ZBT-1 Stick OTBR Homeassistant
Ich bin neu hier und hätte eine Frage zur Installation bzw. Zum OBTR in Homeassistant.
Ich habe meinen Sick angeschlossen und entsprechend Konfiguriert.
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service mdns successfully started
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service banner: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
[12:57:27] INFO: Starting mDNS Responder...
Default: mDNSResponder (Engineering Build) (Dec 15 2025 09:15:25) starting
 Add-on: OpenThread Border Router
 OpenThread Border Router add-on
 Add-on version: 2.15.3
 You are running the latest version of this add-on.
 System: Home Assistant OS 16.3  (aarch64 / raspberrypi4-64)
 Home Assistant Core: 2025.12.4
 Home Assistant Supervisor: 2025.12.3
 Please, share the above information when looking for help
 or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service banner successfully started
s6-rc: info: service otbr-agent: starting
[12:57:32] INFO: Setup OTBR firewall...
[12:57:33] INFO: Migrating OTBR settings if needed...
2025-12-20 12:57:33 homeassistant asyncio[226] DEBUG Using selector: EpollSelector
2025-12-20 12:57:33 homeassistant zigpy.serial[226] DEBUG Opening a serial connection to '/dev/serial/by-id/usb-Nabu_Casa_Home_Assistant_Connect_ZBT-1_069fe0be6ff7ed11a3403372024206e6-if00-port0' (baudrate=460800, xonxoff=False, rtscts=True)
2025-12-20 12:57:33 homeassistant serialx.platforms.serial_posix[226] DEBUG Configuring serial port '/dev/serial/by-id/usb-Nabu_Casa_Home_Assistant_Connect_ZBT-1_069fe0be6ff7ed11a3403372024206e6-if00-port0'
2025-12-20 12:57:33 homeassistant serialx.platforms.serial_posix[226] DEBUG Configuring serial port: [0, 0, 2147486896, 0, 4100, 4100, [b'\x03', b'\x1c', b'\x7f', b'\x15', b'\x04', 0, 0, b'\x00', b'\x11', b'\x13', b'\x1a', b'\x00', b'\x12', b'\x0f', b'\x17', b'\x16', b'\x00', b'\x00', b'\x00', b'\x00', b'\x00', b'\x00', b'\x00', b'\x00', b'\x00', b'\x00', b'\x00', b'\x00', b'\x00', b'\x00', b'\x00', b'\x00']]
2025-12-20 12:57:33 homeassistant serialx.platforms.serial_posix[226] DEBUG Setting low latency mode: True
2025-12-20 12:57:33 homeassistant serialx.platforms.serial_posix[226] DEBUG Setting modem pins: ModemPins[dtr rts]
2025-12-20 12:57:33 homeassistant serialx.platforms.serial_posix[226] DEBUG Setting TIOCMBIS: 0x00000006
2025-12-20 12:57:33 homeassistant zigpy.serial[226] DEBUG Connection made: <serialx.platforms.serial_posix.PosixSerialTransport object at 0x7fa91b7a10>
2025-12-20 12:57:33 homeassistant universal_silabs_flasher.spinel[226] DEBUG Sending frame SpinelFrame(header=SpinelHeader(transaction_id=0, network_link_id=0, flag=2), command_id=<CommandID.RESET: 1>, data=b'\x02')
2025-12-20 12:57:33 homeassistant universal_silabs_flasher.spinel[226] DEBUG Sending data b'~\x80\x01\x02\xea\xf0~'
2025-12-20 12:57:33 homeassistant serialx.descriptor_transport[226] DEBUG Immediately writing b'~\x80\x01\x02\xea\xf0~'
2025-12-20 12:57:33 homeassistant serialx.descriptor_transport[226] DEBUG Sent 7 of 7 bytes
2025-12-20 12:57:33 homeassistant serialx.descriptor_transport[226] DEBUG Event loop woke up reader
2025-12-20 12:57:33 homeassistant serialx.descriptor_transport[226] DEBUG Received b'~\x80\x06\x00p\xeet~'
2025-12-20 12:57:33 homeassistant universal_silabs_flasher.spinel[226] DEBUG Decoded HDLC frame: HDLCLiteFrame(data=b'\x80\x06\x00p')
2025-12-20 12:57:33 homeassistant universal_silabs_flasher.spinel[226] DEBUG Parsed frame SpinelFrame(header=SpinelHeader(transaction_id=0, network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_IS: 6>, data=b'\x00p')
2025-12-20 12:57:33 homeassistant universal_silabs_flasher.spinel[226] DEBUG Sending frame SpinelFrame(header=SpinelHeader(transaction_id=3, network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b'\x08')
2025-12-20 12:57:33 homeassistant universal_silabs_flasher.spinel[226] DEBUG Sending data b'~\x83\x02\x08\xbc\x9a~'
2025-12-20 12:57:33 homeassistant serialx.descriptor_transport[226] DEBUG Immediately writing b'~\x83\x02\x08\xbc\x9a~'
2025-12-20 12:57:34 homeassistant serialx.descriptor_transport[226] DEBUG Event loop woke up reader
2025-12-20 12:57:34 homeassistant serialx.descriptor_transport[226] DEBUG Received b'~\x83\x06\x08l\\\xb1\xff\xfe*\xa6\xcf\xad\x80~'
2025-12-20 12:57:34 homeassistant universal_silabs_flasher.spinel[226] DEBUG Decoded HDLC frame: HDLCLiteFrame(data=b'\x83\x06\x08l\\\xb1\xff\xfe*\xa6\xcf')
2025-12-20 12:57:34 homeassistant universal_silabs_flasher.spinel[226] DEBUG Parsed frame SpinelFrame(header=SpinelHeader(transaction_id=3, network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_IS: 6>, data=b'\x08l\\\xb1\xff\xfe*\xa6\xcf')
2025-12-20 12:57:34 homeassistant serialx.descriptor_transport[226] DEBUG Closing at the request of the application
2025-12-20 12:57:34 homeassistant zigpy.serial[226] DEBUG Waiting for serial port to close
2025-12-20 12:57:34 homeassistant serialx.descriptor_transport[226] DEBUG Closing connection: None
2025-12-20 12:57:34 homeassistant serialx.descriptor_transport[226] DEBUG Closing file descriptor 7
