Ah ok das hat damit zu tuen. Hatte das so verstanden das jetzt in Zunkunft einfach die Samples weiter steigen können, aber nicht das es so einen Sprung direkt macht​:+1:t2:
Update fehlerfrei durchgelaufen.
HA auf Proxmox, 3 Panel Flächen, EoD: 1:37 Minuten., ca. 212 Samples
Virtualisierte HA-Installation auf einem Windows-Host, NucI3, EOD 4:24, 205 samples, 4 Panel Gruppen
HA OS auf Intel NUC
Gestern nachmittags das aktuelle update eingespielt und heute habe ich noch immer DB locked
2026-03-01 06:10:00 - custom_components.solar_forecast_ml.production.production_morning_routine - INFO -   MORNING ROUTINE EXECUTION - Attempt 1/3 for 2026-03-01
2026-03-01 06:10:00 - custom_components.solar_forecast_ml.production.production_morning_routine - INFO - ================================================================================
2026-03-01 06:10:00 - custom_components.solar_forecast_ml.production.production_morning_routine - INFO - → Step 1/5: Validating prerequisites...
2026-03-01 06:10:00 - custom_components.solar_forecast_ml.production.production_morning_routine - DEBUG - All prerequisites validated
2026-03-01 06:10:00 - custom_components.solar_forecast_ml.production.production_morning_routine - INFO -   ✓ Prerequisites validated: 72 forecast hours, 72 weather hours
2026-03-01 06:10:00 - custom_components.solar_forecast_ml.production.production_morning_routine - INFO - → Step 2/5: Creating hourly predictions in database...
2026-03-01 06:10:00 - custom_components.solar_forecast_ml.production.production_morning_routine - INFO -   ├─ Checking and unlocking existing forecast locks...
2026-03-01 06:10:00 - custom_components.solar_forecast_ml.production.production_morning_routine - INFO -   │  🔓 Found 24 existing predictions - will update
2026-03-01 06:10:00 - custom_components.solar_forecast_ml.production.production_morning_routine - INFO -   │  🔓 Unlocking daily_forecast (was locked at 2026-03-01 00:30:00.719904+01:00 by morning_routine)
2026-03-01 06:10:00 - custom_components.solar_forecast_ml.production.production_morning_routine - INFO -   ├─ Preparing to update predictions for 3 days...
2026-03-01 06:10:00 - custom_components.solar_forecast_ml.production.production_morning_routine - INFO -   │  Preserved 2 hourly actuals, 0 group actuals before re-creation
2026-03-01 06:10:00 - custom_components.solar_forecast_ml.production.production_morning_routine - INFO -   │  Cleared 72 existing prediction slots for update
2026-03-01 06:10:00 - custom_components.solar_forecast_ml.production.production_morning_routine - INFO -   ├─ Processing 72 input forecast entries (3 days)...
2026-03-01 06:10:02 - custom_components.solar_forecast_ml.data.db_manager - WARNING - DB locked (attempt 1/5), retrying in 0.29s: database is locked
2026-03-01 06:10:02 - custom_components.solar_forecast_ml.data.db_manager - WARNING - DB locked (attempt 2/5), retrying in 0.68s: database is locked
2026-03-01 06:10:03 - custom_components.solar_forecast_ml.data.db_manager - WARNING - DB locked (attempt 3/5), retrying in 1.87s: database is locked
2026-03-01 06:10:05 - custom_components.solar_forecast_ml.data.db_manager - WARNING - DB locked (attempt 4/5), retrying in 5.01s: database is locked
2026-03-01 06:10:10 - custom_components.solar_forecast_ml.data.db_manager - WARNING - DB locked (attempt 5/5), retrying in 5.06s: database is locked
2026-03-01 06:10:15 - custom_components.solar_forecast_ml.data.db_manager - ERROR - DB locked after 5 retries, giving up: database is locked
2026-03-01 06:10:15 - custom_components.solar_forecast_ml.production.production_morning_routine - ERROR - Morning routine attempt 1/3 FAILED: database is locked
  File "<frozen production_morning_routine>", line 105, in execute_morning_routine_with_retry
  File "<frozen production_morning_routine>", line 394, in _create_daily_predictions
  File "<frozen db_manager>", line 4380, in execute
  File "<frozen db_manager>", line 4348, in _retry_on_locked
  File "<frozen db_manager>", line 4374, in _do
  File "/usr/local/lib/python3.13/site-packages/aiosqlite/core.py", line 183, in execute
    cursor = await self._execute(self._conn.execute, sql, parameters)
  File "/usr/local/lib/python3.13/site-packages/aiosqlite/core.py", line 122, in _execute
    return await future
  File "/usr/local/lib/python3.13/site-packages/aiosqlite/core.py", line 105, in run
    result = function()
sqlite3.OperationalError: database is locked
2026-03-01 06:10:15 - custom_components.solar_forecast_ml.production.production_morning_routine - INFO - Waiting 60s before retry 2...
