OTBR schaltet ab!?
Guten Morgen zusammen!
könntet ihr bitte mal über mein Log vom OTBR schauen, und mir auf die Sprünge helfen.
Irgendwie sehe ich den Wald vor lauter Bäumen nimmer…
Herzlichen Dank und Grüße,
Tim
Add-on: OpenThread Border Router
 OpenThread Border Router add-on
 Add-on version: 2.16.8
 You are running the latest version of this add-on.
 System: Home Assistant OS 17.3  (aarch64 / yellow)
 Home Assistant Core: 2026.5.4
 Home Assistant Supervisor: 2026.05.0
 Please, share the above information when looking for help
 or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service banner successfully started
s6-rc: info: service otbr-agent: starting
[10:50:37] INFO: Setup OTBR firewall...
[10:50:38] INFO: Migrating OTBR settings if needed...
2026-05-27 10:50:38 homeassistant asyncio[245] DEBUG Using selector: EpollSelector
2026-05-27 10:50:38 homeassistant zigpy.serial[245] DEBUG Opening a serial connection to '/dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_8683cd0618c3ef11a9a1e2b08048b910-if00-port0' (baudrate=460800, xonxoff=False, rtscts=False)
2026-05-27 10:50:38 homeassistant serialx.platforms.serial_posix[245] DEBUG Configuring serial port '/dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_8683cd0618c3ef11a9a1e2b08048b910-if00-port0'
2026-05-27 10:50:38 homeassistant serialx.platforms.serial_posix[245] DEBUG Configuring serial port: [0, 0, 3248, 0, 4100, 4100, [b'\x03', b'\x1c', b'\x7f', b'\x15', b'\x04', 0, 0, b'\x00', b'\x11', b'\x13', b'\x1a', b'\x00', b'\x12', b'\x0f', b'\x17', b'\x16', b'\x00', b'\x00', b'\x00', b'\x00', b'\x00', b'\x00', b'\x00', b'\x00', b'\x00', b'\x00', b'\x00', b'\x00', b'\x00', b'\x00', b'\x00', b'\x00']]
2026-05-27 10:50:38 homeassistant serialx.platforms.serial_posix[245] DEBUG Setting low latency mode: True
2026-05-27 10:50:38 homeassistant serialx.platforms.serial_posix[245] DEBUG Setting modem pins: ModemPins[!dtr !rts]
2026-05-27 10:50:38 homeassistant serialx.platforms.serial_posix[245] DEBUG TIOCMBIC: 0x00000006
2026-05-27 10:50:38 homeassistant zigpy.serial[245] DEBUG Connection made: <serialx.platforms.serial_posix.PosixSerialTransport object at 0x7f95fa0850>
2026-05-27 10:50:38 homeassistant universal_silabs_flasher.spinel[245] DEBUG Sending frame SpinelFrame(header=SpinelHeader(transaction_id=0, network_link_id=0, flag=2), command_id=<CommandID.RESET: 1>, data=b'\x02')
2026-05-27 10:50:38 homeassistant universal_silabs_flasher.spinel[245] DEBUG Sending data b'~\x80\x01\x02\xea\xf0~'
2026-05-27 10:50:38 homeassistant serialx.descriptor_transport[245] DEBUG Immediately writing b'~\x80\x01\x02\xea\xf0~'
2026-05-27 10:50:38 homeassistant serialx.descriptor_transport[245] DEBUG Sent 7 of 7 bytes
2026-05-27 10:50:38 homeassistant serialx.descriptor_transport[245] DEBUG Event loop woke up reader
2026-05-27 10:50:38 homeassistant serialx.descriptor_transport[245] DEBUG Received b'~\x80\x06\x00p\xeet~'
2026-05-27 10:50:38 homeassistant universal_silabs_flasher.spinel[245] DEBUG Decoded HDLC frame: HDLCLiteFrame(data=b'\x80\x06\x00p')
2026-05-27 10:50:38 homeassistant universal_silabs_flasher.spinel[245] DEBUG Parsed frame SpinelFrame(header=SpinelHeader(transaction_id=0, network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_IS: 6>, data=b'\x00p')
2026-05-27 10:50:38 homeassistant universal_silabs_flasher.spinel[245] DEBUG Sending frame SpinelFrame(header=SpinelHeader(transaction_id=3, network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b'\x08')
2026-05-27 10:50:38 homeassistant universal_silabs_flasher.spinel[245] DEBUG Sending data b'~\x83\x02\x08\xbc\x9a~'
2026-05-27 10:50:38 homeassistant serialx.descriptor_transport[245] DEBUG Immediately writing b'~\x83\x02\x08\xbc\x9a~'
2026-05-27 10:50:38 homeassistant serialx.descriptor_transport[245] DEBUG Received b'~\x83\x06\x08\x8c\x8bH\xff\xfeN\xe0\xd8\xf0^~'
2026-05-27 10:50:38 homeassistant universal_silabs_flasher.spinel[245] DEBUG Decoded HDLC frame: HDLCLiteFrame(data=b'\x83\x06\x08\x8c\x8bH\xff\xfeN\xe0\xd8')
2026-05-27 10:50:38 homeassistant universal_silabs_flasher.spinel[245] DEBUG Parsed frame SpinelFrame(header=SpinelHeader(transaction_id=3, network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_IS: 6>, data=b'\x08\x8c\x8bH\xff\xfeN\xe0\xd8')
2026-05-27 10:50:38 homeassistant serialx.descriptor_transport[245] DEBUG Closing at the request of the application
2026-05-27 10:50:38 homeassistant zigpy.serial[245] DEBUG Waiting for serial port to close
2026-05-27 10:50:38 homeassistant serialx.descriptor_transport[245] DEBUG Closing connection: None
2026-05-27 10:50:38 homeassistant serialx.descriptor_transport[245] DEBUG Closing file descriptor 7
2026-05-27 10:50:38 homeassistant serialx.descriptor_transport[245] DEBUG Calling protocol `connection_lost` with exc=None
2026-05-27 10:50:38 homeassistant zigpy.serial[245] DEBUG Connection lost: None
Adapter settings file /data/thread/0_8c8b48fffe4ee0d8.data is the most recently used, skipping
[10:50:38] INFO: Starting otbr-agent...
