Nachdem ich es komplett neu installiert hatte, lief es. Danach habe ich die configuration.yaml vom backup eingespielt. Nun bekomme ich wieder eine Fehlermeldung:
root@zigbee2mqtt:/opt/zigbee2mqtt/data# npm start
> zigbee2mqtt@2.4.0 start
> node index.js
[2025-06-19 16:18:03] error: zh:adapter:zstack:manager: Configuration is not consistent with adapter state/backup!
[2025-06-19 16:18:03] error: zh:adapter:zstack:manager: - PAN ID: configured=19435, adapter=41613
[2025-06-19 16:18:03] error: zh:adapter:zstack:manager: - Extended PAN ID: configured=7f8d447e3aa3b3b2, adapter=c83f3fef846d5a26
[2025-06-19 16:18:03] error: zh:adapter:zstack:manager: - Network Key: configured=a66af51146c4de97107d1b15f18cf02d, adapter:active=ca60cd19ec080aa7107747919733d0f7 adapter:preconfigured=ca60cd19ec080aa7107747919733d0f7, adapter:alternate=ca60cd19ec080aa7107747919733d0f7
[2025-06-19 16:18:03] error: zh:adapter:zstack:manager: - Channel List: configured=15, adapter=11
[2025-06-19 16:18:03] error: zh:adapter:zstack:manager: Please update configuration to prevent further issues.
[2025-06-19 16:18:03] error: zh:adapter:zstack:manager: If you wish to re-commission your network, please remove coordinator backup at /opt/zigbee2mqtt/data/coordinator_backup.json.
[2025-06-19 16:18:03] error: zh:adapter:zstack:manager: Re-commissioning your network will require re-pairing of all devices!
[2025-06-19 16:18:03] error: z2m: Error while starting zigbee-herdsman
[2025-06-19 16:18:03] error: z2m: Failed to start zigbee-herdsman
[2025-06-19 16:18:03] error: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions
[2025-06-19 16:18:03] error: z2m: Exiting...
[2025-06-19 16:18:03] error: z2m: Error: startup failed - configuration-adapter mismatch - see logs above for more information
at ZnpAdapterManager.determineStrategy (/opt/zigbee2mqtt/node_modules/.pnpm/zigbee-herdsman@4.1.0/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:249:23)
at processTicksAndRejections (node:internal/process/task_queues:105:5)
at ZnpAdapterManager.start (/opt/zigbee2mqtt/node_modules/.pnpm/zigbee-herdsman@4.1.0/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:62:26)
at ZStackAdapter.start (/opt/zigbee2mqtt/node_modules/.pnpm/zigbee-herdsman@4.1.0/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:154:16)
at Controller.start (/opt/zigbee2mqtt/node_modules/.pnpm/zigbee-herdsman@4.1.0/node_modules/zigbee-herdsman/src/controller/controller.ts:133:29)
at Zigbee.start (/opt/zigbee2mqtt/lib/zigbee.ts:71:27)
at Controller.start (/opt/zigbee2mqtt/lib/controller.ts:102:13)
at start (/opt/zigbee2mqtt/index.js:149:5)
Unter HA erhalte ich jetzt auch nach dem Start von zigbee2mqtt die ähnliche Fehlermeldung wie auf dem lxc:
Starting Zigbee2MQTT with watchdog (2000,60000,300000,900000,1800000,3600000).
[2025-06-19 16:22:47] error: zh:adapter:zstack:manager: Configuration is not consistent with adapter state/backup!
[2025-06-19 16:22:47] error: zh:adapter:zstack:manager: - PAN ID: configured=19435, adapter=41613
[2025-06-19 16:22:47] error: zh:adapter:zstack:manager: - Extended PAN ID: configured=7f8d447e3aa3b3b2, adapter=c83f3fef846d5a26
[2025-06-19 16:22:47] error: zh:adapter:zstack:manager: - Network Key: configured=a66af51146c4de97107d1b15f18cf02d, adapter=ca60cd19ec080aa7107747919733d0f7
[2025-06-19 16:22:47] error: zh:adapter:zstack:manager: - Channel List: configured=15, adapter=11
[2025-06-19 16:22:47] error: zh:adapter:zstack:manager: Please update configuration to prevent further issues.
[2025-06-19 16:22:47] error: zh:adapter:zstack:manager: If you wish to re-commission your network, please remove coordinator backup at /config/zigbee2mqtt/coordinator_backup.json.
