### What happened?
When using the OTA functionality Zigbee2MQTT concludes that …the version 1.0.024 is newer than the firmware available online 2.4.5, so it won't update the device.
I've tried forcing the update, but that didn't work. To accomplish that I've renamed the index.json from pull request https://github.com/Koenkk/zigbee-OTA/pull/340 to my_index.json and put it in \config\zigbee2mqtt in Home Assistant and entered /config/zigbee2mqtt/my_index.json in Zigbee2MQTT as the OTA index override file name.
### What did you expect to happen?
I would have liked the device to update to the latests firmware.
### How to reproduce it (minimal and precise)
Press "Check for new updates" on a Ikea Styrbar in the OTA-menu.
### Zigbee2MQTT version
1.32.2-dev commit: 68ec507
### Adapter firmware version
20220928
### Adapter
CC2652RB
### Debug log
info 2023-08-03 22:04:53: Checking if update available for 'Drukknop voordeur'
info 2023-08-03 22:04:53: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":"Checking if update available for 'Drukknop voordeur'","meta":{"device":"Drukknop voordeur","status":"checking_if_available"},"type":"ota_update"}'
debug 2023-08-03 22:04:53: Check if update available for '0x540f57fffe8f81f0' (Remote Control N2)
debug 2023-08-03 22:04:53: Using endpoint '1'
debug 2023-08-03 22:04:54: Received Zigbee message from 'Drukknop voordeur', type 'commandOff', cluster 'genOnOff', data '{}' from endpoint 1 with groupID 0
info 2023-08-03 22:04:54: MQTT publish: topic 'zigbee2mqtt/Drukknop voordeur', payload '{"action":"off","battery":100,"last_seen":"2023-08-03T22:04:54+02:00","linkquality":36,"update":{"installed_version":65572,"latest_version":581,"state":"idle"},"update_available":false}'
info 2023-08-03 22:04:54: MQTT publish: topic 'zigbee2mqtt/Drukknop voordeur', payload '{"action":"","battery":100,"last_seen":"2023-08-03T22:04:54+02:00","linkquality":36,"update":{"installed_version":65572,"latest_version":581,"state":"idle"},"update_available":false}'
info 2023-08-03 22:04:54: MQTT publish: topic 'zigbee2mqtt/Drukknop voordeur/action', payload 'off'
info 2023-08-03 22:04:54: MQTT publish: topic 'zigbee2mqtt/Drukknop voordeur', payload '{"action":null,"battery":100,"last_seen":"2023-08-03T22:04:54+02:00","linkquality":36,"update":{"installed_version":65572,"latest_version":581,"state":"idle"},"update_available":false}'
debug 2023-08-03 22:04:56: Received Zigbee message from 'Drukknop voordeur', type 'commandTradfriArrowSingle', cluster 'genScenes', data '{"value":256,"value2":13}' from endpoint 1 with groupID 0
info 2023-08-03 22:04:56: MQTT publish: topic 'zigbee2mqtt/Drukknop voordeur', payload '{"action":"arrow_right_click","battery":100,"last_seen":"2023-08-03T22:04:56+02:00","linkquality":36,"update":{"installed_version":65572,"latest_version":581,"state":"idle"},"update_available":false}'
info 2023-08-03 22:04:56: MQTT publish: topic 'zigbee2mqtt/Drukknop voordeur', payload '{"action":"","battery":100,"last_seen":"2023-08-03T22:04:56+02:00","linkquality":36,"update":{"installed_version":65572,"latest_version":581,"state":"idle"},"update_available":false}'
info 2023-08-03 22:04:56: MQTT publish: topic 'zigbee2mqtt/Drukknop voordeur/action', payload 'arrow_right_click'
