### What happened?
I've several TS130F cover switch. They work well, but sinc…e latest version, they appear with estate "CLOSE" when they are totally opened. The numeric position is right, the state is wrong.
### What did you expect to happen?
Have the state correct.
### How to reproduce it (minimal and precise)
Open the cover. Look at the state of the device. It will appear as CLOSE.
### Zigbee2MQTT version
1.27.2
### Adapter firmware version
20220219
### Adapter
Egony E72
### Debug log
This is a log starting from a cover 100% open and:
- Press close
- Press stop
- Press open
You can see that it ends with a state CLOSE at position 100.
debug 2022-09-02 11:25:09: Received MQTT message on 'zigbee2mqtt/persiana_cocina/set' with data '{"state":"CLOSE"}'
debug 2022-09-02 11:25:09: Publishing 'set' 'state' to 'persiana_cocina'
info 2022-09-02 11:25:09: MQTT publish: topic 'zigbee2mqtt/persiana_cocina', payload '{"backlight_mode":"LOW","calibration":"OFF","calibration_time":null,"last_seen":"2022-09-02T11:25:09+02:00","linkquality":40,"motor_reversal":"OFF","moving":"STOP","position":100,"state":"CLOSE"}'
info 2022-09-02 11:25:09: MQTT publish: topic 'zigbee2mqtt/persiana_cocina/mode', payload '{"backlight":"LOW"}'
debug 2022-09-02 11:25:09: Received Zigbee message from 'persiana_cocina', type 'attributeReport', cluster 'closuresWindowCovering', data '{"currentPositionLiftPercentage":100,"tuyaMovingState":2}' from endpoint 1 with groupID 0
info 2022-09-02 11:25:09: MQTT publish: topic 'zigbee2mqtt/persiana_cocina', payload '{"backlight_mode":"LOW","calibration":"OFF","calibration_time":null,"last_seen":"2022-09-02T11:25:09+02:00","linkquality":43,"motor_reversal":"OFF","moving":"DOWN","position":100,"state":"CLOSE"}'
debug 2022-09-02 11:25:12: Received MQTT message on 'zigbee2mqtt/persiana_cocina/set' with data '{"state":"STOP"}'
debug 2022-09-02 11:25:12: Publishing 'set' 'state' to 'persiana_cocina'
info 2022-09-02 11:25:12: MQTT publish: topic 'zigbee2mqtt/persiana_cocina', payload '{"backlight_mode":"LOW","calibration":"OFF","calibration_time":null,"last_seen":"2022-09-02T11:25:12+02:00","linkquality":47,"motor_reversal":"OFF","moving":"DOWN","position":100,"state":"CLOSE"}'
info 2022-09-02 11:25:12: MQTT publish: topic 'zigbee2mqtt/persiana_cocina/mode', payload '{"backlight":"LOW"}'
debug 2022-09-02 11:25:12: Received Zigbee message from 'persiana_cocina', type 'attributeReport', cluster 'closuresWindowCovering', data '{"currentPositionLiftPercentage":86,"tuyaMovingState":1}' from endpoint 1 with groupID 0
info 2022-09-02 11:25:12: MQTT publish: topic 'zigbee2mqtt/persiana_cocina', payload '{"backlight_mode":"LOW","calibration":"OFF","calibration_time":null,"last_seen":"2022-09-02T11:25:12+02:00","linkquality":47,"motor_reversal":"OFF","moving":"STOP","position":86,"state":"OPEN"}'
debug 2022-09-02 11:25:14: Received MQTT message on 'zigbee2mqtt/persiana_cocina/set' with data '{"state":"OPEN"}'
debug 2022-09-02 11:25:14: Publishing 'set' 'state' to 'persiana_cocina'
info 2022-09-02 11:25:14: MQTT publish: topic 'zigbee2mqtt/persiana_cocina', payload '{"backlight_mode":"LOW","calibration":"OFF","calibration_time":null,"last_seen":"2022-09-02T11:25:14+02:00","linkquality":47,"motor_reversal":"OFF","moving":"STOP","position":86,"state":"OPEN"}'
info 2022-09-02 11:25:14: MQTT publish: topic 'zigbee2mqtt/persiana_cocina/mode', payload '{"backlight":"LOW"}'
debug 2022-09-02 11:25:14: Received Zigbee message from 'persiana_cocina', type 'attributeReport', cluster 'closuresWindowCovering', data '{"currentPositionLiftPercentage":86,"tuyaMovingState":0}' from endpoint 1 with groupID 0
info 2022-09-02 11:25:14: MQTT publish: topic 'zigbee2mqtt/persiana_cocina', payload '{"backlight_mode":"LOW","calibration":"OFF","calibration_time":null,"last_seen":"2022-09-02T11:25:14+02:00","linkquality":47,"motor_reversal":"OFF","moving":"UP","position":86,"state":"OPEN"}'
debug 2022-09-02 11:25:18: Received Zigbee message from 'persiana_cocina', type 'attributeReport', cluster 'closuresWindowCovering', data '{"currentPositionLiftPercentage":100,"tuyaMovingState":1}' from endpoint 1 with groupID 0
info 2022-09-02 11:25:18: MQTT publish: topic 'zigbee2mqtt/persiana_cocina', payload '{"backlight_mode":"LOW","calibration":"OFF","calibration_time":null,"last_seen":"2022-09-02T11:25:18+02:00","linkquality":51,"motor_reversal":"OFF","moving":"STOP","position":100,"state":"CLOSE"}'
info 2022-09-02 11:25:18: MQTT publish: topic 'zigbee2mqtt/persiana_cocina/mode', payload '{"backlight":"LOW"}'
