Und das hier
File "/usr/local/lib/python3.14/site-packages/aiohttp/_websocket/writer.py", line 151, in _write_websocket_frame
raise ClientConnectionResetError("Cannot write to closing transport")
aiohttp.client_exceptions.ClientConnectionResetError: Cannot write to closing transport
2026-06-13 18:48:31.487 WARNING (SyncWorker_5) [py.warnings] /usr/local/lib/python3.14/site-packages/rich/segment.py:547: SyntaxWarning: ‘return’ in a ‘finally’ block
return
2026-06-13 18:48:52.662 ERROR (MainThread) [homeassistant] Error doing job: Unclosed client session (task: None)
2026-06-13 18:48:52.673 ERROR (MainThread) [homeassistant] Error doing job: Unclosed client session (task: None)
2026-06-13 19:00:31.708 WARNING (MainThread) [pysma.sma_webconnect] Request to /dyn/login.json did not return a valid json.
2026-06-13 19:00:31.709 ERROR (MainThread) [pysma.sma_webconnect] Could not start session: Session ID expected [result.sid]
2026-06-14 08:48:07.123 WARNING (MainThread) [pysmaplus.discovery] Sending Discovery Request
2026-06-14 08:48:07.626 WARNING (MainThread) [pysmaplus.discovery] Sending Discovery Request
2026-06-14 08:48:08.128 WARNING (MainThread) [pysmaplus.discovery] Sending Discovery Request
2026-06-14 08:48:08.630 WARNING (MainThread) [pysmaplus.discovery] Sending Discovery Request
2026-06-14 08:48:09.144 WARNING (MainThread) [pymodbus.logging] Failed to connect [Errno 111] Connect call failed (‘192.168.178.162’, 502)
2026-06-14 08:48:09.222 WARNING (MainThread) [pysmaplus.device_webconnect] Request to /dyn/login.json did not return a valid json.
2026-06-14 08:48:09.222 ERROR (MainThread) [pysmaplus.device_webconnect] Could not start session: Session ID expected [result.sid]
2026-06-14 08:48:13.099 ERROR (MainThread) [aiohttp.server] Error handling request from 192.168.178.146
