Mein HA war heute mal nicht erreichbar. Wie finde ich heraus an was es gelegen hat?
Einstellungen → System → Protokolle
Was wurde denn getestet?
Kann es ein Fehler der Hardware gewesen sein? Könnte es am Netzwerk gelegen haben? Gab es zuvor Updates? Könnten Prozessor oder Speicher ausgelastet gewesen sein?
Aus dem Log werde ich nicht schlau, was der Fehler sein kann:
e[32m2025-02-01 20:31:20.528 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state runninge[0m
e[32m2025-02-01 20:31:20.529 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisore[0m
e[32m2025-02-01 20:31:20.533 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_servere[0m
e[32m2025-02-01 20:31:20.595 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/systeme[0m
e[32m2025-02-01 20:31:20.596 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disabled_data_disk/systeme[0m
e[32m2025-02-01 20:31:20.596 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/systeme[0m
e[32m2025-02-01 20:31:20.596 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_servere[0m
e[32m2025-02-01 20:31:20.596 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addone[0m
e[32m2025-02-01 20:31:20.596 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/systeme[0m
e[32m2025-02-01 20:31:20.596 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/systeme[0m
e[32m2025-02-01 20:31:20.597 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/coree[0m
e[32m2025-02-01 20:31:20.597 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/systeme[0m
e[32m2025-02-01 20:31:20.597 INFO (MainThread) [supervisor.resolution.check] System checks completee[0m
e[32m2025-02-01 20:31:20.597 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state runninge[0m
e[32m2025-02-01 20:31:20.685 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation completee[0m
e[32m2025-02-01 20:31:20.685 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state runninge[0m
e[32m2025-02-01 20:31:20.686 INFO (MainThread) [supervisor.resolution.fixup] System autofix completee[0m
e[31m2025-02-01 20:46:59.544 ERROR (MainThread) [supervisor.homeassistant.api] Timeout on call http://172.30.32.1:8123/api/core/state.e[0m
e[32m2025-02-01 20:47:11.545 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API error: Cannot proxy websocket message of unsupported type: 258e[0m
e[32m2025-02-01 20:47:11.547 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API for 491eb00d_hamh closede[0m
e[32m2025-02-01 20:47:14.547 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API error: Cannot proxy websocket message of unsupported type: 258e[0m
e[32m2025-02-01 20:47:14.548 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API for a0d7b954_nodered closede[0m
e[31m2025-02-01 20:48:13.548 ERROR (MainThread) [supervisor.homeassistant.api] Timeout on call http://172.30.32.1:8123/api/core/state.e[0m
e[31m2025-02-01 20:48:44.545 ERROR (MainThread) [supervisor.homeassistant.api] Timeout on call http://172.30.32.1:8123/api/core/state.e[0m
e[33m2025-02-01 20:48:59.459 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon File editor is unhealthy, restarting...e[0m
e[32m2025-02-01 20:48:59.464 INFO (SyncWorker_0) [supervisor.docker.manager] Stopping addon_core_configurator applicatione[0m
e[32m2025-02-01 20:49:02.622 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning addon_core_configurator applicatione[0m
e[32m2025-02-01 20:49:02.897 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on homeassistant/amd64-addon-configurator with version 5.8.0e[0m
e[31m2025-02-01 20:49:15.547 ERROR (MainThread) [supervisor.homeassistant.api] Timeout on call http://172.30.32.1:8123/api/core/state.e[0m
e[31m2025-02-01 20:49:46.551 ERROR (MainThread) [supervisor.homeassistant.api] Timeout on call http://172.30.32.1:8123/api/core/state.e[0m
e[31m2025-02-01 20:50:17.547 ERROR (MainThread) [supervisor.homeassistant.api] Timeout on call http://172.30.32.1:8123/api/core/state.e[0m
e[31m2025-02-01 20:50:48.547 ERROR (MainThread) [supervisor.homeassistant.api] Timeout on call http://172.30.32.1:8123/api/core/state.e[0m
e[33m2025-02-01 20:51:02.904 WARNING (MainThread) [supervisor.addons.addon] Timeout while waiting for addon File editor to start, took more than 120 secondse[0m
e[31m2025-02-01 20:51:19.545 ERROR (MainThread) [supervisor.homeassistant.api] Timeout on call http://172.30.32.1:8123/api/core/state.e[0m
