Neues SLZB-OS v3.3.3.dev1 für SMLight Geräte
Changelog: Changelog SLZB-OS | SMLIGHT Manuals
Improvements
  • Experimental support for SLZB-OS configuration backup/restore
  • Optimized the processing speed of SSE messages
  • Added a button to copy the device log
  • Added autocomplete for TIMER module
  • SUN module redesigned documentation
  • OTBR on device moves from experimental to beta
  • U-series coordinators now store 12x larger device log in PSRAM (50KB vs 4KB)
  • (SLZB-Ultima) New “Audio” page and MP3 audio player support!
  • (SLZB-Ultima) Added new Berry audio player module documentation
  • (SLZB-Ultima) Added optional argument for number of repetitions for sending IR command for berry IR module documentation
  • (SLZB-Ultima) Improved stability of Z-Wave addon
  • (SLZB-Ultima) Improved 4G modem processing
  • (SLZB-Ultima) The IR receiver will be disabled while transmitter active
  • Added 10s timeout for OTBR startup. If after that the radio module still does not respond - you will see an error on the OTBR page
Fixes
  • Fixed an OS crash that caused OTBR in some cases
  • Fixed ZigBee network scanning not working if OTBR is running on radio module 2
  • Fixed DNS issues for NAPT bridge mode
  • Fixed SPAM in device log when using SMLIGHT SLZB integration
Zigbee Hub
  • Added experimental ZigBee Hub backup functionality
  • Added missing subscriptions to new zHub control topics. Now new topics will work (attribute read request, system_control)
  • When creating a new random network, only channels 11, 15, 25 will be used
  • Automatic firmware updates of the radio module will be disabled if the Zigbee Hub is active
  • Fixed an issue that caused a ZigBee network start error when the network was actually started
  • Fixed issues with network key comparing
  • Fixed broken Zigbee buttons triggers
Meiner Meinung nach der wichtigste Punkt: “OTBR on device moves from experimental to beta”
Das bedeutet sie verfolgen weiterhin die Funktion, den OTBR auf dem Gerät laufen zu lassen.
Ich selber bin noch auf v3.3.1 und es läuft relativ stabil. Ich hatte zwei größere Ausfälle aller meiner Ikea Gerät, aber das hat sich wieder gefangen. Ich warte aber noch ab, bevor ich auf die neue OS Version update.
Moin
Und dabei würde ich an Deiner Stelle auch bleiben. Zu der Beta/Dev-Version gibt es an anderen Stellen bereits div. Problemmeldungen. :wink:
An welchen “anderen Stellen” denn? :slight_smile:
Z.B.:
Ich habe es aus “Versehen” installiert, hatte nicht auf das “dev.” geachtet. Hat mein sonst sehr stabiles Netz mit 3 Sticks total vermurkst. Bin wieder auf 3.3.1. Auch ich installiere eigentlich keine “dev”, habe da ein wenig gepennt!!!
FYI: Zigbee2MQTT not restoring devices after coordinator migration (ZBDongle-P → SLZB-06p7 over Ethernet) · Koenkk/zigbee2mqtt · Discussion #27423 · GitHub
Wenn ich die dev Versionen installieren, geht keine Device Commission von Thread Geräten mehr. Hab irgendwie noch nicht gefunden wie man Bugs reporten kann.
Über das WebGUI. :wink:
Habe ich selber darüber aber auch noch nicht gemacht. Früher konnte man sich mit den Entwicklern noch direkt austauschen. :laughing:
Ah, sehr gut. Ich setz mal Vector auf um syslog aufzusammeln dann kann ich mal schauen wie man das debugged.
