/local/lib/python3.10/site-packages/bellows/uart.py”, line 406, in connect
protocol, connection_done = await thread.run_coroutine_threadsafe(
File “/usr/local/lib/python3.10/site-packages/bellows/uart.py”, line 385, in _connect
transport, protocol = await zigpy.serial.create_serial_connection(
File “/usr/local/lib/python3.10/site-packages/zigpy/serial.py”, line 37, in create_serial_connection
transport, protocol = await pyserial_asyncio.create_serial_connection(
File “/usr/local/lib/python3.10/site-packages/serial_asyncio/init.py”, line 448, in create_serial_connection
serial_instance = serial.serial_for_url(*args, **kwargs)
File “/usr/local/lib/python3.10/site-packages/serial/init.py”, line 90, in serial_for_url
instance.open()
File “/usr/local/lib/python3.10/site-packages/serial/serialposix.py”, line 325, in open
raise SerialException(msg.errno, “could not open port {}: {}”.format(self._port, msg))
serial.serialutil.SerialException: [Errno 2] could not open port /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20221210194016-if00: [Errno 2] No such file or directory: ‘/dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20221210194016-if00’
