Hat alles gut geklappt, allerdings bekomme ich über den HmIP RFUSB stick nix angelernt
Der Stick wird im Protokoll erkannt mit "ok"
auch im Posteingang zu finden , aber er erkennt halt nix findet kein Gerät
***** /var/log/boot.log *****
Mounting /data as /usr/local (Home Assistant Add-On): OK
Identifying host system: oci, OK
Initializing RTC Clock: onboard, OK
Running sysctl: OK
Checking for Factory Reset: not required
Checking for Backup Restore: OK: backup successfully restored
Initializing System: OK
Setup ca-certificates: OK
Starting logging: OK
Init onboard LEDs: init, OK
Starting irqbalance: OK
Starting iptables: OK
Starting network: eth0: link up, fixed, firewall, inet up, 172.30.33.6, OK
Identifying Homematic RF-Hardware: ....HmRF: HMIP-RFUSB/eQ-3 HmIP-RFUSB@usb-0000:00:14.0-2, HmIP: HMIP-RFUSB/eQ-3 HmIP-RFUSB@usb-0000:00:14.0-2, OK
Updating Homematic RF-Hardware: HMIP-RFUSB: 4.4.18, not necessary, OK
Starting hs485dLoader: disabled
Starting xinetd: OK
Starting eq3configd: OK
Starting lighttpd: OK
Starting ser2net: disabled
Starting ssdpd: OK
Starting sshd: OK
Starting ha-proxy: OK
Starting NUT services: disabled
Initializing Third-Party Addons: OK
Starting LGWFirmwareUpdate: ...OK
Setting LAN Gateway keys: OK
Starting hs485d: disabled
Starting multimacd: .......OK
Starting rfd: .OK
Starting HMIPServer: ........OK
Starting ReGaHss: .OK
Starting CloudMatic: OK
Starting Third-Party Addons: OK
Starting crond: OK
Setup onboard LEDs: booted, OK
Finished Boot: 3.67.10.20230130 (raspmatic_oci_amd64)