2026-03-01 06:10:30 - custom_components.solar_forecast_ml.data.db_manager - WARNING - DB locked (attempt 1/5), retrying in 0.26s: database is locked
2026-03-01 06:10:30 - custom_components.solar_forecast_ml.data.db_manager - WARNING - DB locked (attempt 2/5), retrying in 0.69s: database is locked
2026-03-01 06:10:31 - custom_components.solar_forecast_ml.data.db_manager - WARNING - DB locked (attempt 3/5), retrying in 1.89s: database is locked
2026-03-01 06:10:33 - custom_components.solar_forecast_ml.data.db_manager - WARNING - DB locked (attempt 4/5), retrying in 5.08s: database is locked
2026-03-01 06:10:38 - custom_components.solar_forecast_ml.data.db_manager - WARNING - DB locked (attempt 5/5), retrying in 5.07s: database is locked
2026-03-01 06:10:43 - custom_components.solar_forecast_ml.data.db_manager - ERROR - DB locked after 5 retries, giving up: database is locked
2026-03-01 06:10:43 - custom_components.solar_forecast_ml.production.production_tracker - ERROR - Failed to save persistent production time state: database is locked
2026-03-01 06:11:00 - custom_components.solar_forecast_ml.data.db_manager - WARNING - DB locked (attempt 1/5), retrying in 0.25s: database is locked
2026-03-01 06:11:00 - custom_components.solar_forecast_ml.data.db_manager - WARNING - DB locked (attempt 2/5), retrying in 0.69s: database is locked
2026-03-01 06:11:01 - custom_components.solar_forecast_ml.data.db_manager - WARNING - DB locked (attempt 3/5), retrying in 1.84s: database is locked
2026-03-01 06:11:03 - custom_components.solar_forecast_ml.data.db_manager - WARNING - DB locked (attempt 4/5), retrying in 5.06s: database is locked
2026-03-01 06:11:08 - custom_components.solar_forecast_ml.data.db_manager - WARNING - DB locked (attempt 5/5), retrying in 5.04s: database is locked
2026-03-01 06:11:13 - custom_components.solar_forecast_ml.data.db_manager - ERROR - DB locked after 5 retries, giving up: database is locked
2026-03-01 06:11:13 - custom_components.solar_forecast_ml.production.production_tracker - ERROR - Failed to save persistent production time state: database is locke
Ja nach dem Update habe ich auch 2 rote Neustarts durchgeführt
Ja und die Frostmeldung ist auch eher komisch. Hatten gestern 18 Grad plus
Was läuft hier bei mir schief?
Danke Helmut
EOD auf dem „Green“ knapp 2 Std.
Allerdings von 274 Samples auf 528 Samples hoch.
Kein dB locked und soweit auch keine Fehlermeldungen. Lief anscheinend durch.
Mal schauen wie gut dann heute Abend der „normale EOD“ läuft.
Ansonsten muss ich doch mal auf potentere Hardware wechseln. Dann könnt ich auch STATS wieder nutzen.
@Tom-HA und alle andern
Können wir bitte versuchen, den Thread für Updates und Release Notes offen zu lassen und alles andere in ein Extra Thread zu schreiben?
EOD zeiten Thread
Rückmeldungen zum Update Thread oder ggf. zu jeden Release einen neuen Thread auf machen, analog zu dem HA Release Thread hier im Forum?
Sonst geht die Übersicht so schnell kaputt wie im alten Mega Thread
6 „Gefällt mir“
System: HAOS auf PROXMOX, Xeon 2176,32GB
1 Panel Gruppe
EOD problemlos durchgelaufen, keine DB Locks
EOD etwas länger wegen 107 Epochen und 377 samples, Laufzeit 382s
Sind die Anzahl samples angestiegen wegen der erweiterung von >30Tagen oder weil die bisher verworfenen outlier mit aufgenommen wurden?
