Proxmox Fritzbox
Hallo Freunde, Ich habe mir auf der Fritzbox zur Sicherung ein Laufwerk angelegt diesen auch in Proxmox eingetragen. Ein paar Tage hat das wunderbar funktioniert. Seit gestern plötzlich diese Fehlermeldung.
INFO: starting new backup job: vzdump 100 101 102 103 --mode snapshot --prune-backups 'keep-last=3' --compress zstd --notes-template '{{guestname}}' --quiet 1 --fleecing 0 --storage Unraid
INFO: Starting Backup of VM 100 (qemu)
INFO: Backup started at 2025-04-24 00:00:02
INFO: status = running
INFO: VM Name: haos12.3
INFO: include disk 'scsi0' 'local-lvm:vm-100-disk-1' 32G
INFO: include disk 'efidisk0' 'local-lvm:vm-100-disk-0' 4M
INFO: backup mode: snapshot
INFO: ionice priority: 7
ERROR: Backup of VM 100 failed - unable to open '/mnt/pve/Unraid/dump/vzdump-qemu-100-2025_04_24-00_00_01.tmp/qemu-server.conf' - Stale file handle
INFO: Failed at 2025-04-24 00:00:02
INFO: filesystem type on dumpdir is 'cifs' -using /var/tmp/vzdumptmp3749672_101 for temporary files
INFO: Starting Backup of VM 101 (lxc)
INFO: CT Name: iobroker
INFO: including mount point rootfs ('/') in backup
INFO: create storage snapshot 'vzdump'
  WARNING: You have not turned on protection against thin pools running out of space.
  WARNING: Set activation/thin_pool_autoextend_threshold below 100 to trigger automatic extension of thin pools before they get full.
  Logical volume "snap_vm-101-disk-0_vzdump" created.
  WARNING: Sum of all thin volume sizes (8.58 TiB) exceeds the size of thin pool pve/data and the size of whole volume group (<464.76 GiB).
INFO: creating vzdump archive '/mnt/pve/Unraid/dump/vzdump-lxc-101-2025_04_24-00_00_02.tar.zst'
INFO: Total bytes written: 12038881280 (12GiB, 38MiB/s)
INFO: archive file size: 4.23GB
INFO: adding notes to backup
INFO: prune older backups with retention: keep-last=3
INFO: cleanup temporary 'vzdump' snapshot
  Logical volume "snap_vm-101-disk-0_vzdump" successfully removed.
ERROR: Backup of VM 101 failed - file '/mnt/pve/Unraid/dump/vzdump-lxc-101-2025_04_14-00_00_04.tar.zst.notes' exists but open for reading failed - Stale file handle
INFO: Failed at 2025-04-24 00:05:07
INFO: filesystem type on dumpdir is 'cifs' -using /var/tmp/vzdumptmp3749672_102 for temporary files
INFO: Starting Backup of VM 102 (lxc)
INFO: Backup started at 2025-04-24 00:05:07
INFO: CT Name: influxdb
  Logical volume "snap_vm-102-disk-0_vzdump" created.
  WARNING: Sum of all thin volume sizes (8.59 TiB) exceeds the size of thin pool pve/data and the size of whole volume group (<464.76 GiB).
INFO: creating vzdump archive '/mnt/pve/Unraid/dump/vzdump-lxc-102-2025_04_24-00_05_07.tar.zst'
INFO: Total bytes written: 4486932480 (4.2GiB, 105MiB/s)
INFO: archive file size: 645MB
  Logical volume "snap_vm-102-disk-0_vzdump" successfully removed.
ERROR: Backup of VM 102 failed - file '/mnt/pve/Unraid/dump/vzdump-lxc-102-2025_04_14-00_04_54.tar.zst.notes' exists but open for reading failed - Stale file handle
INFO: Failed at 2025-04-24 00:05:49
INFO: filesystem type on dumpdir is 'cifs' -using /var/tmp/vzdumptmp3749672_103 for temporary files
INFO: Starting Backup of VM 103 (lxc)
INFO: Backup started at 2025-04-24 00:05:49
INFO: CT Name: grafana
  Logical volume "snap_vm-103-disk-0_vzdump" created.
  WARNING: Sum of all thin volume sizes (12.60 TiB) exceeds the size of thin pool pve/data and the size of whole volume group (<464.76 GiB).
INFO: creating vzdump archive '/mnt/pve/Unraid/dump/vzdump-lxc-103-2025_04_24-00_05_49.tar.zst'
INFO: Total bytes written: 2132879360 (2.0GiB, 38MiB/s)
INFO: archive file size: 941MB
  Logical volume "snap_vm-103-disk-0_vzdump" successfully removed.
ERROR: Backup of VM 103 failed - file '/mnt/pve/Unraid/dump/vzdump-lxc-103-2025_04_14-00_05_33.tar.zst.notes' exists but open for reading failed - Stale file handle
INFO: Failed at 2025-04-24 00:06:45
INFO: Backup job finished with errors
INFO: notified via target `mail-to-root`
TASK ERROR: job errors
Wer kann helfen woran das liegt?
