Home-Assistant-Matter-Hub kann nicht gestartet werden
Ich habe das HA Matter Hub installiert. Leider bringe ich es nicht zum Laufen.
Auch eine Neuinstallation brachte mich nicht weiter.
Kann jemand den Fehler aus dem Protokoll lesen?
Danke euch,
Tommes
Hier das Protokoll:
 Add-on version: 3.0.0-alpha.61
 You are running the latest version of this add-on.
 System: Home Assistant OS 14.1  (amd64 / qemux86-64)
 Home Assistant Core: 2025.1.2
 Home Assistant Supervisor: 2024.12.3
 Please, share the above information when looking for help
 or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service base-addon-log-level: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
[ 2025-01-14T09:52:54.557Z ] [ INFO  ] [ Matter / ServerNodeStore                           ]: Opened *7acd91f4bd5f4b859fae1ed97bb6fd43* storage at /config/data/7acd91f4bd5f4b859fae1ed97bb6fd43
[ 2025-01-14T09:52:54.629Z ] [ INFO  ] [ Matter / Endpoint                                  ]: *7acd91f4bd5f4b859fae1ed97bb6fd43* ready endpoint#: 0 type: RootNode (0x16) behaviors: 💤parts ✓index ✓basicInformation ✓accessControl ✓groupKeyManagement ✓generalCommissioning ✓administratorCommissioning ✓operationalCredentials ✓generalDiagnostics ✓commissioning ✓network 💤productDescription 💤sessions 💤controller ✓descriptor
[ 2025-01-14T09:52:54.635Z ] [ INFO  ] [ Matter / Endpoint                                  ]: *7acd91f4bd5f4b859fae1ed97bb6fd43.aggregator* ready endpoint#: 1 type: Aggregator (0xe) behaviors: 💤parts ✓index ✓descriptor
[ 2025-01-14T09:52:54.847Z ] [ ERROR ] [ apply-patch-state                                  ]: Failed to patch the following properties:
  "operationalStatus": {
    "global": 1,
    "lift": 1
  "installedClosedLimitLift": 10000,
  "currentPositionLift": 12400,
  "currentPositionLiftPercent100ths": 12400,
  "targetPositionLiftPercent100ths": 12400
[ 2025-01-14T09:52:54.848Z ] [ ERROR ] [ apply-patch-state                                  ]: Failed to patch the following properties:
    "global": 1,
    "lift": 1
[ 2025-01-14T09:52:54.849Z ] [ ERROR ] [ apply-patch-state                                  ]: Failed to patch the following properties:
    "global": 1,
    "lift": 1
    "global": 1,
    "lift": 1
    "global": 1,
    "lift": 1
[ 2025-01-14T09:52:54.850Z ] [ ERROR ] [ apply-patch-state                                  ]: Failed to patch the following properties:
    "global": 1,
    "lift": 1
    "global": 1,
    "lift": 1
    "global": 1,
    "lift": 1
[ 2025-01-14T09:52:54.851Z ] [ ERROR ] [ apply-patch-state                                  ]: Failed to patch the following properties:
    "global": 1,
    "lift": 1
    "global": 1,
    "lift": 1
    "global": 1,
    "lift": 1
[ 2025-01-14T09:52:54.852Z ] [ ERROR ] [ apply-patch-state                                  ]: Failed to patch the following properties:
    "global": 1,
    "lift": 1
    "global": 1,
    "lift": 1
    "global": 1,
    "lift": 1
[ 2025-01-14T09:52:54.853Z ] [ ERROR ] [ apply-patch-state                                  ]: Failed to patch the following properties:
    "global": 1,
    "lift": 1
[ 2025-01-14T09:52:54.885Z ] [ ERROR ] [ Matter / Transaction                               ]: Rolling back initialize<7acd91f4bd5f4b859fae1ed97bb6fd43.aggregator.cover_wohnzimmer_tur>#21 due to error: Behaviors have errors
[ 2025-01-14T09:52:54.886Z ] [ ERROR ] [ Matter / Transaction                               ]: Rolling back initialize<7acd91f4bd5f4b859fae1ed97bb6fd43.aggregator.cover_keller_tur>#26 due to error: Behaviors have errors
[ 2025-01-14T09:52:54.888Z ] [ ERROR ] [ Matter / Transaction                               ]: Rolling back initialize<7acd91f4bd5f4b859fae1ed97bb6fd43.aggregator.cover_bad_rolladen>#35 due to error: Behaviors have errors
[ 2025-01-14T09:52:54.890Z ] [ ERROR ] [ Matter / Transaction                               ]: Rolling back initialize<7acd91f4bd5f4b859fae1ed97bb6fd43.aggregator.cover_buro_rolladen_links>#3a due to error: Behaviors have errors
[ 2025-01-14T09:52:54.891Z ] [ ERROR ] [ Matter / Transaction                               ]: Rolling back initialize<7acd91f4bd5f4b859fae1ed97bb6fd43.aggregator.cover_buro_rolladen_rechts>#3f due to error: Behaviors have errors
[ 2025-01-14T09:52:54.891Z ] [ ERROR ] [ Matter / Transaction                               ]: Rolling back initialize<7acd91f4bd5f4b859fae1ed97bb6fd43.aggregator.cover_esszimmer_rolladen_rechts>#44 due to error: Behaviors have errors
