HA installations Error auf Proxmox/NUC system
Guten Tag,
ich komme leider nicht weiter mit der Installation von HA. Ich bin der Meinung das ich mich genau an die Video-Anleitung gehalten habe :wink: im Log steht folgendes
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/udev.sh
[13:39:34] INFO: Using udev information from host
cont-init: info: /etc/cont-init.d/udev.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun supervisor (no readiness notification)
services-up: info: copying legacy longrun watchdog (no readiness notification)
[13:39:34] INFO: Starting local supervisor watchdog...
s6-rc: info: service legacy-services successfully started
24-03-16 13:39:38 INFO (MainThread) [__main__] Initializing Supervisor setup
24-03-16 13:39:38 INFO (MainThread) [supervisor.docker.network] Can't find Supervisor network, creating a new network
24-03-16 13:39:39 INFO (MainThread) [supervisor.bootstrap] Setting up coresys for machine: qemux86-64
24-03-16 13:39:39 INFO (MainThread) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/amd64-hassio-supervisor with version 2024.03.0
24-03-16 13:39:39 INFO (MainThread) [supervisor.docker.supervisor] Connecting Supervisor to hassio-network
24-03-16 13:39:39 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state initialize
24-03-16 13:39:39 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
24-03-16 13:39:39 INFO (MainThread) [__main__] Setting up Supervisor
24-03-16 13:39:40 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
24-03-16 13:39:40 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
24-03-16 13:39:40 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
24-03-16 13:39:40 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
24-03-16 13:39:40 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
24-03-16 13:39:40 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
24-03-16 13:39:40 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
24-03-16 13:39:40 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
24-03-16 13:39:40 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
24-03-16 13:39:40 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
24-03-16 13:39:40 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
24-03-16 13:39:40 INFO (MainThread) [supervisor.host.services] Updating service information
24-03-16 13:39:40 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
24-03-16 13:39:40 WARNING (SyncWorker_0) [supervisor.host.sound] Can't update PulseAudio data: Failed to connect to pulseaudio server
24-03-16 13:39:40 INFO (MainThread) [supervisor.host.network] Updating local network information
24-03-16 13:39:40 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
24-03-16 13:39:45 WARNING (MainThread) [supervisor.utils.whoami] Can't fetch Whoami data: Cannot connect to host services.home-assistant.io:443 ssl:default [Try again]
24-03-16 13:39:45 WARNING (MainThread) [supervisor.core] Can't adjust Time/Date settings: Can't fetch Whoami data: Cannot connect to host services.home-assistant.io:443 ssl:default [Try again]
24-03-16 13:39:45 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
24-03-16 13:39:45 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
24-03-16 13:39:50 WARNING (MainThread) [supervisor.updater] Can't fetch versions from https://version.home-assistant.io/stable.json: Cannot connect to host version.home-assistant.io:443 ssl:default [Try again]
24-03-16 13:39:50 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-cli versions: [<AwesomeVersion CalVer '2024.03.1'>]
24-03-16 13:39:50 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-cli with version 2024.03.1
24-03-16 13:39:51 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
24-03-16 13:39:53 INFO (MainThread) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/amd64-hassio-cli with version 2024.03.1 - 172.30.32.5
24-03-16 13:39:53 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-dns versions: [<AwesomeVersion CalVer '2024.03.0'>]
24-03-16 13:39:53 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-dns with version 2024.03.0
24-03-16 13:39:53 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
24-03-16 13:39:57 INFO (MainThread) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/amd64-hassio-dns with version 2024.03.0 - 172.30.32.3
24-03-16 13:39:57 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
24-03-16 13:40:02 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-audio versions: [<AwesomeVersion CalVer '2023.12.0'>]
24-03-16 13:40:02 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-audio with version 2023.12.0
24-03-16 13:40:02 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
24-03-16 13:40:05 INFO (MainThread) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/amd64-hassio-audio with version 2023.12.0 - 172.30.32.4
24-03-16 13:40:05 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-observer versions: [<AwesomeVersion CalVer '2023.06.0'>]
24-03-16 13:40:05 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-observer with version 2023.06.0
24-03-16 13:40:06 INFO (MainThread) [supervisor.plugins.observer] Starting observer plugin
24-03-16 13:40:09 INFO (MainThread) [supervisor.docker.observer] Starting Observer ghcr.io/home-assistant/amd64-hassio-observer with version 2023.06.0 - 172.30.32.6
24-03-16 13:40:09 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-multicast versions: [<AwesomeVersion CalVer '2024.03.0'>]
24-03-16 13:40:09 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-multicast with version 2024.03.0
24-03-16 13:40:10 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
24-03-16 13:40:13 INFO (MainThread) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/amd64-hassio-multicast with version 2024.03.0 - Host
24-03-16 13:40:13 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
24-03-16 13:40:13 INFO (MainThread) [supervisor.docker.interface] No version found for ghcr.io/home-assistant/qemux86-64-homeassistant
24-03-16 13:40:13 INFO (MainThread) [supervisor.homeassistant.core] No Home Assistant Docker image ghcr.io/home-assistant/qemux86-64-homeassistant found.
