Hallo Ihr lieben,
ich bin seit kurzem auch HA Nutzer und stehe nun vor einem Problem. Ich have versehentlich den Stromstecker des HomeServers gezogen und nun kann ich Zigbee2Mqtt nicht mehr starten.
Im Log des Addons steht folgendes:
[2024-09-26 16:18:39] info: z2m: Currently 15 devices are joined.
[2024-09-26 16:18:39] info: z2m: Zigbee: disabling joining new devices.
[2024-09-26 16:18:39] info: z2m: Connecting to MQTT server at mqtt://core-mosquitto:1883
[2024-09-26 16:18:39] error: z2m: MQTT error: connect ECONNREFUSED 172.30.33.0:1883
[2024-09-26 16:18:39] error: z2m: MQTT failed to connect, exiting... (connect ECONNREFUSED 172.30.33.0:1883)
[2024-09-26 16:18:39] info: z2m: Stopping zigbee-herdsman...
[2024-09-26 16:18:40] error: z2m: MQTT error: connect ECONNREFUSED 172.30.33.0:1883
[2024-09-26 16:18:41] error: z2m: MQTT error: connect ECONNREFUSED 172.30.33.0:1883
[2024-09-26 16:18:43] error: z2m: MQTT error: connect ECONNREFUSED 172.30.33.0:1883
[2024-09-26 16:18:44] error: z2m: MQTT error: connect ECONNREFUSED 172.30.33.0:1883
[2024-09-26 16:18:45] error: z2m: MQTT error: connect ECONNREFUSED 172.30.33.0:1883
[2024-09-26 16:18:46] error: z2m: MQTT error: connect ECONNREFUSED 172.30.33.0:1883
[2024-09-26 16:18:47] error: z2m: MQTT error: connect ECONNREFUSED 172.30.33.0:1883
[2024-09-26 16:18:48] error: z2m: MQTT error: connect ECONNREFUSED 172.30.33.0:1883
[2024-09-26 16:18:49] error: z2m: MQTT error: connect ECONNREFUSED 172.30.33.0:1883
[2024-09-26 16:18:49] info: zh:controller: Wrote coordinator backup to '/config/zigbee2mqtt/coordinator_backup.json'
[2024-09-26 16:18:49] info: zh:zstack:znp: closing
[2024-09-26 16:18:49] info: zh:zstack:znp: Port closed
[2024-09-26 16:18:49] info: z2m: Stopped zigbee-herdsman
[16:18:50] INFO: Preparing to start...
[16:18:50] INFO: Socat not enabled
[16:18:50] ERROR: Got unexpected response from the API: Service not enabled
[16:18:50] INFO: Starting Zigbee2MQTT...
[2024-09-26 16:18:51] info: z2m: Logging to console, file (filename: log.log)
[2024-09-26 16:18:51] info: z2m: Starting Zigbee2MQTT version 1.40.1 (commit #unknown)
[2024-09-26 16:18:51] info: z2m: Starting zigbee-herdsman (0.57.3)
[2024-09-26 16:18:51] info: zh:zstack:znp: Opening SerialPort with {"path":"/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_423e5f9c16a6ed11b1fceba32981d5c7-if00-port0","baudRate":115200,"rtscts":false,"autoOpen":false}
[2024-09-26 16:18:52] info: zh:zstack:znp: Serialport opened
[2024-09-26 16:18:52] info: z2m: zigbee-herdsman started (resumed)
[2024-09-26 16:18:52] info: z2m: Coordinator firmware version: '{"meta":{"maintrel":1,"majorrel":2,"minorrel":7,"product":1,"revision":20210708,"transportrev":2},"type":"zStack3x0"}'
[2024-09-26 16:18:52] info: z2m: Thermometer Wohnzimmer (0x0ceff6fffe3e796e): SNZB-02D - SONOFF Temperature and humidity sensor with screen (EndDevice)