[2025-06-19 16:22:47] error: zh:adapter:zstack:manager: Re-commissioning your network will require re-pairing of all devices!
[2025-06-19 16:22:47] error: z2m: Error while starting zigbee-herdsman
[2025-06-19 16:22:47] error: z2m: Failed to start zigbee-herdsman
[2025-06-19 16:22:47] error: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions
[2025-06-19 16:22:47] error: z2m: Exiting...
[2025-06-19 16:22:47] error: z2m: Error: startup failed - configuration-adapter mismatch - see logs above for more information
at ZnpAdapterManager.determineStrategy (/app/node_modules/.pnpm/zigbee-herdsman@4.0.0/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:248:23)
at ZnpAdapterManager.start (/app/node_modules/.pnpm/zigbee-herdsman@4.0.0/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:62:26)
at ZStackAdapter.start (/app/node_modules/.pnpm/zigbee-herdsman@4.0.0/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:154:16)
at Controller.start (/app/node_modules/.pnpm/zigbee-herdsman@4.0.0/node_modules/zigbee-herdsman/src/controller/controller.ts:133:29)
at Zigbee.start (/app/lib/zigbee.ts:70:27)
at Controller.start (/app/lib/controller.ts:104:13)
at start (/app/index.js:149:5)
Wenn ich auf dem lxc komplett neu anfange, muss ich alle Geräte dort neu anlernen?
Bekommen die Geräte dann in HA neue ID´s , so dass ich alle Automationen auch neu anpassen muss?
Update 20.06.
Da bisher keiner geantwortet hat, habe ich selbe angefangen alle Geräte neu zu verbinden. Die erste Steckdose hat geklappt, dann wieder Fehlermeldung:
root@zigbee2mqtt:/opt/zigbee2mqtt/data# npm start zigbee2mqtt
> node index.js zigbee2mqtt
[2025-06-20 09:20:41] info: z2m: Logging to console, file (filename: log.log)
[2025-06-20 09:20:41] info: z2m: Starting Zigbee2MQTT version 2.4.0 (commit #unknown)
[2025-06-20 09:20:41] info: z2m: Starting zigbee-herdsman (4.1.0)
[2025-06-20 09:20:41] info: zh:zstack:znp: Opening TCP socket with 192.168.1.3:6638
[2025-06-20 09:20:41] info: zh:zstack:znp: Socket connected
[2025-06-20 09:20:41] info: zh:zstack:znp: Socket ready
[2025-06-20 09:20:41] info: zh:zstack:znp: Writing CC2530/CC2531 skip bootloader payload
[2025-06-20 09:20:42] info: zh:zstack:znp: Skip bootloader for CC2652/CC1352
[2025-06-20 09:20:43] error: zh:adapter:zstack:manager: Configuration is not consistent with adapter state/backup!
[2025-06-20 09:20:43] error: zh:adapter:zstack:manager: - PAN ID: configured=37609, adapter=61352
[2025-06-20 09:20:43] error: zh:adapter:zstack:manager: - Extended PAN ID: configured=26aaf3813a37ca07, adapter=2aff335f3e129a1e
[2025-06-20 09:20:43] error: zh:adapter:zstack:manager: - Network Key: configured=cd08d432f5bd0ee83330581aded6618f, adapter:active=8b7378791fe214aab1636850977604a0 adapter:preconfigured=8b7378791fe214aab1636850977604a0, adapter:alternate=8b7378791fe214aab1636850977604a0
[2025-06-20 09:20:43] error: zh:adapter:zstack:manager: - Channel List: configured=11, adapter=16
[2025-06-20 09:20:43] error: zh:adapter:zstack:manager: Please update configuration to prevent further issues.
[2025-06-20 09:20:43] error: zh:adapter:zstack:manager: If you wish to re-commission your network, please remove coordinator backup at /opt/zigbee2mqtt/data/coordinator_backup.json.
[2025-06-20 09:20:43] error: zh:adapter:zstack:manager: Re-commissioning your network will require re-pairing of all devices!
[2025-06-20 09:20:43] error: z2m: Error while starting zigbee-herdsman
[2025-06-20 09:20:43] error: z2m: Failed to start zigbee-herdsman
[2025-06-20 09:20:43] error: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions
[2025-06-20 09:20:43] error: z2m: Exiting...
[2025-06-20 09:20:43] error: z2m: Error: startup failed - configuration-adapter mismatch - see logs above for more information
Wo hängt es jetzt wieder?
