Ich habe noch mal einige Dinge versuche aber alles ohne Erfolg. Aus den Supervision Logs habe ich das hier rauskopiert. Das Backup File kann ich leider auch nicht einzeln entpacken … langsam bekomme ich ein bisschen Sorge, dass ich alles neu machen darf.
Hat noch jemand ne gute Idee?
2025-12-18 10:31:29.974 ERROR (SyncWorker_7) [supervisor.homeassistant.module] Can't read tarfile <securetar.SecureTarFile object at 0x7fd1339f57f0>: invalid compressed data
2025-12-18 10:31:29.982 ERROR (MainThread) [supervisor.backups.manager] Restore 32b6009d error
File "/usr/local/lib/python3.13/tarfile.py", line 549, in _read
buf = self.cmp.decompress(buf)
igzip_lib.IsalError: Error -1 Invalid deflate block found
The above exception was the direct cause of the following exception:
File "/usr/src/supervisor/supervisor/homeassistant/module.py", line 488, in _restore_home_assistant
with tar_file as backup:
File "/usr/local/lib/python3.13/site-packages/securetar/__init__.py", line 190, in __enter__
return self.open()
File "/usr/local/lib/python3.13/site-packages/securetar/__init__.py", line 220, in open
self._tar = tarfile.open(
fileobj=self,
...<2 lines>...
bufsize=self._bufsize,
File "/usr/local/lib/python3.13/tarfile.py", line 1912, in open
t = cls(name, filemode, stream, **kwargs)
File "/usr/local/lib/python3.13/tarfile.py", line 1788, in __init__
self.firstmember = self.next()
File "/usr/local/lib/python3.13/tarfile.py", line 2801, in next
raise e
File "/usr/local/lib/python3.13/tarfile.py", line 2774, in next
tarinfo = self.tarinfo.fromtarfile(self)
File "/usr/local/lib/python3.13/tarfile.py", line 1335, in fromtarfile
buf = tarfile.fileobj.read(BLOCKSIZE)
File "/usr/local/lib/python3.13/tarfile.py", line 527, in read
buf = self._read(size)
File "/usr/local/lib/python3.13/tarfile.py", line 551, in _read
raise ReadError("invalid compressed data") from e
tarfile.ReadError: invalid compressed data
File "/usr/src/supervisor/supervisor/backups/manager.py", line 736, in _do_restore
task_hass = await backup.restore_homeassistant()
File "/usr/src/supervisor/supervisor/jobs/decorator.py", line 307, in wrapper
raise err
File "/usr/src/supervisor/supervisor/jobs/decorator.py", line 299, in wrapper
return await method(obj, *args, **kwargs)
File "/usr/src/supervisor/supervisor/backups/backup.py", line 890, in restore_homeassistant
await self.sys_homeassistant.restore(
homeassistant_file, self.homeassistant_exclude_database
raise err
File "/usr/src/supervisor/supervisor/homeassistant/module.py", line 539, in restore
data = await self.sys_run_in_executor(_restore_home_assistant)
File "/usr/local/lib/python3.13/concurrent/futures/thread.py", line 59, in run
result = self.fn(*self.args, **self.kwargs)
File "/usr/src/supervisor/supervisor/homeassistant/module.py", line 495, in _restore_home_assistant
raise HomeAssistantError(
f"Can't read tarfile {tar_file}: {err}", _LOGGER.error
) from err
supervisor.exceptions.HomeAssistantError: Can't read tarfile <securetar.SecureTarFile object at 0x7fd1339f57f0>: invalid compressed data
2025-12-18 10:31:29.985 INFO (MainThread) [supervisor.backups.manager] Restore 32b6009d starting stage await_home_assistant_restart
2025-12-18 10:31:30.065 INFO (MainThread) [supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
2025-12-18 10:31:31.010 INFO (MainThread) [supervisor.docker.homeassistant] Starting Home Assistant ghcr.io/home-assistant/qemux86-64-homeassistant with version 2025.12.3
2025-12-18 10:31:31.010 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
2025-12-18 10:31:59.706 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state freeze
2025-12-18 10:31:59.706 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2025-12-18 10:32:01.058 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to APIState(core_state='NOT_RUNNING', offline_db_migration=False)
2025-12-18 10:32:11.083 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to APIState(core_state='RUNNING', offline_db_migration=False)
2025-12-18 10:32:11.084 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instance
2025-12-18 10:32:11.086 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished name='Task-311714' coro=<BackupManager.do_restore_partial() done, defined at /usr/src/supervisor/supervisor/jobs/decorator.py:245> exception=BackupError('Restore 32b6009d error, see supervisor logs')>
return self.open()
fileobj=self,
...<2 lines>...
raise e
raise err
raise err
) from err
raise err
File "/usr/src/supervisor/supervisor/backups/manager.py", line 937, in do_restore_partial
success = await self._do_restore(
...<6 lines>...
File "/usr/src/supervisor/supervisor/backups/manager.py", line 761, in _do_restore
raise BackupError(
f"Restore {backup.slug} error, see supervisor logs"
) from err
supervisor.exceptions.BackupError: Restore 32b6009d error, see supervisor logs
Live
