Ich habe es etwas umgebaut. Jetzt funktioniert es.
[{"id":"8ffb6fb73433cd45","type":"tab","label":"Endgeräte","disabled":false,"info":"","env":[]},{"id":"404b8cee12e547b6","type":"api-call-service","z":"8ffb6fb73433cd45","name":"Lichtprüfer einschalten","server":"d6e1a14d.333e1","version":5,"debugenabled":false,"domain":"switch","service":"turn_on","areaId":[],"deviceId":[],"entityId":["switch.wohnzimmer_lichtprufer"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":500,"y":220,"wires":[[]]},{"id":"0e5e54916c0de8b7","type":"api-call-service","z":"8ffb6fb73433cd45","name":"Licht an","server":"d6e1a14d.333e1","version":5,"debugenabled":false,"domain":"light","service":"turn_on","areaId":[],"deviceId":[],"entityId":["light.esstisch_oben","light.esstisch_unten","light.palme","light.sofa","light.strahler","light.wand_hinten_oben","light.wand_hinten_unten","light.wand_vorne_oben","light.wand_vorne_unten"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":460,"y":160,"wires":[[]]},{"id":"d02abd6f60ae311b","type":"api-current-state","z":"8ffb6fb73433cd45","name":"Staubsauger reinigt?","server":"d6e1a14d.333e1","version":3,"outputs":2,"halt_if":"cleaning","halt_if_type":"str","halt_if_compare":"is","entity_id":"vacuum.roborock_s6_maxv","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":500,"y":100,"wires":[["f7fbcafefc8a5068","728a842fbf570ff3"],[]]},{"id":"f7fbcafefc8a5068","type":"api-call-service","z":"8ffb6fb73433cd45","name":"Staubsauger pausieren","server":"d6e1a14d.333e1","version":5,"debugenabled":false,"domain":"vacuum","service":"pause","areaId":[],"deviceId":["57d50b33c303a2bfda65154cc17e0eb9"],"entityId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":790,"y":100,"wires":[[]]},{"id":"5d62c1c29ca1021c","type":"api-current-state","z":"8ffb6fb73433cd45","name":"TV an?","server":"d6e1a14d.333e1","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"media_player.55oled803","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":460,"y":340,"wires":[["f365bb5509fcf145"],[]]},{"id":"befdaf3c7be23361","type":"api-call-service","z":"8ffb6fb73433cd45","name":"Streaming pausieren","server":"d6e1a14d.333e1","version":5,"debugenabled":false,"domain":"media_player","service":"media_pause","areaId":[],"deviceId":[],"entityId":["media_player.apple_tv"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1160,"y":340,"wires":[[]]},{"id":"f365bb5509fcf145","type":"api-current-state","z":"8ffb6fb73433cd45","name":"Magenta TV?","server":"d6e1a14d.333e1","version":3,"outputs":2,"halt_if":"Magenta TV","halt_if_type":"str","halt_if_compare":"is","entity_id":"media_player.apple_tv","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":630,"y":340,"wires":[[],["8ce3a061c315e6c6"]]},{"id":"8ce3a061c315e6c6","type":"api-current-state","z":"8ffb6fb73433cd45","name":"DAZN?","server":"d6e1a14d.333e1","version":3,"outputs":2,"halt_if":"DAZN","halt_if_type":"str","halt_if_compare":"is","entity_id":"media_player.apple_tv","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":800,"y":340,"wires":[[],["de051510a80b4faf"]]},{"id":"de051510a80b4faf","type":"api-current-state","z":"8ffb6fb73433cd45","name":"WOW?","server":"d6e1a14d.333e1","version":3,"outputs":2,"halt_if":"WOW","halt_if_type":"str","halt_if_compare":"is","entity_id":"media_player.apple_tv","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":960,"y":340,"wires":[[],["befdaf3c7be23361"]]},{"id":"5742741fa0384bb8","type":"api-call-service","z":"8ffb6fb73433cd45","name":"Staubsauger starten","server":"d6e1a14d.333e1","version":5,"debugenabled":false,"domain":"vacuum","service":"start","areaId":[],"deviceId":["57d50b33c303a2bfda65154cc17e0eb9"],"entityId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":760,"y":520,"wires":[[]]},{"id":"ca25f828994d71ec","type":"server-state-changed","z":"8ffb6fb73433cd45","name":"Telefon