Gruß OSR
Ich bin kein Freund der Methode “SNAPSHOT”, gerade wenn Datenbanken involviert sind. Ich nutze als Backup generell die Methode “STOP” beim Backup.
Und wieso Fritzbox? Ich sehe nur UNRAID, oder bin mit Blindheit geschlagen.
Moin
Ne bist Du nicht. :grin: Wenn man als Storage Ziel /mnt/pve/Unraid/dump... nimmt dann wird das auch nichts.
@ostseereiter Überprüf mal was Du bei der VM100 hier für ein Ziel für das Backup ausgewählt hast, sofern Du bei Dir mehrere Storage als mögliche Backup-Ziele eingebunden haben solltest.
Proxmox_Backup_Ziel
Na der Fritzpfad ist fritz.nas/BACKUP/UNRAID
Hier noch die Einstellungen in Proxmox
Das ist dennoch recht verwirrend für mich. Wenn du UNRAID hast, warum sicherst du nicht dort und schiebst dann vom UNRAID die Sicherung auf die Festplatte der Fritzbox, wir das rechtliche Backup deiner UNRAID Daten oder Config?
Vielleicht hat Proxmox aber auch ein Problem mit dem Share und dem Punkt zwischen FRITZ und NAS???
Das kann ich natürlich mit der Hand verschieben kein Ding. so wäre es halt automatisiert. das kuriose daran ist es hat ja auch ein paar Tage funktioniert.
Dann einfach mit von Methode SNAPSHOT auf STOP umstellen. Was passiert beim manuellen Anschieben des Backups.
Ich habe gerade das Storage gelöscht nochmal ein neues Storage angelegt es ist zwar schon sichtbar aber in Proxmox noch nicht aus wählbar. werde dann nochmal schauen.
Habe jetzt manuell angestoßen und hat funktioniert
INFO: starting new backup job: vzdump 102 --node pve --notification-mode auto --storage Taeglich --mode snapshot --compress zstd --remove 0 --notes-template '{{guestname}}'
INFO: filesystem type on dumpdir is 'cifs' -using /var/tmp/vzdumptmp4013919_102 for temporary files
INFO: Backup started at 2025-04-24 13:41:36
INFO: creating vzdump archive '/mnt/pve/Taeglich/dump/vzdump-lxc-102-2025_04_24-13_41_36.tar.zst'
INFO: Total bytes written: 4574330880 (4.3GiB, 115MiB/s)
INFO: archive file size: 655MB
INFO: Finished Backup of VM 102 (00:00:39)
INFO: Backup finished at 2025-04-24 13:42:15
INFO: Backup job finished successfully
TASK OK
Naja auf die Idee eine Storage-Einbindung eines Verzeichnisses auf einer FB dann unter Proxmox UNRAID zu nennen muss man natürlich auch erst einmal kommen. :laughing:
Was da jetzt bei Dir das genaue Problem ist - bzw. jetzt war - kann ich Dir auch nicht sagen. Bei mir funktioniert das problemlos. Allerdings nutze ich eine USB WD HDD an der FB dafür.
@anon80162771 Der Share-Name “FRITZ.NAS” ist so schon korrekt und für/mit Proxmox kein Problem.
Ich werde es nochmal alles neu anlegen.
Alles nochmal neu angelegt es funktioniert nicht das Backup wird nicht auf der Fritzbox gespeichert
Hier nochmal meine Einstellungen.
Hier noch mal der die Errormeldung im Log.
INFO: starting new backup job: vzdump 100 101 102 103 --mode snapshot --quiet 1 --notes-template '{{guestname}}' --compress zstd --storage neuerserver --fleecing 0
INFO: Backup started at 2025-04-27 01:00:03
ERROR: Backup of VM 100 failed - unable to open '/mnt/pve/neuerserver/dump/vzdump-qemu-100-2025_04_27-01_00_02.tmp/qemu-server.conf' - Stale file handle
INFO: Failed at 2025-04-27 01:00:03
INFO: filesystem type on dumpdir is 'cifs' -using /var/tmp/vzdumptmp1043654_101 for temporary files
INFO: creating vzdump archive '/mnt/pve/neuerserver/dump/vzdump-lxc-101-2025_04_27-01_00_03.tar.zst'
INFO: Total bytes written: 12068382720 (12GiB, 39MiB/s)
INFO: archive file size: 4.27GB
INFO: prune older backups with retention: keep-last=7
ERROR: Backup of VM 101 failed - file '/mnt/pve/neuerserver/dump/vzdump-lxc-101-2025_04_15-00_00_05.tar.zst.notes' exists but open for reading failed - Stale file handle
INFO: Failed at 2025-04-27 01:05:07
INFO: filesystem type on dumpdir is 'cifs' -using /var/tmp/vzdumptmp1043654_102 for temporary files
INFO: Backup started at 2025-04-27 01:05:08
INFO: creating vzdump archive '/mnt/pve/neuerserver/dump/vzdump-lxc-102-2025_04_27-01_05_08.tar.zst'
INFO: Total bytes written: 4787200000 (4.5GiB, 112MiB/s)
INFO: archive file size: 644MB
