Ja, leider! Ich habe die Berechnung und das Abspeichern nun auch in den eigenen Code verschoben und als Speicherort die SFML DB und HA Recorder nur als sekundäre Quelle
ich hohle mal ein Thema aus der Versenkung. (MDC)
- INFO - Reason: Deviation below threshold (0.63 kWh < 0.42 kWh)
das hatte ich heute mal wieder.
2026-07-06 12:30:00 - custom_components.solar_forecast_ml.production.production_adaptive_forecast - INFO - === Adaptive Forecast Check ===
2026-07-06 12:30:00 - custom_components.solar_forecast_ml.production.production_adaptive_forecast - INFO - Time: 12:30:00
2026-07-06 12:30:00 - custom_components.solar_forecast_ml.production.production_adaptive_forecast - INFO - Collecting analysis data...
2026-07-06 12:30:00 - custom_components.solar_forecast_ml.production.production_adaptive_forecast - INFO - Morning analysis (05:40-12:30): Actual=2.46 kWh, Predicted=1.84 kWh, Deviation=+34% (+0.63 kWh)
2026-07-06 12:30:00 - custom_components.solar_forecast_ml.production.production_adaptive_forecast - INFO - Criterion 1: Daily forecast=4.23 kWh, Dynamic threshold=0.42 kWh, Deviation=0.63 kWh
2026-07-06 12:30:00 - custom_components.solar_forecast_ml.production.production_adaptive_forecast - INFO - == Result: NO CORRECTION ==
2026-07-06 12:30:00 - custom_components.solar_forecast_ml.production.production_adaptive_forecast - INFO - Reason: Deviation below threshold (0.63 kWh < 0.42 kWh)
und auf dem Pi auch.
2026-07-06 12:30:00 - custom_components.solar_forecast_ml.production.production_adaptive_forecast - INFO - Morning analysis (05:40-12:30): Actual=2.46 kWh, Predicted=1.89 kWh, Deviation=+30% (+0.57 kWh)
2026-07-06 12:30:00 - custom_components.solar_forecast_ml.production.production_adaptive_forecast - INFO - Criterion 1: Daily forecast=4.12 kWh, Dynamic threshold=0.41 kWh, Deviation=0.57 kWh
2026-07-06 12:30:00 - custom_components.solar_forecast_ml.production.production_adaptive_forecast - INFO - Reason: Deviation below threshold (0.57 kWh < 0.41 kWh)
Grüße
Hallo @Kaysen899
und was ist nun die Frage oder das vermutete Problem?
Zara
naja, Mathematisch ist (0.63 kWh < 0.42 kWh) nicht korrekt!
Theoretisch müsste MDC auslösen.
Hab ich im Februar auch schon mal gemeldet, BUG-TRACKER Solar Forecast ML - #14 von pmcl ich habe es dann aber aus den Augen verloren, weil man es ja eben nicht täglich beobachten kann. Tom hatte damals dazu geschrieben, es sei (damals) im Release gefixt.
das habe ich auch gelesen, deshalb
Achso.. :slight_smile: Nein alles in Ordnung! Ich verstehe deine Verwirrung, du liest es als Mathematische Formel, das ist aber falsch es ist eine verkürzte Darstellung. Es sagt nur warum die MDC nicht ausgelöst wurde: 34% mehr Produktion ist unterhalb der Schwelle.
kein BUG
Hätte er dann nicht bei mir augelöst werden sollen?