klingelt","server":"d6e1a14d.333e1","version":5,"outputs":2,"exposeAsEntityConfig":"","entityId":"sensor.fritz_box_7590_call_monitor_telefonbuch","entityIdType":"exact","outputInitially":false,"stateType":"str","ifState":"ringing","ifStateType":"str","ifStateOperator":"is","outputOnlyOnStateChange":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":120,"y":220,"wires":[["d02abd6f60ae311b","404b8cee12e547b6","0e5e54916c0de8b7","5d62c1c29ca1021c","a5e934e129ef1165"],[]]},{"id":"6ecadc80b8ec30aa","type":"comment","z":"8ffb6fb73433cd45","name":"Fritzfon","info":"","x":90,"y":100,"wires":[]},{"id":"f0b731888b68a8a9","type":"api-call-service","z":"8ffb6fb73433cd45","name":"Sonos Beam Lautstärke auf 0","server":"d6e1a14d.333e1","version":5,"debugenabled":false,"domain":"media_player","service":"volume_set","areaId":[],"deviceId":[],"entityId":["media_player.sonos_lautsprecher_wohnzimmer"],"data":"{\"volume_level\": \"0\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":790,"y":280,"wires":[[]]},{"id":"a5e934e129ef1165","type":"api-call-service","z":"8ffb6fb73433cd45","name":"Snapshot Sonos Beam","server":"d6e1a14d.333e1","version":5,"debugenabled":false,"domain":"sonos","service":"snapshot","areaId":[],"deviceId":[],"entityId":[],"data":"{\"entity_id\": \"media_player.sonos_lautsprecher_wohnzimmer\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":510,"y":280,"wires":[["f0b731888b68a8a9"]]},{"id":"3cb3c6b3a64297ce","type":"api-call-service","z":"8ffb6fb73433cd45","name":"Sonos Beam restore","server":"d6e1a14d.333e1","version":5,"debugenabled":false,"domain":"sonos","service":"restore","areaId":[],"deviceId":[],"entityId":[],"data":"{\"entity_id\": \"media_player.sonos_lautsprecher_wohnzimmer\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":500,"y":420,"wires":[[]]},{"id":"728a842fbf570ff3","type":"api-call-service","z":"8ffb6fb73433cd45","name":"Staubsauger Hilfe einschalten","server":"d6e1a14d.333e1","version":5,"debugenabled":false,"domain":"switch","service":"turn_on","areaId":[],"deviceId":[],"entityId":["switch.staubsauger_hilfe"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":810,"y":160,"wires":[[]]},{"id":"aba501db0407e4d6","type":"server-state-changed","z":"8ffb6fb73433cd45","name":"Anruf beendet oder nicht angenommen","server":"d6e1a14d.333e1","version":5,"outputs":2,"exposeAsEntityConfig":"","entityId":"sensor.fritz_box_7590_call_monitor_telefonbuch","entityIdType":"exact","outputInitially":false,"stateType":"str","ifState":"idle","ifStateType":"str","ifStateOperator":"is","outputOnlyOnStateChange":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":190,"y":440,"wires":[["5f85971da32edf9e","3cb3c6b3a64297ce"],[]]},{"id":"5f85971da32edf9e","type":"api-current-state","z":"8ffb6fb73433cd45","name":"Staubsauger Hilfe an?","server":"d6e1a14d.333e1","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"switch.staubsauger_hilfe","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":500,"y":480,"wires":[["9aeb12276cc91b0d","5742741fa0384bb8"],[]]},{"id":"9aeb12276cc91b0d","type":"api-call-service","z":"8ffb6fb73433cd45","name":"Staubsauger Hilfe ausschalten","server":"d6e1a14d.333e1","version":5,"debugenabled":false,"domain":"switch","service":"turn_off","areaId":[],"deviceId":[],"entityId":["switch.staubsauger_hilfe"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":790,"y":460,"wires":[[]]},{"id":"5f821e296bdc04c9","type":"server-state-changed","z":"8ffb6fb73433cd45","name":"Anruf tätigen","server":"d6e1a14d.333e1","version":5,"outputs":2,"exposeAsEntityConfig":"","entityId":"sensor.fritz_box_7590_call_monitor_telefonbuch","entityIdType":"exact","outputInitially":false,"stateType":"str","ifState":"dialing","ifStateType":"str","ifStateOperator":"is","outputOnlyOnStateChange":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":110,"y":280,"wires":[["d02abd6f60ae311b","0e5e54916c0de8b7","404b8cee12e547b6","a5e934e129ef1165","5d62c1c29ca1021c"],[]]},{"id":"d6e1a14d.333e1","type":"server","name":"Home Assistant","addon":true}]
