### The problem
Zwave stops working on all devices. After restart works for a…while then stops. All devices can be seen on dashboard but no control. I rolled back to previous version with the same issue
### What version of Home Assistant Core has the issue?
Current
### What was the last working version of Home Assistant Core?
Current
### What type of installation are you running?
Home Assistant Core
### Integration causing the issue
Zwave
### Link to integration documentation on our website
NA
### Diagnostics information
Front Door Light Sunset: Error executing script. Unexpected error for call_service at pos 1: '5ee498498a304eb681669eda6bced32b'
9:06:55 AM – (ERROR) Automation - message first occurred at 9:06:54 AM and shows up 2 times
Garage Light Off BD Closed: Error executing script. Unexpected error for call_service at pos 1: 'e27f9c7316674bbc9af2f76ec40b51d0'
9:06:55 AM – (ERROR) Automation - message first occurred at September 4, 2023 at 5:02:36 PM and shows up 6 times
Garage Light On BD Open: Error executing script. Unexpected error for call_service at pos 1: 'fb0dd455e5b942e3baecdf5a7bc2243f'
[2546299816] '47c6fe9112c845d3935456f27da71c04'
9:06:54 AM – (ERROR) Home Assistant WebSocket API - message first occurred at September 4, 2023 at 5:02:36 PM and shows up 11 times
Error executing service: <ServiceCall light.turn_off (c:01H9MDSVF8STMBKTRYV7SH42D1): entity_id=['light.cabinet_light_3'], params=>
9:06:54 AM – (ERROR) components/zwave_js/entity.py - message first occurred at 9:06:54 AM and shows up 12 times
Error doing job: Task exception was never retrieved
9:06:54 AM – (ERROR) components/zwave_js/update.py - message first occurred at September 4, 2023 at 11:50:07 AM and shows up 11 times
Back Lock (L5001US): Failed to connect to the lock: Back Lock (L5001US) - 78:9C:85:34:04:0A: Failed to connect after 7 attempt(s): failed to discover services, device disconnected
9:05:53 AM – (ERROR) runner.py - message first occurred at September 3, 2023 at 7:49:20 PM and shows up 2110 times
A message handler raised an exception: 'org.bluez.Device1'. Traceback (most recent call last): File "src/dbus_fast/message_bus.py", line 811, in dbus_fast.message_bus.BaseMessageBus._process_message File "/usr/local/lib/python3.11/site-packages/bleak/backends/bluezdbus/manager.py", line 854, in _parse_msg condition_callback() File "/usr/local/lib/python3.11/site-packages/bleak/backends/bluezdbus/manager.py", line 709, in callback self._properties[device_path][defs.DEVICE_INTERFACE][property_name] ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~^^^^^^^^^^^^^^^^^^^^^^^ KeyError: 'org.bluez.Device1'
9:01:33 AM – (ERROR) runner.py - message first occurred at September 3, 2023 at 8:01:21 PM and shows up 7938 times
Garage Light Off BD Closed: Already running
9:01:24 AM – (WARNING) Automation - message first occurred at September 4, 2023 at 4:13:49 PM and shows up 16 times
Garage Light On BD Open: Already running
9:01:18 AM – (WARNING) Automation - message first occurred at September 4, 2023 at 4:13:31 PM and shows up 16 times
Update of climate.home is taking over 10 seconds
8:58:20 AM – (WARNING) helpers/entity.py - message first occurred at September 4, 2023 at 7:50:14 PM and shows up 11 times
Referenced entities switch.jasco_products_14288_duplex_receptacle_switch are missing or not currently available
7:05:06 AM – (WARNING) helpers/service.py - message first occurred at September 4, 2023 at 1:01:12 AM and shows up 17 times
API returned 403 from /portal/Device/CheckDataSession/8222562 request
7:00:12 AM – (ERROR) components/honeywell/climate.py - message first occurred at September 4, 2023 at 2:58:04 AM and shows up 30 times
Back Lock (L5001US): Bluetooth error updating
6:19:02 AM – (ERROR) /usr/local/lib/python3.11/site-packages/yalexs_ble/push.py - message first occurred at September 3, 2023 at 9:40:14 PM and shows up 30 times
Error fetching speedtestdotnet data: Selected server is not found.
