ist meiner erster Post in dem Forum. Hoffe ich habe alle Forumsrichtlinien beachtet.
Ich habe aktuell das Problem, dass ich meinen Sonoff Stick nicht mit Z2M zum laufen bekomme. Ich hab bereits diverse Fehlerdiagnosen durchgeführt, von Z2M deinstalliert, Dongle mit der Standard Sonoff Firmware geflasht, USB-Port gewechselt, ich komme einfach nicht weiter. Am Ende kommt immer folgendes Fehlerbild dabei raus.
[23:39:12] INFO: Preparing to start...
[23:39:12] INFO: Socat not enabled
[23:39:12] INFO: Starting Zigbee2MQTT...
Onboarding page is available at http://0.0.0.0:8099/
[2025-09-15 23:39:52] info: z2m: Logging to console, file (filename: log.log)
[2025-09-15 23:39:52] debug: z2m: Can't load state from file /config/zigbee2mqtt/state.json (doesn't exist)
[2025-09-15 23:39:52] info: z2m: Starting Zigbee2MQTT version 2.6.1 (commit #unknown)
[2025-09-15 23:39:52] info: z2m: Starting zigbee-herdsman (6.0.4)
[2025-09-15 23:39:52] debug: z2m: Using zigbee-herdsman with settings: '"{\"network\":{\"panID\":59236,\"extendedPanID\":[98,253,232,2,152,22,68,6],\"channelList\":[11],\"networkKey\":\"HIDDEN\"},\"databasePath\":\"/config/zigbee2mqtt/database.db\",\"databaseBackupPath\":\"/config/zigbee2mqtt/database.db.backup\",\"backupPath\":\"/config/zigbee2mqtt/coordinator_backup.json\",\"serialPort\":{\"baudRate\":460800,\"rtscts\":false,\"path\":\"/dev/ttyUSB0\",\"adapter\":\"zstack\"},\"adapter\":{\"disableLED\":false}}"'
[2025-09-15 23:39:53] debug: zh:adapter:discovery: Connected devices: [{"path":"/dev/ttyS0"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS3"},{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"427fecf44a4eef11b41148b3174bec31","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_427fecf44a4eef11b41148b3174bec31-if00-port0","vendorId":"10c4","productId":"ea60"}]
[2025-09-15 23:39:53] info: zh:adapter:discovery: Matched adapter: {"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"427fecf44a4eef11b41148b3174bec31","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_427fecf44a4eef11b41148b3174bec31-if00-port0","vendorId":"10c4","productId":"ea60"} => zstack: 4
[2025-09-15 23:39:53] debug: zh:controller: Starting with options '{"network":{"networkKeyDistribute":false,"networkKey":"HIDDEN","panID":59236,"extendedPanID":[98,253,232,2,152,22,68,6],"channelList":[11]},"serialPort":{"baudRate":460800,"rtscts":false,"path":"/dev/ttyUSB0","adapter":"zstack"},"adapter":{"disableLED":false},"databasePath":"/config/zigbee2mqtt/database.db","databaseBackupPath":"/config/zigbee2mqtt/database.db.backup","backupPath":"/config/zigbee2mqtt/coordinator_backup.json"}'
[2025-09-15 23:39:53] info: zh:zstack:znp: Opening SerialPort with {"path":"/dev/ttyUSB0","baudRate":460800,"rtscts":false,"autoOpen":false}
[2025-09-15 23:39:53] info: zh:zstack:znp: Serialport opened
[2025-09-15 23:39:53] debug: zh:zstack:znp: --> SREQ: SYS - ping - {"capabilities":1}
[2025-09-15 23:39:53] debug: zh:zstack:unpi:writer: --> frame [254,0,33,1,32]
[2025-09-15 23:39:53] info: zh:zstack:znp: Writing CC2530/CC2531 skip bootloader payload
[2025-09-15 23:39:53] debug: zh:zstack:unpi:writer: --> buffer [239]
[2025-09-15 23:39:54] debug: zh:zstack:znp: --> SREQ: SYS - ping - {"capabilities":1}
[2025-09-15 23:39:54] debug: zh:zstack:unpi:writer: --> frame [254,0,33,1,32]
[2025-09-15 23:39:54] info: zh:zstack:znp: Skip bootloader for CC2652/CC1352
[2025-09-15 23:39:55] debug: zh:zstack:znp: --> SREQ: SYS - ping - {"capabilities":1}
[2025-09-15 23:39:55] debug: zh:zstack:unpi:writer: --> frame [254,0,33,1,32]
[2025-09-15 23:39:57] debug: zh:zstack:unpi:parser: <-- [128,128,0,120,120,0,128,0,120,128,0,248,0,120,0]
[2025-09-15 23:39:57] debug: zh:zstack:unpi:parser: --- parseNext [128,128,0,120,120,0,128,0,120,128,0,248,0,120,0]
[2025-09-15 23:40:01] debug: zh:zstack:znp: --> SREQ: SYS - ping - {"capabilities":1}
[2025-09-15 23:40:01] debug: zh:zstack:unpi:writer: --> frame [254,0,33,1,32]
[2025-09-15 23:40:07] debug: zh:zstack:znp: --> SREQ: SYS - ping - {"capabilities":1}
[2025-09-15 23:40:07] debug: zh:zstack:unpi:writer: --> frame [254,0,33,1,32]
[2025-09-15 23:40:13] error: z2m: Error while starting zigbee-herdsman
[2025-09-15 23:40:13] error: z2m: Failed to start zigbee-herdsman
[2025-09-15 23:40:13] error: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions
[2025-09-15 23:40:13] error: z2m: Exiting...
[2025-09-15 23:40:13] error: z2m: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
at ZStackAdapter.start (/app/node_modules/.pnpm/zigbee-herdsman@6.0.4/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:114:27)
at Controller.start (/app/node_modules/.pnpm/zigbee-herdsman@6.0.4/node_modules/zigbee-herdsman/src/controller/controller.ts:133:29)
at Zigbee.start (/app/lib/zigbee.ts:67:27)
at Controller.start (/app/lib/controller.ts:101:13)
at start (/app/index.js:149:5)
version: 4
mqtt:
base_topic: zigbee2mqtt
user: addons
password: ohxeifooqu4iemeexaingooWi2OoM0Gaz0aijecah9Ieraithaenat9xe7iathah
serial:
baudrate: 460800
rtscts: false
port: /dev/ttyUSB0
adapter: zstack
advanced:
log_level: debug
channel: 11
network_key:
- 132
- 88
- 171
- 115
- 31
- 113
- 90
- 106
- 114
- 72
- 177
- 66
- 224
- 71
- 203
- 1
pan_id: 59236
ext_pan_id:
- 98
- 253
- 232
- 2
- 152
- 22
- 68
- 6
frontend:
enabled: true
port: 8099
homeassistant:
enabled: true
onboarding: true
Würde mich über weiteren Input freuen.
Danke
