heute habe ich festgestellt. Dass mein SONOFF Zigbee 3.0 USB Dongle P Plus (CC2652P + CP2102N) nicht mehr läuft.
Wenn ich unter Integrationen gehe, versucht HA den Dongle immer wieder zu initialisieren. Und das bricht dann jedesmal mit einem Einrichtungsfehler ab.
Das Protokoll gibt so einiges raus. Ich hoffe, ich zeige euch hier das richtige
File "/usr/local/lib/python3.13/site-packages/zigpy_znp/api.py", line 1117, in request_callback_rsp
async with asyncio_timeout(timeout):
File "/usr/local/lib/python3.13/asyncio/timeouts.py", line 116, in __aexit__
raise TimeoutError from exc_val
TimeoutError
2026-02-11 10:38:43.117 ERROR (Thread-16) [homeassistant] Error doing job: Task exception was never retrieved (task: None)
File "/usr/local/lib/python3.13/site-packages/zigpy_znp/api.py", line 1118, in request_callback_rsp
await self.request(request, timeout=timeout, **response_params)
File "/usr/local/lib/python3.13/site-packages/zigpy_znp/api.py", line 1053, in request
async with ctx:
File "/usr/local/lib/python3.13/site-packages/zigpy/datastructures.py", line 35, in __aenter__
await self.on_enter()
File "/usr/local/lib/python3.13/site-packages/zigpy/datastructures.py", line 144, in acquire
await fut
asyncio.exceptions.CancelledError
The above exception was the direct cause of the following exception:
TimeoutError
2026-02-11 10:38:43.127 ERROR (Thread-16) [homeassistant] Error doing job: Task exception was never retrieved (task: None)
async with ctx:
await fut
TimeoutError
2026-02-11 10:38:43.138 ERROR (Thread-16) [homeassistant] Error doing job: Task exception was never retrieved (task: None)
async with ctx:
await fut
TimeoutError
2026-02-11 10:39:49.355 WARNING (MainThread) [zigpy_znp.zigbee.application] Failed to reset before disconnect: 'NoneType' object has no attribute 'write'
2026-02-11 10:40:11.966 WARNING (MainThread) [zigpy_znp.zigbee.application] Failed to reset before disconnect: 'NoneType' object has no attribute 'write'
2026-02-11 10:40:13.457 ERROR (MainThread) [zigpy.zcl] [0x10C6:1:0x0000] Traceback (most recent call last):
File "/usr/local/lib/python3.13/site-packages/zigpy/zcl/__init__.py", line 737, in reply
return await self._endpoint.reply(
...<9 lines>...
File "/usr/local/lib/python3.13/site-packages/zigpy/endpoint.py", line 263, in reply
return await self.device.reply(
...<11 lines>...
File "/usr/local/lib/python3.13/site-packages/zigpy/device.py", line 883, in reply
return await self.request(
...<11 lines>...
File "/usr/local/lib/python3.13/site-packages/zigpy/device.py", line 571, in request
await send_request()
File "/usr/local/lib/python3.13/site-packages/zigpy/application.py", line 1013, in request
await self.send_packet(
...<14 lines>...
File "/usr/local/lib/python3.13/site-packages/zigpy_znp/zigbee/application.py", line 927, in send_packet
await self._send_request_raw(
...<11 lines>...
File "/usr/local/lib/python3.13/site-packages/zigpy_znp/zigbee/application.py", line 823, in _send_request_raw
response = await asyncio.shield(
...<13 lines>...
2026-02-11 10:42:03.187 WARNING (MainThread) [zigpy_znp.zigbee.application] Failed to reset before disconnect: 'NoneType' object has no attribute 'write'
2026-02-11 10:43:38.590 WARNING (MainThread) [zigpy_znp.zigbee.application] Failed to reset before disconnect: 'NoneType' object has no attribute 'write'
2026-02-11 10:45:27.705 WARNING (MainThread) [zigpy_znp.zigbee.application] Failed to reset before disconnect: 'NoneType' object has no attribute 'write'
Infos zu meiner Umgebung:
Raspberry Pi 3 Model B+
HA Version 2026.2.1
Operating System 17.0
ZHA
Wie bekomme ich meinen Sonoff Dongle wieder zum Laufen?
Vielen Dank im Voraus.
Viele Grüße
Lars
