ESP32 Erstinstallation
Hallo, ich versuche einen ESP32 mit der Erstinstallation zu starten.
Egal ob ich am USB vom Rasspery oder am USB vom PC durchführe, es klappt nicht!
Dies ist die Fehlermeldung:
Hallo, Kannst Du mir sagen, warum mein ESP32 immer die Fehlermeldung bringt und dann mit der Erstinstallation aufhört?
Gruss Rotrigo
" INFO ESPHome 2023.12.8
INFO Reading configuration /config/esphome/esp-home.yaml…
INFO Generating C++ source…
INFO Compiling app…
Processing esp-home (board: esp32dev; framework: arduino; platform: platformio/espressif32@5.4.0)
Library Manager: Installing esphome/AsyncTCP-esphome @ 2.0.1
INFO Installing esphome/AsyncTCP-esphome @ 2.0.1
Unpacking [####################################] 100%
Library Manager: AsyncTCP-esphome@2.0.1 has been installed!
INFO AsyncTCP-esphome@2.0.1 has been installed!
Library Manager: Installing esphome/ESPAsyncWebServer-esphome @ 3.1.0
INFO Installing esphome/ESPAsyncWebServer-esphome @ 3.1.0
Library Manager: ESPAsyncWebServer-esphome@3.1.0 has been installed!
INFO ESPAsyncWebServer-esphome@3.1.0 has been installed!
Library Manager: Resolving dependencies…
INFO Resolving dependencies…
Library Manager: Installing esphome/noise-c @ 0.1.4
INFO Installing esphome/noise-c @ 0.1.4
Library Manager: noise-c@0.1.4 has been installed!
INFO noise-c@0.1.4 has been installed!
Library Manager: Installing esphome/libsodium @ 1.10018.1
INFO Installing esphome/libsodium @ 1.10018.1
Library Manager: libsodium@1.10018.1 has been installed!
INFO libsodium@1.10018.1 has been installed!
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
  • toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch5
    Dependency Graph
    |-- AsyncTCP-esphome @ 2.0.1
    |-- WiFi @ 2.0.0
    |-- FS @ 2.0.0
    |-- Update @ 2.0.0
    |-- ESPAsyncWebServer-esphome @ 3.1.0
    |-- DNSServer @ 2.0.0
    |-- ESPmDNS @ 2.0.0
    |-- noise-c @ 0.1.4
    Compiling .pioenvs/esp-home/src/esphome/components/api/api_connection.cpp.o
    Compiling .pioenvs/esp-home/src/esphome/components/api/api_frame_helper.cpp.o
    Compiling .pioenvs/esp-home/src/esphome/components/api/api_pb2.cpp.o
    Compiling .pioenvs/esp-home/src/esphome/components/api/api_pb2_service.cpp.o
    xtensa-esp32-elf-g++: fatal error: Killed signal terminated program cc1plus
    compilation terminated.
  • [.pioenvs/esp-home/src/esphome/components/api/api_pb2.cpp.o] Error 1
  • [.pioenvs/esp-home/src/esphome/components/api/api_pb2_service.cpp.o] Error 1
    ========================= [FAILED] Took 40.18 seconds ========================
Kann mir jemand dabei helfen?
DANKE
Servus
Verwende einmal ein anders USB Kabel - ich hatte auch mit einem Kabel Probleme
Helmut
hast du mal online flash versucht?
https://web.esphome.io/
Ich habe es auch per PC Versucht. Ich hab den Treiber installiert und konnte dann den ESP 32 flashen. Die Meldung “Online” war da.
Jedoch sind dann alle Update Versuche gescheitert!
Das ist ein Compilerfehler. Ich würde ESPhome deinstallieren und neu installieren und hoffen, dass dann alle Komponenten richtig arbeiten. Es liegt nicht am EPS32 oder Kabel oder Treiber.
Hallo Rotrigo,
ich habe aktuell ein vergleichbares Problem. Was hat bei dir denn am Ende geholfen?
Ist zwar schon bisschen her, aber bei mir war es ein Ressourcenproblem. Ich hab HA auf einem Proxmox laufen und er hatte beim Kompilieren immer an der gleichen Stelle den Error.
Lösung: ESPHome auf meinem Laptop lokal installiert, dort kompiliert und auf das Device hochgeladen.
Der Kommentar hier hat bei mir die Wende gebracht: Compilation fails : xtensa-lx106-elf-g++: fatal error: Killed signal terminated program cc1plus - #21 by HASeeker - ESPHome - Home Assistant Community
Vg