e[31m2025-02-01 20:51:50.556 ERROR (MainThread) [supervisor.homeassistant.api] Timeout on call http://172.30.32.1:8123/api/core/state.e[0m
e[33m2025-02-01 20:52:02.980 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon File editor is unhealthy, restarting...e[0m
e[32m2025-02-01 20:52:02.985 INFO (SyncWorker_4) [supervisor.docker.manager] Stopping addon_core_configurator applicatione[0m
e[32m2025-02-01 20:52:06.176 INFO (SyncWorker_4) [supervisor.docker.manager] Cleaning addon_core_configurator applicatione[0m
e[32m2025-02-01 20:52:06.453 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on homeassistant/amd64-addon-configurator with version 5.8.0e[0m
e[31m2025-02-01 20:52:21.556 ERROR (MainThread) [supervisor.homeassistant.api] Timeout on call http://172.30.32.1:8123/api/core/state.e[0m
e[31m2025-02-01 20:52:52.559 ERROR (MainThread) [supervisor.homeassistant.api] Timeout on call http://172.30.32.1:8123/api/core/state.e[0m
e[31m2025-02-01 20:53:23.544 ERROR (MainThread) [supervisor.homeassistant.api] Timeout on call http://172.30.32.1:8123/api/core/state.e[0m
e[31m2025-02-01 20:53:54.552 ERROR (MainThread) [supervisor.homeassistant.api] Timeout on call http://172.30.32.1:8123/api/core/state.e[0m
e[33m2025-02-01 20:54:06.456 WARNING (MainThread) [supervisor.addons.addon] Timeout while waiting for addon File editor to start, took more than 120 secondse[0m
e[31m2025-02-01 20:54:25.546 ERROR (MainThread) [supervisor.homeassistant.api] Timeout on call http://172.30.32.1:8123/api/core/state.e[0m
e[31m2025-02-01 20:54:56.563 ERROR (MainThread) [supervisor.homeassistant.api] Timeout on call http://172.30.32.1:8123/api/core/state.e[0m
e[33m2025-02-01 20:55:06.539 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon File editor is unhealthy, restarting...e[0m
e[32m2025-02-01 20:55:06.543 INFO (SyncWorker_2) [supervisor.docker.manager] Stopping addon_core_configurator applicatione[0m
e[32m2025-02-01 20:55:09.687 INFO (SyncWorker_2) [supervisor.docker.manager] Cleaning addon_core_configurator applicatione[0m
e[32m2025-02-01 20:55:10.067 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on homeassistant/amd64-addon-configurator with version 5.8.0e[0m
e[31m2025-02-01 20:55:27.555 ERROR (MainThread) [supervisor.homeassistant.api] Timeout on call http://172.30.32.1:8123/api/core/state.e[0m
e[31m2025-02-01 20:55:58.562 ERROR (MainThread) [supervisor.homeassistant.api] Timeout on call http://172.30.32.1:8123/api/core/state.e[0m
e[31m2025-02-01 20:56:29.553 ERROR (MainThread) [supervisor.homeassistant.api] Timeout on call http://172.30.32.1:8123/api/core/state.e[0m
e[31m2025-02-01 20:57:00.545 ERROR (MainThread) [supervisor.homeassistant.api] Timeout on call http://172.30.32.1:8123/api/core/state.e[0m
e[33m2025-02-01 20:57:10.073 WARNING (MainThread) [supervisor.addons.addon] Timeout while waiting for addon File editor to start, took more than 120 secondse[0m
e[31m2025-02-01 20:57:31.547 ERROR (MainThread) [supervisor.homeassistant.api] Timeout on call http://172.30.32.1:8123/api/core/state.e[0m
e[31m2025-02-01 20:58:02.566 ERROR (MainThread) [supervisor.homeassistant.api] Timeout on call http://172.30.32.1:8123/api/core/state.e[0m
e[33m2025-02-01 20:58:10.146 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon File editor is unhealthy, restarting...e[0m
e[32m2025-02-01 20:58:10.151 INFO (SyncWorker_1) [supervisor.docker.manager] Stopping addon_core_configurator applicatione[0m
e[32m2025-02-01 20:58:13.305 INFO (SyncWorker_1) [supervisor.docker.manager] Cleaning addon_core_configurator applicatione[0m
e[32m2025-02-01 20:58:13.590 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on homeassistant/amd64-addon-configurator with version 5.8.0e[0m
e[31m2025-02-01 20:58:33.559 ERROR (MainThread) [supervisor.homeassistant.api] Timeout on call http://172.30.32.1:8123/api/core/state.e[0m
e[31m2025-02-01 20:59:04.564 ERROR (MainThread) [supervisor.homeassistant.api] Timeout on call http://172.30.32.1:8123/api/core/state.e[0m
e[31m2025-02-01 20:59:35.549 ERROR (MainThread) [supervisor.homeassistant.api] Timeout on call http://172.30.32.1:8123/api/core/state.e[0m
e[31m2025-02-01 21:00:06.550 ERROR (MainThread) [supervisor.homeassistant.api] Timeout on call http://172.30.32.1:8123/api/core/state.e[0m
e[33m2025-02-01 21:00:13.595 WARNING (MainThread) [supervisor.addons.addon] Timeout while waiting for addon File editor to start, took more than 120 secondse[0m
