Zigbee geht nicht
Hallo mein Zigbee geht nicht mehr…Es kommt immer das im LOG
[20:20:37] INFO: Starting Zigbee2MQTT
[2026-04-18 20:20:38\] info: 	z2m: Logging to console, file (filename: log.log)
[2026-04-18 20:20:38\] info: 	z2m: Starting Zigbee2MQTT version 2.9.2 (commit #unknown)
[2026-04-18 20:20:38\] info: 	z2m: Starting zigbee-herdsman (10.0.5)
[2026-04-18 20:20:38\] info: 	zh:zstack:znp: Opening SerialPort with {"path":"/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_b46ea43cbca3ef11be014cbd61ce3355-if00-port0","baudRate":115200,"rtscts":false,"autoOpen":false}
[2026-04-18 20:20:38\] info: 	zh:zstack:znp: Serialport opened
[2026-04-18 20:20:39\] info: 	zh:zstack:znp: Writing CC2530/CC2531 skip bootloader payload
[2026-04-18 20:20:40\] info: 	zh:zstack:znp: Skip bootloader for CC2652/CC1352
[2026-04-18 20:20:58\] error: 	z2m: Error while starting zigbee-herdsman
[2026-04-18 20:20:58\] error: 	z2m: Failed to start zigbee-herdsman
[2026-04-18 20:20:58\] error: 	z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions
[2026-04-18 20:20:58\] error: 	z2m: Exiting...
[2026-04-18 20:20:58\] error: 	z2m: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
    at ZStackAdapter.start (/app/node_modules/.pnpm/zigbee-herdsman@10.0.5/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:107:27)
    at Controller.start (/app/node_modules/.pnpm/zigbee-herdsman@10.0.5/node_modules/zigbee-herdsman/src/controller/controller.ts:146:29)
    at Zigbee.start (/app/lib/zigbee.ts:70:27)
    at Controller.start (/app/lib/controller.ts:111:29)
    at start (/app/index.js:156:5)
https://community.simon42.com/t/mein-zigbee2mqtt-startet-nicht/40462
Danke!
CLOSED, es geht im verlinkten Thread weiter.