[NOTE]-AGENT---: Running 0.3.0-b067e5ac-dirty
[NOTE]-AGENT---: Thread version: 1.3.0
[NOTE]-AGENT---: Thread interface: wpan0
[NOTE]-AGENT---: Radio URL: spinel+hdlc+uart:///dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_8683cd0618c3ef11a9a1e2b08048b910-if00-port0?uart-baudrate=460800&uart-init-deassert
[NOTE]-AGENT---: Radio URL: trel://end0
[NOTE]-ILS-----: Infra link selected: end0
51d.15:02:03.245 [C] P-SpinelDrive-: Software reset co-processor successfully
00:00:00.051 [N] RoutingManager: BR ULA prefix: fdd9:8b29:bd9d::/48 (loaded)
00:00:00.051 [N] RoutingManager: Local on-link prefix: fd7d:6563:e675:5329::/64
00:00:00.068 [N] Mle-----------: Role disabled -> detached
00:00:00.079 [N] P-Netif-------: Changing interface state to up.
00:00:00.090 [W] P-Netif-------: Failed to process request#2: No such process
00:00:00.090 [W] P-Netif-------: Failed to process request#6: No such process
Connection to 172.30.32.1 8081 port [tcp/tproxy] succeeded!
s6-rc: info: service otbr-agent successfully started
s6-rc: info: service otbr-agent-configure: starting
Done
00:00:00.298 [W] P-Daemon------: Daemon read: Connection reset by peer
Done
s6-rc: info: service otbr-agent-configure successfully started
s6-rc: info: service otbr-agent-rest-discovery: starting
00:00:00.358 [W] P-Daemon------: Failed to write CLI output: Broken pipe
[10:50:38] INFO: Successfully sent discovery information to Home Assistant.
s6-rc: info: service otbr-agent-rest-discovery successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
00:00:27.697 [N] Mle-----------: RLOC16 5000 -> fffe
00:00:27.855 [N] Mle-----------: Attach attempt 1, AnyPartition reattaching with Active Dataset
00:00:34.355 [N] RouterTable---: Allocate router id 20
00:00:34.355 [N] Mle-----------: RLOC16 fffe -> 5000
00:00:34.358 [N] Mle-----------: Role detached -> leader
00:00:34.358 [N] Mle-----------: Partition ID 0x2d3700ff
[NOTE]-BBA-----: BackboneAgent: Backbone Router becomes Primary!
00:00:38.208 [W] DuaManager----: Failed to perform next registration: NotFound
00:01:28.073 [W] P-RadioSpinel-: radio tx timeout
00:01:28.073 [W] P-RadioSpinel-: RCP failure detected
00:01:28.073 [W] P-RadioSpinel-: Trying to recover (1/2)
00:01:30.075 [W] P-RadioSpinel-: Wait for response timeout
00:01:30.075 [W] P-RadioSpinel-: RCP failure detected
00:01:30.075 [W] P-RadioSpinel-: Trying to recover (2/2)
00:01:32.077 [W] P-RadioSpinel-: Wait for response timeout
00:01:32.077 [W] P-RadioSpinel-: RCP failure detected
00:01:32.077 [C] P-RadioSpinel-: Too many rcp failures, exiting
00:01:32.077 [C] Platform------: RecoverFromRcpFailure() at radio_spinel.cpp:2063: Failure
[10:52:10] WARNING: otbr-agent exited with code 1 (by signal 0).
Chain OTBR_FORWARD_INGRESS (0 references)
target     prot opt source               destination
DROP       all  --  anywhere             anywhere             PKTTYPE = unicast
DROP       all  --  anywhere             anywhere             match-set otbr-ingress-deny-src src
ACCEPT     all  --  anywhere             anywhere             match-set otbr-ingress-allow-dst dst
otbr-ingress-deny-src-swap
otbr-ingress-allow-dst-swap
Chain OTBR_FORWARD_EGRESS (0 references)
[10:52:10] INFO: OTBR firewall/NAT64 rules teardown completed.
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service otbr-agent-rest-discovery: stopping
s6-rc: info: service otbr-agent-rest-discovery successfully stopped
s6-rc: info: service otbr-agent-configure: stopping
s6-rc: info: service otbr-agent-configure successfully stopped
s6-rc: info: service otbr-agent: stopping
s6-rc: info: service otbr-agent successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service banner: stopping
s6-rc: info: service mdns: stopping
Default: mDNSResponder (Engineering Build) (May  6 2026 09:56:44) stopping
s6-rc: info: service banner successfully stopped
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: warning: service s6rc-oneshot-runner is marked as essential, not stopping it
[10:52:10] INFO: mDNS ended with exit code 4 (signal 0)...
s6-rc: info: service mdns successfully stopped
Versuchst Du Matter und Zigbee gleichzeitig (über ein Gerät) zu verwenden?
Ich meine, gelesen zu haben, dass das nicht mehr unterstützt wird.
Nein, Zigbee läuft auf dem Yellow selbst…
