ich betreibe bei mir etliche Sonoff mini R2 zwecks Rolladensteuerung.
Nun ändert sich ab ESP HOME 2026 die framework definition.
Diese Konfig führt zur Fehlermeldung:
esp32:
board: esp32dev
framework:
type: arduino
ERROR Error binary size: Unknown error from ESP WARNING Failed to upload to \['rsw-30.local'\]
Kann mir jemand helfen wie die richtige Konfig für den Sonoff mini r2 ist?
Grüß
Matthias
INFO ESPHome 2025.10.2 INFO Reading configuration /config/esphome/rsw30.yaml... WARNING Pin 10 (9-10) might already be used by the flash interface in QUAD IO flash mode. INFO Generating C++ source... INFO Compiling app... Processing **rsw-30** (board: esp32dev; framework: arduino, espidf; platform: https://github.com/pioarduino/platform-espressif32/releases/download/54.03.21-2/platform-espressif32.zip) **--------------------------------------------------------------------------------** INFO Package configuration completed successfully INFO Package configuration completed successfully HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash - framework-arduinoespressif32 @ 3.2.1 - framework-arduinoespressif32-libs @ 5.4.0+sha.858a988d6e - framework-espidf @ 3.50402.0 (5.4.2) - tool-cmake @ 3.30.2 - tool-esp-rom-elfs @ 2024.10.11 - tool-esptoolpy @ 5.0.2 - tool-mklittlefs @ 3.2.0 - tool-ninja @ 1.13.1 - tool-scons @ 4.40801.0 (4.8.1) - toolchain-xtensa-esp-elf @ 14.2.0+20241119 Reading CMake configuration... Dependency Graph |-- Networking @ 3.2.1 |-- ESPmDNS @ 3.2.1 |-- Update @ 3.2.1 |-- noise-c @ 0.1.10 |-- ArduinoJson @ 7.4.2 Compiling .pioenvs/rsw-30/src/main.cpp.o **/config/esphome/rsw30.yaml: In lambda function: /config/esphome/rsw30.yaml:61:25: warning: 'void esphome::cover::Cover::open()' is deprecated: open() is deprecated, use make_call().set_command_open().perform() instead. \[-Wdeprecated-declarations\]** 61 | **id(my_cover).open();** | **\~\~\~\~\~\~\~\~\~\~^\~ In file included from src/esphome/core/application.h:51,** from **src/esphome/components/api/api_frame_helper.h:13,** from **src/esphome/components/api/api_connection.h:5,** from **src/esphome.h:3,** from **src/main.cpp:3: src/esphome/components/cover/cover.h:133:8: note: declared here** 133 | void **open();** | **^\~\~\~ /config/esphome/rsw30.yaml:63:26: warning: 'void esphome::cover::Cover::close()' is deprecated: close() is deprecated, use make_call().set_command_close().perform() instead. \[-Wdeprecated-declarations\]** 63 | **id(my_cover).close();** | **\~\~\~\~\~\~\~\~\~\~\~^\~ src/esphome/components/cover/cover.h:139:8: note: declared here** 139 | void **close();** | **^\~\~\~\~ /config/esphome/rsw30.yaml:67:23: warning: 'void esphome::cover::Cover::stop()' is deprecated: stop() is deprecated, use make_call().set_command_stop().perform() instead. \[-Wdeprecated-declarations\]** 67 | **id(my_cover).stop();** | **\~\~\~\~\~\~\~\~\~\~^\~ src/esphome/components/cover/cover.h:146:8: note: declared here** 146 | void **stop();** | **^\~\~\~** Linking .pioenvs/rsw-30/firmware.elf usage: esp_idf_size \[-h\] \[--format {table,text,tree,csv,json2,raw,dot}\] \[--archives\] \[--archive-dependencies\] \[--dep-symbols\] \[--dep-reverse\] \[--archive-details ARCHIVE_NAME\] \[--files\] \[--diff MAP_FILE\] \[--no-abbrev\] \[--unify\] \[--show-unused\] \[--show-unchanged\] \[--use-flash-size\] \[--lto\] \[-d\] \[-o OUTPUT_FILE\] \[-s COLUMN\] \[-F PATTERN\] \[--sort-diff\] \[--sort-reverse\] \[-q\] \[--no-color\] \[--force-terminal\] \[--doc\] MAP_FILE RAM: \[= \] 11.5% (used 37588 bytes from 327680 bytes) Flash: \[===== \] 54.2% (used 994978 bytes from 1835008 bytes) Building .pioenvs/rsw-30/firmware.bin Creating ESP32 image... Successfully created ESP32 image. merge_factory_bin(\[".pioenvs/rsw-30/firmware.bin"\], \[".pioenvs/rsw-30/firmware.elf"\]) Info: bootloader.bin not found - skipping Info: partition-table.bin not found - skipping Info: ota_data_initial.bin not found - skipping Info: rsw-30.bin not found - skipping Using FLASH_EXTRA_IMAGES from PlatformIO environment Merging binaries into /data/build/rsw-30/.pioenvs/rsw-30/firmware.factory.bin Merging binaries with esptool SHA digest in image updated. Wrote 0x103030 bytes to file '/data/build/rsw-30/.pioenvs/rsw-30/firmware.factory.bin', ready to flash to offset 0x0. Successfully created /data/build/rsw-30/.pioenvs/rsw-30/firmware.factory.bin esp32_copy_ota_bin(\[".pioenvs/rsw-30/firmware.bin"\], \[".pioenvs/rsw-30/firmware.elf"\]) Copied firmware to /data/build/rsw-30/.pioenvs/rsw-30/firmware.ota.bin ======================== \[**SUCCESS**\] Took 123.94 seconds ======================== INFO Successfully compiled program. INFO Connecting to 192.168.178.42 port 3232... INFO Connected to 192.168.178.42 INFO Uploading /data/build/rsw-30/.pioenvs/rsw-30/firmware.bin (995376 bytes) ERROR Error binary size: Unknown error from ESP WARNING Failed to upload to \['rsw-30.local'\]
