Smart Meter auslesen mit SML Problem
ich versuche mittels ESP8266 meinen Stromzähler auszulesen. Hierzu habe ich in ESP Home die folgende .yaml geflashed.
esphome:
  friendly_name: Smart_Meter_SML
esp8266:
  board: d1_mini
# Enable logging
logger:
  level: DEBUG
# Enable Home Assistant API
api:
  encryption:
    key: blablabla
ota:
  - platform: esphome
    password: "blablabla"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Smart-Meter-Sml Fallback Hotspot"
    password: blablabla
captive_portal:
uart:
  rx_pin:
  #D7 GPIO13 bei Wemos D1 Mini, other boars may use different Pin Layouts.
    number: D7
    inverted: false
  baud_rate: 9600
  data_bits: 8
  parity: NONE
  stop_bits: 1
  debug:
sml:
  uart_id: uart_bus
text_sensor:
  - platform: sml
    #Change to your Smart Meter Name
    sml_id: mysml
    #server_id: "YOURSERVERID"
    #Change to your server ID as visiable fro the text debug console
    obis_code: "129-129:199.130.3"
    format: text
sensor:
  - platform: sml
    name: "SM_Total energy bought"
    sml_id: mysml
    obis_code: "1-0:1.8.0"
    unit_of_measurement: kWh
    accuracy_decimals: 4
    device_class: energy
    state_class: total_increasing
    filters:
      - multiply: 0.0001
  - platform: sml
    name: "SM_Total energy bought-1.8.2"
    sml_id: mysml
    obis_code: "1-0:1.8.2"
    filters:
      - multiply: 0.0001
  - platform: sml
    name: "SM_Total energy sold"
    sml_id: mysml
    obis_code: "1-0:2.8.0"
    filters:
      - multiply: 0.0001
  - platform: sml
    sml_id: mysml
    obis_code: "1-0:16.7.0"
    unit_of_measurement: W
    accuracy_decimals: 0
    filters:
      - multiply: 0.1
Das hat soweit auch funktioniert. Nun sehe ich allerdings in den logs nur am Anfang in lila die Sensoren, jedoch keine zyklischen Updates in türkis, wie üblich.
[13:38:53.168][I][app:206]: ESPHome version 2026.1.1 compiled on 2026-01-24 13:36:07 +0100
[13:38:53.168][C][logger:316]: Logger:
[13:38:53.168][C][logger:316]:   Max Level: DEBUG
[13:38:53.168][C][logger:316]:   Initial Level: DEBUG
[13:38:53.168][C][logger:322]:   Log Baud Rate: 115200
[13:38:53.168][C][logger:322]:   Hardware UART: UART0
[13:38:53.212][C][uart.arduino_esp8266:137]: UART Bus:
[13:38:53.212][C][uart.arduino_esp8266:152]:   RX Pin: GPIO13
[13:38:53.212][C][uart.arduino_esp8266:141]:   RX Buffer Size: 256
[13:38:53.212][C][uart.arduino_esp8266:143]:   Baud Rate: 9600 baud
[13:38:53.212][C][uart.arduino_esp8266:143]:   Data Bits: 8
[13:38:53.212][C][uart.arduino_esp8266:143]:   Parity: NONE
[13:38:53.212][C][uart.arduino_esp8266:143]:   Stop bits: 1
[13:38:53.212][C][uart.arduino_esp8266:152]:   Using software serial
[13:38:53.226][C][sml:106]: SML:
[13:38:53.229][C][sml_text_sensor:017]: SML 'ED100l'
[13:38:53.230][C][sml_text_sensor:060]:   OBIS Code: 129-129:199.130.3
[13:38:53.251][C][sml_sensor:016]: SML 'SM_Total energy bought'
[13:38:53.251][C][sml_sensor:016]:   State Class: 'total_increasing'
[13:38:53.251][C][sml_sensor:016]:   Unit of Measurement: 'kWh'
[13:38:53.251][C][sml_sensor:016]:   Accuracy Decimals: 4
[13:38:53.257][C][sml_sensor:026]:   Device Class: 'energy'
[13:38:53.257][C][sml_sensor:037]:   OBIS Code: 1-0:1.8.0
[13:38:53.269][C][sml_sensor:016]: SML 'SM_Total energy bought-1.8.2'
[13:38:53.269][C][sml_sensor:016]:   State Class: 'total_increasing'