info 2023-08-03 22:04:56: MQTT publish: topic 'zigbee2mqtt/Drukknop voordeur', payload '{"action":null,"battery":100,"last_seen":"2023-08-03T22:04:56+02:00","linkquality":36,"update":{"installed_version":65572,"latest_version":581,"state":"idle"},"update_available":false}'
debug 2023-08-03 22:04:57: Received Zigbee message from 'Drukknop voordeur', type 'commandTradfriArrowSingle', cluster 'genScenes', data '{"value":257,"value2":13}' from endpoint 1 with groupID 0
info 2023-08-03 22:04:57: MQTT publish: topic 'zigbee2mqtt/Drukknop voordeur', payload '{"action":"arrow_left_click","battery":100,"last_seen":"2023-08-03T22:04:57+02:00","linkquality":36,"update":{"installed_version":65572,"latest_version":581,"state":"idle"},"update_available":false}'
info 2023-08-03 22:04:57: MQTT publish: topic 'zigbee2mqtt/Drukknop voordeur', payload '{"action":"","battery":100,"last_seen":"2023-08-03T22:04:57+02:00","linkquality":36,"update":{"installed_version":65572,"latest_version":581,"state":"idle"},"update_available":false}'
info 2023-08-03 22:04:57: MQTT publish: topic 'zigbee2mqtt/Drukknop voordeur/action', payload 'arrow_left_click'
info 2023-08-03 22:04:57: MQTT publish: topic 'zigbee2mqtt/Drukknop voordeur', payload '{"action":null,"battery":100,"last_seen":"2023-08-03T22:04:57+02:00","linkquality":36,"update":{"installed_version":65572,"latest_version":581,"state":"idle"},"update_available":false}'
debug 2023-08-03 22:04:57: Received Zigbee message from 'Drukknop voordeur', type 'commandQueryNextImageRequest', cluster 'genOta', data '{"fieldControl":1,"fileVersion":65572,"imageType":4555,"manufacturerCode":4476}' from endpoint 1 with groupID 0
debug 2023-08-03 22:04:57: Got OTA request '{"fieldControl":1,"manufacturerCode":4476,"imageType":4555,"fileVersion":65572}'
debug 2023-08-03 22:04:58: Received Zigbee message from 'Drukknop voordeur', type 'commandOn', cluster 'genOnOff', data '{}' from endpoint 1 with groupID 0
info 2023-08-03 22:04:58: MQTT publish: topic 'zigbee2mqtt/Drukknop voordeur', payload '{"action":"on","battery":100,"last_seen":"2023-08-03T22:04:58+02:00","linkquality":32,"update":{"installed_version":65572,"latest_version":581,"state":"idle"},"update_available":false}'
info 2023-08-03 22:04:58: MQTT publish: topic 'zigbee2mqtt/Drukknop voordeur', payload '{"action":"","battery":100,"last_seen":"2023-08-03T22:04:58+02:00","linkquality":32,"update":{"installed_version":65572,"latest_version":581,"state":"idle"},"update_available":false}'
info 2023-08-03 22:04:58: MQTT publish: topic 'zigbee2mqtt/Drukknop voordeur/action', payload 'on'
info 2023-08-03 22:04:58: MQTT publish: topic 'zigbee2mqtt/Drukknop voordeur', payload '{"action":null,"battery":100,"last_seen":"2023-08-03T22:04:58+02:00","linkquality":36,"update":{"installed_version":65572,"latest_version":581,"state":"idle"},"update_available":false}'
debug 2023-08-03 22:04:58: Is new image available for '0x540f57fffe8f81f0', current '{"fieldControl":1,"manufacturerCode":4476,"imageType":4555,"fileVersion":65572}', latest meta '{"fileVersion":581,"url":"http://fw.ota.homesmart.ikea.net/global/GW1.0/01.20.065/bin/10078031-zingo_kt_styrbar_remote-2.4.5.ota.ota.signed"}'
debug 2023-08-03 22:04:58: Update available for '0x540f57fffe8f81f0': NO
warn 2023-08-03 22:04:58: Firmware on '0x540f57fffe8f81f0' is newer than latest firmware online.
info 2023-08-03 22:04:58: No update available for 'Drukknop voordeur'
