heute hat sich mein HA neu gestartet, im Supervisor konnte ich folgende Fehlermeldung. Kann die jemand interpretieren, wo müsste ich suchen:
2024-08-12 13:34:13.571 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
2024-08-12 14:04:13.705 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
2024-08-12 14:15:11.163 WARNING (MainThread) [supervisor.homeassistant.websocket] Connection is closed
2024-08-12 14:15:11.163 ERROR (MainThread) [supervisor.homeassistant.api] Error on call http://172.30.32.1:8123/api/core/state: [Errno 104] Connection reset by peer
2024-08-12 14:15:14.519 WARNING (MainThread) [supervisor.homeassistant.core] Watchdog found Home Assistant failed, restarting...
2024-08-12 14:15:14.533 INFO (SyncWorker_5) [supervisor.docker.manager] Starting homeassistant
2024-08-12 14:15:14.647 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
2024-08-12 14:15:19.657 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to APIState(core_state='NOT_RUNNING', offline_db_migration=False)
2024-08-12 14:15:19.893 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
2024-08-12 14:15:20.053 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
und später dies:
2024-08-12 14:30:00.742 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on ghcr.io/hassio-addons/log-viewer/amd64 with version 0.17.0
2024-08-12 14:30:00.786 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.33.11:8099 ssl:default [Connect call failed ('172.30.33.11', 8099)]
Danach ist er aber noch nicht abgestürzt
Elmar
