ich habe den SLZB-MRW10 und habe auch gerade den Updatehinweis bekommen auf die Version 3.1.0 mit folgenden Hinweis.
Release notes:
BREAKING CHANGES
Zigbee Hub Users: You may have to re-pair all your devises after this update due to core changes in the Zigbee stack and API. Please use this repair guide: Troubleshooting -
MQTT Broker Format Changed:-
Old format: ‘
mqtt://example.com’ -
New format: ‘
example.com’ (or, IP format: ‘127.0.0.1’)
You can now use DNS and DDNS hostnames for your MQTT broker.
Updated MQTT API for Zigbee Hub: View the new MQTT API documentation
Zigbee Hub Improvements
Redesigned Zigbee Hub network startup - now significantly faster -
Hub now responds to Time attribute and Identify queries -
Fixed: Some Zigbee devices not sending reports in Hub mode -
Fixed: Zigbee Hub mistakenly available for EFR32 on MRx devices
MQTT & DDNS Enhancements
MQTT Broker now accepts plain domain names, not only IP addresses -
“IP Provider” setting for DDNS is now optional -
Fixed DDNS update interval and max value behavior -
Fixed excessive DNS requests from NTP client
Performance & System Stability
Increased socket task priority for better responsiveness -
Moved secondary tasks on U series to PSRAM for improved memory usage -
Improved Thread stability for U series devices -
Enhanced EFR32x bootloader activation routine -
Improved USB power switch logic on U series -
Fixed second radio status display in web interface header
Berry Script Engine (zHub)
Improved support for sendTuyaData() -
Fixed readAttr()arguments parsing
Hat jemand das Update schon probiert und musste alle Geräte neu anlernen?
Danke
Jens