2025-12-20 12:57:34 homeassistant serialx.descriptor_transport[226] DEBUG Calling protocol `connection_lost` with exc=None
2025-12-20 12:57:34 homeassistant zigpy.serial[226] DEBUG Connection lost: None
Adapter settings file /data/thread/0_6c5cb1fffe2aa6cf.data is the most recently used, skipping
[12:57:34] INFO: Starting otbr-agent...
[NOTE]-AGENT---: Running 0.3.0-b067e5ac-dirty
[NOTE]-AGENT---: Thread version: 1.3.0
[NOTE]-AGENT---: Thread interface: wpan0
[NOTE]-AGENT---: Radio URL: spinel+hdlc+uart:///dev/serial/by-id/usb-Nabu_Casa_Home_Assistant_Connect_ZBT-1_069fe0be6ff7ed11a3403372024206e6-if00-port0?uart-baudrate=460800&uart-flow-control
[NOTE]-AGENT---: Radio URL: trel://end0
[NOTE]-ILS-----: Infra link selected: end0
41d.17:41:15.331 [C] P-SpinelDrive-: Software reset co-processor successfully
00:00:00.061 [N] RoutingManager: BR ULA prefix: fd7f:b292:aef::/48 (loaded)
00:00:00.061 [N] RoutingManager: Local on-link prefix: fd15:fa1e:8d44:4b33::/64
00:00:00.178 [N] Mle-----------: Role disabled -> detached
00:00:00.221 [N] P-Netif-------: Changing interface state to up.
s6-rc: info: service otbr-agent successfully started
s6-rc: info: service otbr-agent-configure: starting
00:00:00.316 [W] P-Netif-------: Failed to process request#2: No such Prozess
00:00:00.319 [W] P-Netif-------: Failed to process request#6: No such process
00:00:00.528 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
Done
s6-rc: info: service otbr-agent-configure successfully started
s6-rc: info: service otbr-agent-rest-discovery: starting
00:00:00.754 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:01.012 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:01.263 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:01.511 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:01.758 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:01.989 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:02.228 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:02.492 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
[12:57:36] INFO: Successfully sent discovery information to Home Assistant.
s6-rc: info: service otbr-agent-rest-discovery successfully started
s6-rc: info: service legacy-services: starting
00:00:02.709 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
s6-rc: info: service legacy-services successfully started
00:00:02.932 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:03.160 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:03.415 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:03.634 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:03.858 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:04.123 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:04.338 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:04.584 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:04.810 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:05.030 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:05.274 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:05.829 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:10.318 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:15.761 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:20.877 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:25.486 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:27.246 [N] Mle-----------: RLOC16 d400 -> fffe
00:00:27.804 [N] Mle-----------: Attach attempt 1, AnyPartition reattaching with Active Dataset
00:00:28.017 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:28.774 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:29.511 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:30.793 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:32.040 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:33.311 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:34.304 [N] RouterTable---: Allocate router id 53
00:00:34.304 [N] Mle-----------: RLOC16 fffe -> d400
00:00:34.307 [N] Mle-----------: Role detached -> leader
00:00:34.309 [N] Mle-----------: Partition ID 0x59f1a4a2
00:00:34.663 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
[NOTE]-BBA-----: BackboneAgent: Backbone Router becomes Primary!
00:00:35.097 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:35.352 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:35.567 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:36.947 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:37.772 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:37.823 [W] DuaManager----: Failed to perform next registration: NotFound
00:00:40.865 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:45.845 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:46.069 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:48.943 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:57.573 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:01:09.468 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:01:23.039 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
Kann mir jemand weiterhelfen?
Danke