[13:38:53.269][C][sml_sensor:016]:   Unit of Measurement: 'kWh'
[13:38:53.269][C][sml_sensor:016]:   Accuracy Decimals: 4
[13:38:53.282][C][sml_sensor:026]:   Device Class: 'energy'
[13:38:53.282][C][sml_sensor:037]:   OBIS Code: 1-0:1.8.2
[13:38:53.293][C][sml_sensor:016]: SML 'SM_Total energy sold'
[13:38:53.293][C][sml_sensor:016]:   State Class: 'total_increasing'
[13:38:53.293][C][sml_sensor:016]:   Unit of Measurement: 'kWh'
[13:38:53.293][C][sml_sensor:016]:   Accuracy Decimals: 4
[13:38:53.303][C][sml_sensor:026]:   Device Class: 'energy'
[13:38:53.303][C][sml_sensor:037]:   OBIS Code: 1-0:2.8.0
[13:38:53.314][C][sml_sensor:016]: SML 'Current load'
[13:38:53.314][C][sml_sensor:016]:   State Class: ''
[13:38:53.314][C][sml_sensor:016]:   Unit of Measurement: 'W'
[13:38:53.314][C][sml_sensor:016]:   Accuracy Decimals: 0
[13:38:53.314][C][sml_sensor:026]:   Device Class: 'energy'
[13:38:53.323][C][sml_sensor:037]:   OBIS Code: 1-0:16.7.0
[13:38:53.341][C][captive_portal:128]: Captive Portal:
[13:38:53.353][C][wifi:1304]: WiFi:
[13:38:53.353][C][wifi:1304]:   Local MAC: 48:3F:DA:6E:CB:E4
[13:38:53.353][C][wifi:1304]:   Connected: YES
[13:38:53.353][C][wifi:1037]:   IP Address: 192.168.178.174
[13:38:53.353][C][wifi:1048]:   SSID: [redacted]
[13:38:53.353][C][wifi:1048]:   BSSID: [redacted]
[13:38:53.353][C][wifi:1048]:   Hostname: 'smart-meter-sml'
[13:38:53.353][C][wifi:1048]:   Signal strength: -75 dB ▂▄▆█
[13:38:53.353][C][wifi:1048]:   Channel: 6
[13:38:53.353][C][wifi:1048]:   Subnet: 255.255.255.0
[13:38:53.353][C][wifi:1048]:   Gateway: 192.168.178.1
[13:38:53.353][C][wifi:1048]:   DNS1: 192.168.178.1
[13:38:53.353][C][wifi:1048]:   DNS2: 0.0.0.0
[13:38:53.395][C][esphome.ota:075]: Over-The-Air updates:
[13:38:53.395][C][esphome.ota:075]:   Address: smart-meter-sml.local:8266
[13:38:53.395][C][esphome.ota:075]:   Version: 2
[13:38:53.395][C][esphome.ota:082]:   Password configured
[13:38:53.395][C][safe_mode:021]: Safe Mode:
[13:38:53.395][C][safe_mode:021]:   Successful after: 60s
[13:38:53.395][C][safe_mode:021]:   Invoke after: 10 attempts
[13:38:53.395][C][safe_mode:021]:   Duration: 300s
[13:38:53.416][C][web_server.ota:231]: Web Server OTA
[13:38:53.417][C][api:221]: Server:
[13:38:53.417][C][api:221]:   Address: smart-meter-sml.local:6053
[13:38:53.417][C][api:221]:   Listen backlog: 1
[13:38:53.417][C][api:221]:   Max connections: 4
[13:38:53.417][C][api:228]:   Noise encryption: YES
[13:38:53.658][C][mdns:177]: mDNS:
[13:38:53.658][C][mdns:177]:   Hostname: smart-meter-sml
[13:39:40.541][I][safe_mode:066]: Boot seems successful; resetting boot loop counter
[13:43:48.134][D][wifi:2112]: Roam scan (-73 dBm, attempt 1/3)
Ist das doch normal und ich irre mich nur, oder wo liegt ansonsten mein Fehler?
Kann mir vielleicht jemand seine yaml und logs zeigen? Das würde mir schon weiterhelfen.
Vielen Dank!
Ich lese meinen Zähler mit einen IR Lesekopf mit Tasmota aus.
Dazu musste ich bei meinem Zähler erst mal den Pin eingeben und auch die Schnittstelle aktivieren.
Hast Du das bei Dir auch gemacht?
Danke für deine schnelle Antwort. Ja, die PIN hatte ich schon eingegeben.
Es funktioniert leider immer noch nicht. Hat jemand noch andere Ideen?
Das mit Tasmota wäre mein nächster Versuch, falls es mit dem Auslesen per IR Diode nicht klappen wird. Allerdings möchte ich noch nicht so schnell aufgeben.