4:55:37 AM – (ERROR) Speedtest.net - message first occurred at September 4, 2023 at 4:52:10 AM and shows up 3 times
Error fetching tesla-wallconnector data: Could not fetch data from Tesla WallConnector at 192.168.200.44: Timeout
2:58:15 AM – (ERROR) Tesla Wall Connector - message first occurred at September 5, 2023 at 6:29:07 AM and shows up 3 times
Giving up async_request(...) after 3 tries (tesla_wall_connector.exceptions.WallConnectorConnectionTimeoutError: Timeout while connecting to Wall Connector at 192.168.200.44)
2:58:15 AM – (ERROR) components/tesla_wall_connector/__init__.py - message first occurred at September 5, 2023 at 6:29:07 AM and shows up 3 times
Error fetching Ring history data for device 54e0191c6028: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response'))
12:04:05 AM – (WARNING) Ring
Login as kuzi6522@gmail.com failed
September 5, 2023 at 3:03:48 PM – (ERROR) components/honeywell/climate.py - message first occurred at September 4, 2023 at 2:58:06 AM and shows up 6 times
:0:0 Script error.
September 5, 2023 at 1:35:56 PM – (ERROR) components/system_log/__init__.py
Failed to start the Z-Wave JS add-on: Another job is running for job group container_addon_core_zwave_js
September 5, 2023 at 1:35:01 PM – (ERROR) Z-Wave - message first occurred at September 5, 2023 at 1:34:49 PM and shows up 2 times
Config entry 'Z-Wave JS' for zwave_js integration not ready yet: Failed to connect: Cannot connect to host core-zwave-js:3000 ssl:default [Connect call failed ('172.30.33.1', 3000)]; Retrying in background
September 5, 2023 at 1:34:43 PM – (WARNING) config_entries.py - message first occurred at September 4, 2023 at 11:50:07 AM and shows up 3 times
Error setting up entry Denon AVR for denonavr
September 5, 2023 at 11:39:02 AM – (ERROR) components/denonavr/receiver.py
Error fetching 192.168.200.18 data: 192.168.200.18: device stopped responding after 4 requests to send state
September 5, 2023 at 10:59:11 AM – (ERROR) Magic Home - message first occurred at September 5, 2023 at 9:41:13 AM and shows up 2 times
Unexpectedly disconnected from Roomba 192.16
### Example YAML snippet
```yaml
NA
### Anything in the logs that might be useful for us?
```txt
2023-09-06T13:07:56.805Z CNTRLR [Node 022] Embedded device config loaded
2023-09-06T13:07:56.813Z CNTRLR [Node 023] Embedded device config loaded
2023-09-06T13:07:56.831Z CNTRLR [Node 024] Embedded device config loaded
2023-09-06T13:07:56.841Z CNTRLR [Node 025] Embedded device config loaded
2023-09-06T13:07:56.877Z CNTRLR [Node 026] Embedded device config loaded
2023-09-06T13:07:56.898Z CNTRLR [Node 028] Embedded device config loaded
2023-09-06T13:07:56.918Z CNTRLR [Node 030] Embedded device config loaded
2023-09-06T13:07:56.940Z CNTRLR setting serial API timeouts: ack = 1000 ms, byte = 150 ms
2023-09-06T13:07:56.954Z CNTRLR serial API timeouts overwritten. The old values were: ack = 1500 ms, byte = 15
0 ms
2023-09-06T13:07:56.955Z CNTRLR Interview completed
Starting server on 0.0.0.0:3000
2023-09-06T13:07:56.990Z CNTRLR [Node 001] The node is alive.
