HA startet unerwartet neu
Seit einiger Zeit startet meine HA-Installation auf einem Raspi unerwartet neu. Immer ungefähr um die Uhrzeit, um die auch das Backup gestartet wird (ob es da einen Zusammenhang gibt, weis ich nicht). Die Installation ist aktuell und der Neustart findet nicht jede Nach statt. Heute morgen jedoch schon.
Das einzige, was ich im Log um die Zeit finden kann ist folgenden:
> [31m2025-09-21 22:47:25.873 **ERROR** (MainThread) \[pysqueezebox.server\] Failed communicating with LMS(http://192.168.0.59:9000/jsonrpc.js): <class ‘aiohttp.client_exceptions.ClientConnectorError’>e\[0m
> [31m2025-09-21 22:47:25.877 **ERROR** (MainThread) \[pysqueezebox.server\] Failed communicating with LMS(http://192.168.0.59:9000/jsonrpc.js): <class ‘aiohttp.client_exceptions.ClientConnectorError’>e\[0m
> s6-rc: info: service s6rc-oneshot-runner: starting
> s6-rc: info: service s6rc-oneshot-runner successfully started
> s6-rc: info: service fix-attrs: starting
> s6-rc: info: service fix-attrs successfully started
> s6-rc: info: service legacy-cont-init: starting
> s6-rc: info: service legacy-cont-init successfully started
> s6-rc: info: service legacy-services: starting
> services-up: info: copying legacy longrun home-assistant (no readiness notification)
> s6-rc: info: service legacy-services successfully started
> e\[33m2025-09-22 03:51:54.332 WARNING (SyncWorker_0) \[homeassistant.loader\] We found a custom integration blitzortung which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistante\[0m
> e\[33m2025-09-22 03:51:54.336 WARNING (SyncWorker_0) \[homeassistant.loader\] We found a custom integration waste_collection_schedule which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
Der gleiche Hinweis steht auch im Log vom Supervisor.
Nach dem Neustart ist alles in Butter und funktioniert. Das Backup hat dann aber nicht stattgefunden.
Was kann ich tun, damit ich rausfinden kann, wer oder was die Neustarts hervorruft?
Grüße aus Essen
Christoph
Wieviel RAM hat dein Raspberry?
Wenn das beim Backup überläuft kann sowas passieren. Oder auch ein etwas schwaches Netzteil was dann die Grätsche macht.
Installier dir das Addon “glances” und beobachte die Systemlast wenn du das Backup von Hand startest.
Der Raspi hat 4GB RAM, Glances ist installiert und deinen Tipp werde ich heute Nachmittag mal ausprobieren.
Das Netzteil sollte eigentlich reichen, das ist ein Schaltnetzteil mit 6A, eingestellt auf 5.1V, die auch unter Last nicht einbrechen.
Ich glaube das Problem gelöst zu haben:
Einfach alles auf einen Rpi 5 gespielt und seit dem keine Probleme mehr. Mir war auch noch aufgefallen, das die Swap-Datei bis auf 100% ging, das dürfte im Nachgang die Neustarts ausgelöst haben. Nun ist auch bei einem Backup die Swap-File size unter 1%.
Soweit, so gut!