Habe im Log auch drei “clamping outlier”, ich sieht so aus also würde das funktionieren, dass die ergebnisse der Std nicht total verworfen werden sondern nur partiell zum lernen herangezogen werden. Sollte also passen!
Danke!
Das gehört hier nicht her:
https://community.simon42.com/t/update-relase-notes-solar-forecast-ml/79860/33?u=tom-ha
https://community.simon42.com/t/update-relase-notes-solar-forecast-ml/79860/32?u=tom-ha
https://community.simon42.com/t/update-relase-notes-solar-forecast-ml/79860/20?u=tom-ha
https://community.simon42.com/t/update-relase-notes-solar-forecast-ml/79860/21?u=tom-ha
https://community.simon42.com/t/update-relase-notes-solar-forecast-ml/79860/36?u=tom-ha
Das gehört alles in SFML BUG-Tracker in dem dort vorgesehenen Formart - Im Übrigen wurde im BUG-Tracker zu dem Thema bereits sehr ausführlich etwas gesagt.
@Kaysen899
Prinzipiell eine Gute Idee.. .aber ich kann leider nicht xy Threads verfolgen :slight_smile:
Also bitte alle hier zitierten löscht bitte euren Post - schaut bitte in den BUG-Tracker ob es dort schon behandelt wurde und wenn nicht erstellt bitte dort eine Fehlermeldung.. ich verliere sonst die Übersicht und ALLE euer Beobachtungen sind wichtig und wertvoll… es wäre Schade wenn sie einfach untergehen..
Danke
BTW:
Leute, haltet doch bitte den Thread sauber für relevante Informationen wie @Kaysen899 und @Tom-HA es 3 Beiträge weiter oben schon mal geschrieben hatten!
Wenn ihr Rückmeldungen zu BUGs habt, nehmt die entsprechenden Threads mit dem von Tom vorgegebenen Format, wenn es allgemeine Sachen sind, könnt ihr das doch auch in den großen Thread posten.
DANKE!
3 „Gefällt mir“
also heißt es jetzt Abwarten. Und die die sich trauen schon auf ein 2026.3.0 gehen, testen das Update aus. :+1:
Ich werde das Update auf meinem Testsystem auf jeden fall nutzen, aber auf dem Live System warte ich ab. Bis ggf. 2026.3.2/3
Da auch das auslesen vom WR über eine Custom Integration hängt und diese noch nicht geupdated wurde?!
Ich warte auf jeden Fall 2026.3.3 ab.
Testsystem habe ich momentan keines.
Gruss
Kann ich denn nun Version 18.0.0 installieren auf 2026.2.3? Das wird mir von HACS bei erneut herunterladen, angeboten.
Updates auf HA 2026.3 und SFML 18.0.0 gemacht, auf den ersten Blick ohne Fehler.
Bloß nicht vorab mit HA 2026.2.3 installieren. Habe ich versehentlich wegen hacs Anzeige gemacht. Danach wurde die Integration Solar forecast ML nicht mehr geladen. Ich habe daraufhin das letzte Release wieder eingespielt. Nochmals gut gegangen. War aber mein Fehler :see_no_evil_monkey:
3 „Gefällt mir“
No risk, no fun …
Update läuft!
2026.3 update hat prima funktioniert!
Aber jetzt dies: erneut herunterladen geht nicht.
Meinen Laptop musste ich manuell neu starten, weil keine Verbindung aufgebaut werden konnte.
Was jetzt noch?
Update 26.3.0 hat ohne Probleme funktioniert
Update SFML auf 18.0.0 auch ohne Probleme
Mehr hab ich von dem Set nicht aktiviert
bei mir stand direkt nach dem Update auf 2026.3 auch “STATS nicht geladen”. Nach dem Update auf 18.0.0 hab ich den ganzen HA nochmal (nach der Anleitung von @klausn für Proxmox) neu gestartet. Weather Fusion AI hab ich allerdings nicht.
Ok, jetzt noch mal System Neustart - roter Button - nichts geht mehr! Tod!
Irgendjemand ne Idee was zu tun ist?
Ich kann ebenfalls bestätigen, dass Weather Fusion AI nach dem Update nicht mehr startet. Habe es in verschiedenen Konstellationen getestet.
Laut Log liegts an Python - falsche Version… Passt also dazu.
Muss sich Tom glaube ich nochmals anschauen