2023-09-06T13:07:56.992Z CNTRLR [Node 001] The node is ready to be used
2023-09-06T13:07:56.998Z CNTRLR Interviewing nodes and/or determining their status: 10, 3, 4, 9, 22, 24, 8, 7,
2, 25, 21, 6, 5, 11, 23, 30, 12, 26, 15, 28, 18, 19, 29
2023-09-06T13:07:56.999Z CNTRLR » [Node 010] pinging the node...
2023-09-06T13:07:57.141Z CNTRLR » [Node 003] pinging the node...
2023-09-06T13:07:57.144Z CNTRLR » [Node 004] pinging the node...
2023-09-06T13:07:57.149Z CNTRLR » [Node 009] pinging the node...
2023-09-06T13:07:57.152Z CNTRLR » [Node 022] pinging the node...
2023-09-06T13:07:57.155Z CNTRLR » [Node 024] pinging the node...
2023-09-06T13:07:57.158Z CNTRLR » [Node 008] pinging the node...
2023-09-06T13:07:57.162Z CNTRLR » [Node 007] pinging the node...
2023-09-06T13:07:57.166Z CNTRLR » [Node 002] pinging the node...
2023-09-06T13:07:57.169Z CNTRLR » [Node 025] pinging the node...
2023-09-06T13:07:57.173Z CNTRLR » [Node 021] pinging the node...
2023-09-06T13:07:57.176Z CNTRLR » [Node 006] pinging the node...
2023-09-06T13:07:57.178Z CNTRLR » [Node 005] pinging the node...
2023-09-06T13:07:57.182Z CNTRLR » [Node 011] pinging the node...
2023-09-06T13:07:57.185Z CNTRLR » [Node 023] pinging the node...
2023-09-06T13:07:57.189Z CNTRLR [Node 030] The node is asleep.
2023-09-06T13:07:57.193Z CNTRLR [Node 030] The node is ready to be used
2023-09-06T13:07:57.195Z CNTRLR [Node 012] The node is asleep.
2023-09-06T13:07:57.196Z CNTRLR [Node 012] The node is ready to be used
2023-09-06T13:07:57.198Z CNTRLR [Node 026] The node is asleep.
2023-09-06T13:07:57.200Z CNTRLR [Node 026] The node is ready to be used
2023-09-06T13:07:57.201Z CNTRLR [Node 015] The node is asleep.
2023-09-06T13:07:57.203Z CNTRLR [Node 015] The node is ready to be used
2023-09-06T13:07:57.206Z CNTRLR [Node 028] The node is asleep.
2023-09-06T13:07:57.207Z CNTRLR [Node 028] The node is ready to be used
2023-09-06T13:07:57.209Z CNTRLR [Node 018] The node is asleep.
2023-09-06T13:07:57.213Z CNTRLR [Node 018] Beginning interview - last completed stage: ProtocolInfo
2023-09-06T13:07:57.215Z CNTRLR » [Node 018] querying node info...
2023-09-06T13:07:57.220Z CNTRLR [Node 019] The node is asleep.
2023-09-06T13:07:57.222Z CNTRLR [Node 019] Beginning interview - last completed stage: ProtocolInfo
2023-09-06T13:07:57.223Z CNTRLR » [Node 019] querying node info...
2023-09-06T13:07:57.226Z CNTRLR [Node 029] The node is asleep.
2023-09-06T13:07:57.229Z CNTRLR [Node 029] Beginning interview - last completed stage: ProtocolInfo
2023-09-06T13:07:57.229Z CNTRLR » [Node 029] querying node info...
ZwaveJS server listening on 0.0.0.0:3000
2023-09-06T13:07:57.309Z CNTRLR [Node 010] The node is alive.
2023-09-06T13:07:57.311Z CNTRLR [Node 010] The node is ready to be used
2023-09-06T13:07:57.314Z CNTRLR « [Node 010] ping successful
2023-09-06T13:07:57.389Z CNTRLR [Node 003] The node is alive.