24-03-16 13:40:13 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/qemux86-64-homeassistant with version landingpage
24-03-16 13:40:13 INFO (MainThread) [supervisor.homeassistant.core] Using preinstalled landingpage
24-03-16 13:40:13 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
24-03-16 13:40:13 INFO (MainThread) [supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
24-03-16 13:40:16 INFO (MainThread) [supervisor.docker.homeassistant] Starting Home Assistant ghcr.io/home-assistant/qemux86-64-homeassistant with version landingpage
24-03-16 13:40:16 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 12.1 / BootSlot A
24-03-16 13:40:21 WARNING (MainThread) [supervisor.jobs] 'GitRepo.clone' blocked from execution, no supervisor internet connection
24-03-16 13:40:21 ERROR (MainThread) [supervisor.store] Can't add repository core due to 'GitRepo.clone' blocked from execution, no supervisor internet connection
24-03-16 13:40:21 INFO (MainThread) [supervisor.resolution.module] Create new suggestion execute_reload - store / core
24-03-16 13:40:21 INFO (MainThread) [supervisor.resolution.module] Create new issue fatal_error - store / core
24-03-16 13:40:21 ERROR (MainThread) [supervisor.store] Can't add repository https://github.com/hassio-addons/repository due to 'GitRepo.clone' blocked from execution, no supervisor internet connection
24-03-16 13:40:21 INFO (MainThread) [supervisor.resolution.module] Create new suggestion execute_reload - store / a0d7b954
24-03-16 13:40:21 INFO (MainThread) [supervisor.resolution.module] Create new issue fatal_error - store / a0d7b954
24-03-16 13:40:21 ERROR (MainThread) [supervisor.store] Can't add repository https://github.com/esphome/home-assistant-addon due to 'GitRepo.clone' blocked from execution, no supervisor internet connection
24-03-16 13:40:21 INFO (MainThread) [supervisor.resolution.module] Create new suggestion execute_reload - store / 5c53de3b
24-03-16 13:40:21 INFO (MainThread) [supervisor.resolution.module] Create new issue fatal_error - store / 5c53de3b
24-03-16 13:40:21 INFO (MainThread) [supervisor.store] Loading add-ons from store: 0 all - 0 new - 0 remove
24-03-16 13:40:21 INFO (MainThread) [supervisor.addons.manager] Found 0 installed add-ons
24-03-16 13:40:21 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
24-03-16 13:40:21 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
24-03-16 13:40:21 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
24-03-16 13:40:21 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state setup
24-03-16 13:40:21 INFO (MainThread) [supervisor.resolution.check] System checks complete
24-03-16 13:40:21 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
24-03-16 13:40:21 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
24-03-16 13:40:21 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - setup
24-03-16 13:40:21 INFO (MainThread) [__main__] Running Supervisor
24-03-16 13:40:21 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
24-03-16 13:40:21 INFO (MainThread) [supervisor.addons.manager] Phase 'initialize' starting 0 add-ons
24-03-16 13:40:21 INFO (MainThread) [supervisor.addons.manager] Phase 'system' starting 0 add-ons
24-03-16 13:40:21 INFO (MainThread) [supervisor.addons.manager] Phase 'services' starting 0 add-ons
24-03-16 13:40:21 INFO (MainThread) [supervisor.core] Skipping start of Home Assistant
24-03-16 13:40:21 INFO (MainThread) [supervisor.addons.manager] Phase 'application' starting 0 add-ons
24-03-16 13:40:21 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
24-03-16 13:40:21 INFO (MainThread) [supervisor.core] Supervisor is up and running
24-03-16 13:40:21 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
24-03-16 13:40:21 INFO (MainThread) [supervisor.host.info] Updating local host information
24-03-16 13:40:21 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
24-03-16 13:40:21 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
24-03-16 13:40:21 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
24-03-16 13:40:21 INFO (MainThread) [supervisor.host.services] Updating service information
24-03-16 13:40:21 INFO (MainThread) [supervisor.host.network] Updating local network information