2026-07-06 12:30:00 - custom_components.solar_forecast_ml.production.production_adaptive_forecast - INFO - Morning analysis (05:40-12:30): Actual=2.60 kWh, Predicted=1.50 kWh, Deviation=+73% (+1.10 kWh)
2026-07-06 12:30:00 - custom_components.solar_forecast_ml.production.production_adaptive_forecast - INFO - Criterion 1: Daily forecast=4.62 kWh, Dynamic threshold=0.46 kWh, Deviation=1.10 kWh
2026-07-06 12:30:00 - custom_components.solar_forecast_ml.production.production_adaptive_forecast - INFO - Criterion 2 (No special situation): MET
2026-07-06 12:30:00 - custom_components.solar_forecast_ml.production.production_adaptive_forecast - INFO - Criterion 3 (>= 3h until sunset): MET (9.0h)
2026-07-06 12:30:00 - custom_components.solar_forecast_ml.production.production_adaptive_forecast - DEBUG - Weather data freshness: last_updated=2026-07-06T10:00:01+02:00, age=2.5h, fresh=True
2026-07-06 12:30:00 - custom_components.solar_forecast_ml.production.production_adaptive_forecast - INFO - Criterion 4 (Fresh weather data): MET (06:00 UTC)
2026-07-06 12:30:00 - custom_components.solar_forecast_ml.production.production_adaptive_forecast - INFO - Criterion 5 (Cloud cover diff > 25pp): NOT MET - Morning=58%, Current=54% (-4pp)
2026-07-06 12:30:00 - custom_components.solar_forecast_ml.production.production_adaptive_forecast - INFO - Reason: Weather data nearly unchanged (Diff: -4pp)
nein, die Himmelsverdeckung hat sich nicht um 25p geändert.
Danke für die INFO
Gruss
Installation SFML 32.1.2: Vorgang lief ohne Fehlermeldungen durch.
HACS: Keine Probleme beim Download via HACS.
Schwierigkeiten: Keine spezifischen Probleme, mit dem Update.
Edit: Ist das so richtig, dass der P10 nach dem Update auf 32.1.2 nicht mehr angezeigt wird?
@harix
vielen Dank für deine Nachricht! Ich habe vergessen darauf hinzuweisen, dass der Sensor erst nach dem nächsten Prognoselauf aktiv wird :frowning:
Ich habe eine Frage zur Ermittlung der Stromkosten. Meiner Meinung nach, ist die Berechnung falsch, oder ich irre mich :thinking:
In meinem Beispiel dürfte ich nur Kosten in Höhe von 2 kw x 0,3457€ = 0,6914€ haben
keine Grundgebühr?
Du kannst nach links ziehen und jeden Monat einzeln anpassen.
ggf. am PC bearbeiten.
Hier stimmt es.
Das habe ich angepasst! Keine Grundgebühr deswegen, weil sie bei mir auch in die Ersparnis eingerechnet wird. Grundgebühr habe ich auch ohne PV, ist also keine Ersparnis.
die wird in die Ersparnis eingerechnet? das macht ja gar keinen Sinn…das muss ich mal bei mir prüfen…
Grundgebühr bzw. Zählergebühr ist ja immer da, egal was du Verbrauchst oder Einspeist
also bei mir wird der nicht eingerechnet.
Eher, zu Wenig berechnet.
Hmm..
die Berechnun ist tatsächlich verwirrend:
Aus der Zeile ergibt sich, dass ich 28kWh zu 29,65 Cent bezogen habe, ergo: 8,30€ Stromkosten, dazu hab ich im Monat eine Grundgebühr von 9,74€
Die wird offenbar anteilig der Tage die im Monat vergangen sind berechnet.
Sieht man auch wenn man auf “Preis ändern” geht.
Meinen erachtens ist das eine Monatsgebühr die ab der ersten Sekunde des Abrechnungsmonats fällig wird. sollte also nicht anteilig berechnet werden.
Außerdem gibts irgendwie ein Delta des Strompreises:
8,15€ vs. 8,30€ (28*0,2965€)
ich vermute aber das könnte an ner ungünstigen Rundung liegen, vielleicht sollte man den genauen kWh Wert bei “Mousover” als Popup anzeigen
Hallo @Kaysen899
sehe ich das richtig, das ich nur den Arbeitspreis anpassen kann, den Grundpreis aber nicht?
Habe ab Mai auf einen höheren Grundpreis geändert, das wirkt sich rückwirkend auf alle Monate aus.