e[31m2025-02-01 21:00:37.547 ERROR (MainThread) [supervisor.homeassistant.api] Timeout on call http://172.30.32.1:8123/api/core/state.e[0m
e[31m2025-02-01 21:01:08.546 ERROR (MainThread) [supervisor.homeassistant.api] Timeout on call http://172.30.32.1:8123/api/core/state.e[0m
e[33m2025-02-01 21:01:13.670 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon File editor is unhealthy, restarting...e[0m
e[32m2025-02-01 21:01:13.674 INFO (SyncWorker_3) [supervisor.docker.manager] Stopping addon_core_configurator applicatione[0m
e[32m2025-02-01 21:01:16.820 INFO (SyncWorker_3) [supervisor.docker.manager] Cleaning addon_core_configurator applicatione[0m
e[32m2025-02-01 21:01:17.101 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on homeassistant/amd64-addon-configurator with version 5.8.0e[0m
e[31m2025-02-01 21:01:39.564 ERROR (MainThread) [supervisor.homeassistant.api] Timeout on call http://172.30.32.1:8123/api/core/state.e[0m
e[31m2025-02-01 21:02:10.557 ERROR (MainThread) [supervisor.homeassistant.api] Timeout on call http://172.30.32.1:8123/api/core/state.e[0m
e[31m2025-02-01 21:02:41.561 ERROR (MainThread) [supervisor.homeassistant.api] Timeout on call http://172.30.32.1:8123/api/core/state.e[0m
e[31m2025-02-01 21:03:12.545 ERROR (MainThread) [supervisor.homeassistant.api] Timeout on call http://172.30.32.1:8123/api/core/state.e[0m
e[31m2025-02-01 21:03:43.548 ERROR (MainThread) [supervisor.homeassistant.api] Timeout on call http://172.30.32.1:8123/api/core/state.e[0m
e[31m2025-02-01 21:04:14.545 ERROR (MainThread) [supervisor.homeassistant.api] Timeout on call http://172.30.32.1:8123/api/core/state.e[0m
e[31m2025-02-01 21:18:00.775 ERROR (MainThread) [aiohttp.server] Error handling request
File "/usr/local/lib/python3.12/site-packages/aiohttp/client_proto.py", line 92, in connection_lost
uncompleted = self._parser.feed_eof()
File "aiohttp/_http_parser.pyx", line 508, in aiohttp._http_parser.HttpParser.feed_eof
raise TransferEncodingError(
aiohttp.http_exceptions.TransferEncodingError: 400, message:
Not enough data for satisfy transfer length header.
The above exception was the direct cause of the following exception:
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_protocol.py", line 480, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.12/site-packages/sentry_sdk/integrations/aiohttp.py", line 161, in sentry_app_handle
reraise(*_capture_exception())
File "/usr/local/lib/python3.12/site-packages/sentry_sdk/utils.py", line 1795, in reraise
raise value
File "/usr/local/lib/python3.12/site-packages/sentry_sdk/integrations/aiohttp.py", line 144, in sentry_app_handle
response = await old_handle(self, request)
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_app.py", line 569, in _handle
return await handler(request)
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_middlewares.py", line 117, in impl
File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 199, in block_bad_requests
File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 215, in system_validation
File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 285, in token_validation
File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 298, in core_proxy
File "/usr/src/supervisor/supervisor/api/utils.py", line 104, in wrap_api
msg_data = await method(api, *args, **kwargs)
File "/usr/src/supervisor/supervisor/api/__init__.py", line 529, in get_addon_logs
return await self._api_host.advanced_logs(request, *args, **kwargs)
File "/usr/src/supervisor/supervisor/api/host.py", line 278, in advanced_logs
return await self.advanced_logs_handler(request, identifier, follow)
File "/usr/src/supervisor/supervisor/api/host.py", line 257, in advanced_logs_handler
async for cursor, line in journal_logs_reader(resp, log_formatter):
File "/usr/src/supervisor/supervisor/utils/systemd_journal.py", line 80, in journal_logs_reader
line = await resp.content.readuntil(b"\n")
File "/usr/local/lib/python3.12/site-packages/aiohttp/streams.py", line 386, in readuntil
await self._wait("readuntil")
File "/usr/local/lib/python3.12/site-packages/aiohttp/streams.py", line 347, in _wait
await waiter
aiohttp.client_exceptions.ClientPayloadError: Response payload is not completed: <TransferEncodingError: 400, message='Not enough data for satisfy transfer length header.'>e[0m
e[31m2025-02-01 21:18:00.786 ERROR (MainThread) [aiohttp.server] Error handling request
raise value
Kann es sein das der FileEditor das Problem verursacht hat?