[2024-09-26 16:18:52] info: z2m: Steckdose Sofa (0xa4c138c05c430a36): TS011F_plug_1 - Tuya Smart plug (with power monitoring) (Router)
[2024-09-26 16:18:52] info: z2m: Waschmaschiene (0xa4c1380998c1e0df): TS011F_plug_1 - Tuya Smart plug (with power monitoring) (Router)
[2024-09-26 16:18:52] info: z2m: Fenster Küche (0x00124b0022cd2bf5): SNZB-04 - SONOFF Contact sensor (EndDevice)
[2024-09-26 16:18:52] info: z2m: Balkontür (0x00124b0022d3305f): SNZB-04 - SONOFF Contact sensor (EndDevice)
[2024-09-26 16:18:52] info: z2m: Fenster Schlafzimmer (0x00124b002269a5a0): SNZB-04 - SONOFF Contact sensor (EndDevice)
[2024-09-26 16:18:52] info: z2m: Rollo Wohnzimmer (0xa4c138861893cc87): TS130F - Tuya Curtain/blind switch (Router)
[2024-09-26 16:18:52] info: z2m: Rollo Küche (0xa4c138ff4438cadc): TS130F - Tuya Curtain/blind switch (Router)
[2024-09-26 16:18:52] info: z2m: Termometer Schlafzimmer (0x00124b002fb7bb4e): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
[2024-09-26 16:18:52] info: z2m: Termometer Bad (0x00124b002fab7580): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
[2024-09-26 16:18:52] info: z2m: Tür Abstellkammer (0x00124b002fbad966): SNZB-04 - SONOFF Contact sensor (EndDevice)
[2024-09-26 16:18:52] info: z2m: Schalter Küche (0x00158d00021354af): WXKG11LM - Aqara Wireless mini switch (EndDevice)
[2024-09-26 16:18:52] info: z2m: Balkonsolar (0xa4c1381f3e91f484): TS011F_plug_1 - Tuya Smart plug (with power monitoring) (Router)
[2024-09-26 16:18:52] info: z2m: Schalter Bad (0x842e14fffea34bdf): E1743 - IKEA TRADFRI on/off switch (EndDevice)
[2024-09-26 16:18:52] info: z2m: Bewegungsmelder Bad (0x00124b002fb90013): SNZB-03 - SONOFF Motion sensor (EndDevice)
[2024-09-26 16:18:52] info: z2m: Currently 15 devices are joined.
[2024-09-26 16:18:52] info: z2m: Zigbee: disabling joining new devices.
[2024-09-26 16:18:52] info: z2m: Connecting to MQTT server at mqtt://core-mosquitto:1883
[2024-09-26 16:18:52] error: z2m: MQTT error: connect ECONNREFUSED 172.30.33.0:1883
[2024-09-26 16:18:52] error: z2m: MQTT failed to connect, exiting... (connect ECONNREFUSED 172.30.33.0:1883)
[2024-09-26 16:18:52] info: z2m: Stopping zigbee-herdsman...
[2024-09-26 16:18:53] error: z2m: MQTT error: connect ECONNREFUSED 172.30.33.0:1883
[2024-09-26 16:18:54] error: z2m: MQTT error: connect ECONNREFUSED 172.30.33.0:1883
[2024-09-26 16:18:55] error: z2m: MQTT error: connect ECONNREFUSED 172.30.33.0:1883
[2024-09-26 16:18:56] error: z2m: MQTT error: connect ECONNREFUSED 172.30.33.0:1883
[2024-09-26 16:18:57] error: z2m: MQTT error: connect ECONNREFUSED 172.30.33.0:1883
[2024-09-26 16:18:58] error: z2m: MQTT error: connect ECONNREFUSED 172.30.33.0:1883
Dieser Log wiederholt sich immer wieder.
Hat jemand eine Idee wie ich das fixen kann?
Lieben Gruß,
Pascal ![]()
