Zigbee 2mqtt sonoff ha green
Also ich versuche jetzt schon seit 3 tagen meinen Sonoff dongle e auf meinem HA green laufen zu kriegen aber ich lande immer in einem Onboarding loop und die Fehlermeldung
\[2025-08-17 13:33:26\] info: 	z2m: Logging to console, file (filename: log.log)
\[2025-08-17 13:33:26\] info: 	z2m: Starting Zigbee2MQTT version 2.6.0 (commit #unknown)
\[2025-08-17 13:33:26\] info: 	z2m: Starting zigbee-herdsman (5.0.4)
\[2025-08-17 13:33:27\] info: 	zh:ember: Using default stack config.
\[2025-08-17 13:33:27\] info: 	zh:ember: ======== Ember Adapter Starting ========
\[2025-08-17 13:33:27\] info: 	zh:ember:ezsp: ======== EZSP starting ========
\[2025-08-17 13:33:27\] info: 	zh:ember:uart:ash: ======== ASH Adapter reset ========
\[2025-08-17 13:33:27\] info: 	zh:ember:uart:ash: RTS/CTS config is off, enabling software flow control.
\[2025-08-17 13:33:27\] info: 	zh:ember:uart:ash: Serial port opened
\[2025-08-17 13:33:27\] info: 	zh:ember:uart:ash: ======== ASH starting ========
\[2025-08-17 13:33:32\] info: 	zh:ember:uart:ash: ======== ASH Adapter reset ========
\[2025-08-17 13:33:32\] info: 	zh:ember:uart:ash: ======== ASH starting ========
\[2025-08-17 13:33:37\] info: 	zh:ember:uart:ash: ======== ASH Adapter reset ========
\[2025-08-17 13:33:37\] info: 	zh:ember:uart:ash: ======== ASH starting ========
\[2025-08-17 13:33:42\] info: 	zh:ember:uart:ash: ======== ASH Adapter reset ========
\[2025-08-17 13:33:42\] info: 	zh:ember:uart:ash: ======== ASH starting ========
\[2025-08-17 13:33:47\] info: 	zh:ember:uart:ash: ======== ASH Adapter reset ========
\[2025-08-17 13:33:47\] info: 	zh:ember:uart:ash: ======== ASH starting ========
\[2025-08-17 13:33:52\] error: 	z2m: Error while starting zigbee-herdsman
\[2025-08-17 13:33:52\] error: 	z2m: Failed to start zigbee-herdsman
\[2025-08-17 13:33:52\] error: 	z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions
\[2025-08-17 13:33:52\] error: 	z2m: Exiting...
\[2025-08-17 13:33:52\] error: 	z2m: Error: Failed to start EZSP layer with status=HOST_FATAL_ERROR.
    at EmberAdapter.initEzsp (/app/node_modules/.pnpm/zigbee-herdsman@5.0.4/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:665:19)
    at EmberAdapter.start (/app/node_modules/.pnpm/zigbee-herdsman@5.0.4/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:1547:24)
    at Controller.start (/app/node_modules/.pnpm/zigbee-herdsman@5.0.4/node_modules/zigbee-herdsman/src/controller/controller.ts:134:29)
    at Zigbee.start (/app/lib/zigbee.ts:67:27)
    at Controller.start (/app/lib/controller.ts:101:13)
    at start (/app/index.js:149:5)
\[13:33:54\] INFO: Preparing to start...
\[13:33:54\] INFO: Socat not enabled
\[13:33:55\] INFO: Starting Zigbee2MQTT...
Onboarding page is available at http://0.0.0.0:8099/
habe schon verschiedene firmware auf den dongle geflasht und keine funktioniert bin ein anfänger bitte um hilfe
Das ist wöchentlich mehrmals Thema hier. Ich vermute eine alte Firmware bzw. eszp statt ember. Oder aber ZHA ist integriert. Schau dich hier einfach mal um.