2023-09-06T13:07:57.390Z CNTRLR [Node 003] The node is ready to be used
2023-09-06T13:07:57.393Z CNTRLR « [Node 003] ping successful
2023-09-06T13:07:57.429Z CNTRLR [Node 004] The node is alive.
2023-09-06T13:07:57.430Z CNTRLR [Node 004] The node is ready to be used
2023-09-06T13:07:57.433Z CNTRLR « [Node 004] ping successful
2023-09-06T13:07:57.502Z CNTRLR [Node 009] The node is alive.
2023-09-06T13:07:57.505Z CNTRLR [Node 009] The node is ready to be used
2023-09-06T13:07:57.508Z CNTRLR « [Node 009] ping successful
2023-09-06T13:07:57.543Z CNTRLR [Node 022] The node is alive.
2023-09-06T13:07:57.545Z CNTRLR [Node 022] The node is ready to be used
2023-09-06T13:07:57.548Z CNTRLR « [Node 022] ping successful
2023-09-06T13:07:57.608Z CNTRLR [Node 024] The node is alive.
2023-09-06T13:07:57.611Z CNTRLR [Node 024] The node is ready to be used
2023-09-06T13:07:57.615Z CNTRLR « [Node 024] ping successful
2023-09-06T13:07:57.652Z CNTRLR [Node 008] The node is alive.
2023-09-06T13:07:57.653Z CNTRLR [Node 008] The node is ready to be used
2023-09-06T13:07:57.655Z CNTRLR « [Node 008] ping successful
2023-09-06T13:07:57.881Z CNTRLR [Node 007] The node is alive.
2023-09-06T13:07:57.882Z CNTRLR [Node 007] The node is ready to be used
2023-09-06T13:07:57.884Z CNTRLR « [Node 007] ping successful
2023-09-06T13:07:57.920Z CNTRLR [Node 002] The node is alive.
2023-09-06T13:07:57.921Z CNTRLR [Node 002] The node is ready to be used
2023-09-06T13:07:57.924Z CNTRLR « [Node 002] ping successful
2023-09-06T13:07:58.000Z CNTRLR [Node 025] The node is alive.
2023-09-06T13:07:58.002Z CNTRLR [Node 025] The node is ready to be used
2023-09-06T13:07:58.003Z CNTRLR « [Node 025] ping successful
2023-09-06T13:07:58.034Z CNTRLR [Node 021] The node is alive.
2023-09-06T13:07:58.035Z CNTRLR [Node 021] The node is ready to be used
2023-09-06T13:07:58.036Z CNTRLR « [Node 021] ping successful
2023-09-06T13:07:58.068Z CNTRLR [Node 006] The node is alive.
2023-09-06T13:07:58.069Z CNTRLR [Node 006] The node is ready to be used
2023-09-06T13:07:58.071Z CNTRLR « [Node 006] ping successful
2023-09-06T13:07:58.105Z CNTRLR [Node 005] The node is alive.
2023-09-06T13:07:58.107Z CNTRLR [Node 005] The node is ready to be used
2023-09-06T13:07:58.109Z CNTRLR « [Node 005] ping successful
New client
Client disconnected
Code 1000:
New client
2023-09-06T13:08:05.947Z CNTRLR [Node 011] The node did not respond after 1 attempts, it is presumed dead
2023-09-06T13:08:05.949Z CNTRLR [Node 011] The node is dead.
2023-09-06T13:08:05.953Z CNTRLR [Node 011] ping failed: The node did not acknowledge the command (ZW0204)
2023-09-06T13:08:32.097Z CNTRLR [Node 023] The node did not respond after 1 attempts, it is presumed dead
2023-09-06T13:08:32.100Z CNTRLR [Node 023] The node is dead.
2023-09-06T13:08:32.105Z CNTRLR [Node 023] ping failed: The node did not acknowledge the command (ZW0204)
### Additional information
NA
