Diesen Bluprint hatte ich mir einmal selbst angelegt. Vielleicht hilft er dir ja weiter:
blueprint:
name: TRV Extension 2.0
author: Lars van Straelen
description: 'Switches TRV/Climate to OFF/ON depending on a presence , schedule, open windows, partymode and wintermode.
** Version 2.0, 22.02.2024
domain: automation
#source_url:
input:
target_trv:
name: TRV - Entity
description: Which Thermostat is to be controlled (climate)
selector:
entity:
domain: climate
schedule_for_trv_on:
description: Schedule when the heating should be on/activated/heat (schedule).
selector:
entity:
domain: schedule
monitor_window:
description: Windows/Door that has to be closes, when the heating should be on/activated/heat (door).
selector:
entity:
device_class: door
monitor_person:
description: This person must be in the defined <Zone> for the Better Thermostat to be switched on (person).
selector:
entity:
domain: person
monitor_zone:
description: The defined person must be in this zone for the Better Thermostat to be switched on (zone).
selector:
entity:
domain: zone
partymode_switch:
description: The Better Thermostat can be activated by a switch, regardless of presence or schedule. Select the input_boolean that signals whether party mode is active or inactive. (input_boolean).
selector:
entity:
domain: input_boolean
wintermode_switch:
description: The heating is only switched on when this parameter is active, i.e. in winter.
selector:
entity:
aktiv_switch:
description: Parameter to switch off individual thermostats so that no heating is provided.
selector:
entity:
partymode_duration:
name: Duration for Partymode
description: The duration of how long the <Partymode> should be active. After this period, the <Partymode> is automatically terminated again and the regulation is carried out according to presence and schedule.
default:
hours: 0
minutes: 60
seconds: 0
selector:
duration:
trigger:
- platform: homeassistant
event: start
- platform: event
event_type: automation_reloaded
- platform: state
entity_id: !input partymode_switch
for: !input partymode_duration
to: "on"
- platform: state
- !input monitor_window
- platform: state
- !input partymode_switch
- platform: state
- !input wintermode_switch
- platform: state
- !input aktiv_switch
- platform: state
- !input monitor_zone
- platform: state
- !input schedule_for_trv_on
condition: []
action:
- if:
- condition: trigger
id:
- DeactivatePartymode
then:
- service: input_boolean.turn_off
data: {}
- if:
- condition: or
conditions:
- condition: and
conditions:
- condition: state
entity_id: !input monitor_window
state: "off"
- condition: zone
entity_id: !input monitor_person
zone: !input monitor_zone
- condition: state
entity_id: !input schedule_for_trv_on
state: "on"
- condition: state
state: "on"
- condition: state
entity_id: !input wintermode_switch
state: "on"
- condition: state
entity_id: !input aktiv_switch
state: "on"
then:
- service: climate.set_hvac_mode
entity_id: !input target_trv
hvac_mode: 'heat'
else:
hvac_mode: 'off'
Einfach als Datei trv-ext2.yaml unter config/blueprint/[eigner ordnername, bei mir lvs] anlegen