24-03-16 13:40:21 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
24-03-16 13:40:21 INFO (MainThread) [supervisor.host.manager] Host information reload completed
24-03-16 13:40:26 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
24-03-16 13:40:26 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
24-03-16 13:40:26 INFO (MainThread) [supervisor.jobs] 'CheckDNSServer.run_check' blocked from execution, no supervisor internet connection
24-03-16 13:40:26 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/system
24-03-16 13:40:26 INFO (MainThread) [supervisor.resolution.module] Create new suggestion create_full_backup - system / None
24-03-16 13:40:26 INFO (MainThread) [supervisor.resolution.module] Create new issue no_current_backup - system / None
24-03-16 13:40:26 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
24-03-16 13:40:26 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
24-03-16 13:40:31 INFO (MainThread) [supervisor.jobs] 'CheckDNSServerIPv6.run_check' blocked from execution, no supervisor internet connection
24-03-16 13:40:31 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
24-03-16 13:40:36 INFO (MainThread) [supervisor.jobs] 'CheckAddonPwned.run_check' blocked from execution, no supervisor internet connection
24-03-16 13:40:36 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
24-03-16 13:40:36 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
24-03-16 13:40:36 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
24-03-16 13:40:36 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
24-03-16 13:40:36 INFO (MainThread) [supervisor.resolution.check] System checks complete
24-03-16 13:40:36 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
24-03-16 13:40:36 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
24-03-16 13:40:36 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
24-03-16 13:40:41 WARNING (MainThread) [supervisor.jobs] 'FixupStoreExecuteReload.process_fixup' blocked from execution, no supervisor internet connection
24-03-16 13:40:41 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
24-03-16 13:41:01 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
24-03-16 13:41:01 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
Wird daraus jemand schlau und kann mir einen Tipp geben wo der oder die Fehler sind ?
Vielen Dank für Eure Unterstützung
:crayon:by HarryP: Log-Datei in Code-Tags „verpackt“
Warum nimmst Du nicht einfach die fertigen Pakete von hier?
GitHub - tteck/Proxmox: Proxmox VE Helper-Scripts
Oder hast Du diese genommen?
Da ich nur ein Laie bin habe ich mich ohne Anleitung da nicht herangetraut.
Ich versuche es mal ansonsten muss ich da mal einen Kollegen dazu ziehen.
Bis dato habe ich mich mit den Videos dadurch gearbeitet.
Kannst Du einen Link des Videos hier posten damit man sehen kann welches Du meinst?
Die ProxMox-Skripte von obigem Link sind eigentlich sehr gute Lösungen und in Teilen selbsterklärend, da vieles bereits mit Default belegt ist. Ich denke es gibt aber ür HA auch ein YouTube-Video diese ProxMox-Skripte nutzt.
Ich habe mich an diese Video gehalten
Hier ist die gesamte Auswahl an Scripts. Das geht wirklich ganz einfach…
Ich versuche es nochmal. Ich melde mich dann später. Danke schonmal
Wenn bei Dir Proxmox läuft, dann versuche mal folgende Beschreibung
und springe in dem Video an die Stelle, ziemlich weit hinten, wo die Installation unter Proxmox beschrieben wird. So ab Minute 21:40 oder kurz davor/danach.
Es gibt dann dort auch viele weitere Skripte für MariaDB, influxDB, grafana, Zigbe2MQTT und und und…
Viel Erfolg
Claudius
Die HelperSkripte sind die einzig vernüftige Lösung, HA auf Proxmox zu installieren.
Einfacher geht es nicht mehr
  • Proxmox Konsole in der WebGUI öffnen
  • Kommando des HelperSkriptes rein pasten und starten
  • Wenn man sich nicht weiter auskenne - Default-Installition laufen lassen.
  • Kaffee trinken und abwarten bis fertig
  • HA WebGui aufrufen und freuen.
Guten Morgen,
So das Problem ist endlich behoben.
Es lag meinem Router. Wieso auch immer er keine Verbindung für HA zu ließ.
Der Router ist nun raus und alles funktioniert.
Vielen Dank für Eure Hilfe.