ERROR: Backup of VM 102 failed - file '/mnt/pve/neuerserver/dump/vzdump-lxc-102-2025_04_14-00_04_54.tar.zst.notes' exists but open for reading failed - Stale file handle
INFO: Failed at 2025-04-27 01:05:50
INFO: filesystem type on dumpdir is 'cifs' -using /var/tmp/vzdumptmp1043654_103 for temporary files
INFO: Backup started at 2025-04-27 01:05:50
INFO: creating vzdump archive '/mnt/pve/neuerserver/dump/vzdump-lxc-103-2025_04_27-01_05_50.tar.zst'
INFO: Total bytes written: 2133903360 (2.0GiB, 38MiB/s)
INFO: archive file size: 942MB
ERROR: Backup of VM 103 failed - file '/mnt/pve/neuerserver/dump/vzdump-lxc-103-2025_04_14-00_05_33.tar.zst.notes' exists but open for reading failed - Stale file handle
INFO: Failed at 2025-04-27 01:06:46
Gruß OSR
Da Du darauf bisher nicht näher eingegangen bist: Wie genau sieht diesen “Laufwerk” denn aus? D.h. ist an die FB - wie bei mir - auch eine USB HDD angeschlossen, oder was? Wenn ja wie viel Platz ist denn da (noch) vorhanden, weil wenn ich das richtig sehe ist das gepackte Backup-File ja 4,27GB groß.
Den options noserverino in der /etc/pve/storage.cfg hast Du auch schon gemacht, oder?
aus der PVE Konsole, mal folgenden Befehl ausführen, der erstellt nur ein leeres File!
pve root# touch /mnt/pve/neuerserver/dump/test.txt
pve root# ls -la /mnt/pve/neuerserver/dump/
Dann fällt mir dazu immer wieder ein, dass man da etwas in die Konfiguration bei Proxmox einfügen muss.
options noserverino
Das müsste dann so aussehen, per nano die Datei /etc/pve/storage.cfg öffnen, dort dann dein cifs Eintrag für die Fritz!Box suchen,
cifs: neuerserver
        path /mnt/pve/neuerserver/
        server 192.168.178.1
        share BACKUP/UNRAID
        content rootdir,backup
        prune-backups keep-all=1
        username <someuser>
        options noserverino
Die letzte Zeile ist wichtig.
bei mir sieht das so aus
cifs: neuerserver
        share FRITZ.NAS
        content backup,images
        prune-backups keep-last=7
        subdir /BACKUP/UNRAID
        username unraid
dann muss ich also jetzt zusätzlich
diese Zeile einfügen.
 options noserverino
aber mit welchen Tasten speicher ich dann diese neue Einstelungen?
so sieht mein speicher aus es ist eine SSD
BACKUP
USB-Speicher
386,33 GB von 472,17 GB frei
Dateisystem: ext4
Anschluss: USB 3.0
Kommt halt darauf an welchen Editor Du für das bearbeiten nutzt. Da musst Du dann schon selber schauen. :slightly_smiling_face:
Bei Nano sind die Tastenkombinationen unter ja vorhanden:
nano_Befehle
Ich nutze hier z.B. den Midnight Commander, weil ich den schon ewig unter Linux nutze und daher habe ich den dann auch unter Proxmox installiert.
Ach ja - und ja ohne den options noserverino Eintrag kommt es zu Problemen, bzw. funktioniert es nicht. :slightly_smiling_face:
VG JIm
Du kannst auch einen Editor Deiner Wahl nutzen, aber nano ist doch simpel :thinking:
        [ Read 25 lines ]
^G Help           ^O Write Out      ^W Where Is       ^K Cut            ^T Execute        ^C Location       M-U Undo          M-A Set Mark      M-] To Bracket    M-Q Previous      ^B Back           ^◂ Prev Word      ^A Home
^X Exit           ^R Read File      ^\ Replace        ^U Paste          ^J Justify        ^/ Go To Line     M-E Redo          M-6 Copy          ^Q Where Was      M-W Next          ^F Forward        ^▸ Next Word      ^E End
Da sieht man doch, mit crtl + o schreibt man das File, mit crtl + x geht man aus dem Editor.
alles klar ich hatte alt gedrückt Steuerung genau danke
mal versucht manuel ei Backup auf die Fritzbox zu starten geht nicht
Fehlermeldung jetzt:
INFO: starting new backup job: vzdump 103 --mode snapshot --notification-mode auto --compress zstd --remove 0 --node pve --notes-template '{{guestname}}' --storage neuerserver
INFO: Failed at 2025-04-27 15:56:02
Hast Du den Proxmox Host denn jetzt nach dem Eintrag von options noserverino schon neu gebootet? Edit: Falls ja habe ich auch keine Idee mehr. Bei mir funktioniert halt das sichern auf dem FB NAS und der daran angeschlossenen WD USB HDD problemlos.
VG JIm
