2025-08-01 13:11:03: New connection from 172.30.32.2:49162 on port 1883.
2025-08-01 13:11:03: Client closed its connection.
Zigbee2MQTT zeigt an:
[13:14:58] INFO: Preparing to start...
[13:14:58] INFO: Socat not enabled
[13:14:59] INFO: Starting Zigbee2MQTT...
Onboarding page is available at http://0.0.0.0:8099/
Zigbee Geräte sollen über den Dongle Sonoff verbunden werden:
Nach Update ging die Verbindung nicht mehr. Andere Foren bringen die Lösung nicht. Wie komme ich auf die Bekannte Seite um die Geräte hinzuzufügen? Muss im Mosquito Broker noch einstellungen getroffen werden?
Set the base configuration to start Zigbee2MQTT.
Optional fields will either be ignored or fallback to defaults if not set (see appropriate documentation page for more details).
If a field is disabled, it means environment variables are being used to override specific values (for example, through the Home Assistant add-on configuration page).
Found Devices
Select a device
Optionally allows to configure coordinator port and type (if known) automatically.
Coordinator/Adapter Port/Path
/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_72fa946805e7ed119562ca770b2af5ab-if00-port0
Coordinator/Adapter Type/Stack/Driver
zstack
Coordinator/Adapter Baudrate
115200
Can be ignored for networked coordinators (TCP).
Coordinator/Adapter Hardware Flow Control ("rtscts: true")
https://www.zigbee2mqtt.io/guide/configuration/adapter-settings.html
Closest WiFi Channel
0
Optionally set to your closest WiFi channel to pick the best value for "Network channel" below.
Network Channel
25
Generate network?
Network Key
248,79,239,40,125,200,231,87,136,182,215,66,31,94,181,248
Network PAN ID
26390
Network Extended PAN ID
171,131,66,11,113,112,70,101
https://www.zigbee2mqtt.io/guide/configuration/zigbee-network.html
MQTT Base Topic
zigbee2mqtt
MQTT Server
mqtt://core-mosquitto:1883
MQTT User
mqttuser
Optional. Set only if using authentication.
MQTT Password
https://www.zigbee2mqtt.io/guide/configuration/mqtt.html
Frontend enabled?
Frontend Port
8099
https://www.zigbee2mqtt.io/guide/configuration/frontend.html
Home Assistant enabled?
https://www.zigbee2mqtt.io/guide/configuration/homeassistant.html
```So sieht es aus. Hatte gelesen das man hier nichts ändert..
Es ist nicht mehr nötig, nach der Installation des Z2M Add-ons, etwas an der Konfiguration, also dem Tab Konfiguration zu ändern, nach der Installation kann man gleich die Onboarding-Seite aufrufen und dort alles einrichten, dieses Onboarding versucht alles so gut wie möglich selbst zu erkennen, es erkennt auch ob es ein Texas Instrument Chip, also zstack, oder ein SiliconLabs Chip, also ember ist, nach dem Save und einem Restart kommt man dann auf die Web-Ui von Z2M.
Das steht auch in der Dokumentation
New connection from ::1:44880 on port 1883. 2025-08-01 15:41:09: Client <unknown> disconnected due to protocol error
Ich wollte einen eigenen Benutzer im Assistant für mqtt erstellen. Als ich das gelöscht hatte, Kommunizierte das Sytsem miteinander und die Onboarding Seite verschwand.