[ 2025-01-14T09:52:54.891Z ] [ ERROR ] [ Matter / Transaction                               ]: Rolling back initialize<7acd91f4bd5f4b859fae1ed97bb6fd43.aggregator.cover_esszimmer_rolladen_links>#49 due to error: Behaviors have errors
[ 2025-01-14T09:52:54.892Z ] [ ERROR ] [ Matter / Transaction                               ]: Rolling back initialize<7acd91f4bd5f4b859fae1ed97bb6fd43.aggregator.cover_kellerzimmer_rolladen_rechts>#4e due to error: Behaviors have errors
[ 2025-01-14T09:52:54.893Z ] [ ERROR ] [ Matter / Transaction                               ]: Rolling back initialize<7acd91f4bd5f4b859fae1ed97bb6fd43.aggregator.cover_kellerzimmer_rolladen_links>#53 due to error: Behaviors have errors
[ 2025-01-14T09:52:54.893Z ] [ ERROR ] [ Matter / Transaction                               ]: Rolling back initialize<7acd91f4bd5f4b859fae1ed97bb6fd43.aggregator.cover_kellerzimmer_rolladen_klein>#58 due to error: Behaviors have errors
[ 2025-01-14T09:52:54.893Z ] [ ERROR ] [ Matter / Transaction                               ]: Rolling back initialize<7acd91f4bd5f4b859fae1ed97bb6fd43.aggregator.cover_kuche_rolladen>#5d due to error: Behaviors have errors
[ 2025-01-14T09:52:54.893Z ] [ ERROR ] [ Matter / Transaction                               ]: Rolling back initialize<7acd91f4bd5f4b859fae1ed97bb6fd43.aggregator.cover_wohnzimmer_rolladen_rechts>#76 due to error: Behaviors have errors
[ 2025-01-14T09:52:54.895Z ] [ ERROR ] [ Matter / Transaction                               ]: Rolling back initialize<7acd91f4bd5f4b859fae1ed97bb6fd43.aggregator.cover_wohnzimmer_rolladen_links>#7b due to error: Behaviors have errors
[ 2025-01-14T09:52:54.895Z ] [ ERROR ] [ Matter / Transaction                               ]: Rolling back initialize<7acd91f4bd5f4b859fae1ed97bb6fd43.aggregator.cover_eg_rolladen_alle>#80 due to error: Behaviors have errors
[ 2025-01-14T09:52:54.896Z ] [ ERROR ] [ Matter / Transaction                               ]: Rolling back initialize<7acd91f4bd5f4b859fae1ed97bb6fd43.aggregator.cover_keller_rolladen_alle>#85 due to error: Behaviors have errors
[ 2025-01-14T09:52:54.948Z ] [ INFO  ] [ Matter / Endpoint                                  ]: *7acd91f4bd5f4b859fae1ed97bb6fd43.aggregator.cover_markise* ready endpoint#: 2 type: WindowCovering (0x202) behaviors: ✓identify ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓windowCovering ✓descriptor
[ 2025-01-14T09:52:54.949Z ] [ INFO  ] [ Matter / Endpoint                                  ]: *7acd91f4bd5f4b859fae1ed97bb6fd43.aggregator.cover_anne_rolladen_rechts* ready endpoint#: 5 type: WindowCovering (0x202) behaviors: ✓identify ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓windowCovering ✓descriptor
[ 2025-01-14T09:52:54.949Z ] [ INFO  ] [ Matter / Endpoint                                  ]: *7acd91f4bd5f4b859fae1ed97bb6fd43.aggregator.cover_anne_rolladen_links* ready endpoint#: 6 type: WindowCovering (0x202) behaviors: ✓identify ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓windowCovering ✓descriptor
[ 2025-01-14T09:52:54.949Z ] [ INFO  ] [ Matter / Endpoint                                  ]: *7acd91f4bd5f4b859fae1ed97bb6fd43.aggregator.cover_lena_rolladen_links* ready endpoint#: 16 type: WindowCovering (0x202) behaviors: ✓identify ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓windowCovering ✓descriptor
[ 2025-01-14T09:52:54.950Z ] [ INFO  ] [ Matter / Endpoint                                  ]: *7acd91f4bd5f4b859fae1ed97bb6fd43.aggregator.cover_lena_rolladen_rechts* ready endpoint#: 17 type: WindowCovering (0x202) behaviors: ✓identify ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓windowCovering ✓descriptor
[ 2025-01-14T09:52:54.950Z ] [ INFO  ] [ Matter / Endpoint                                  ]: *7acd91f4bd5f4b859fae1ed97bb6fd43.aggregator.cover_schlafzimmer_rolladen_rechts* ready endpoint#: 18 type: WindowCovering (0x202) behaviors: ✓identify ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓windowCovering ✓descriptor
[ 2025-01-14T09:52:54.952Z ] [ INFO  ] [ Matter / Endpoint                                  ]: *7acd91f4bd5f4b859fae1ed97bb6fd43.aggregator.cover_schlafzimmer_rolladen_links* ready endpoint#: 19 type: WindowCovering (0x202) behaviors: ✓identify ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓windowCovering ✓descriptor
[ 2025-01-14T09:52:54.954Z ] [ INFO  ] [ Matter / Endpoint                                  ]: *7acd91f4bd5f4b859fae1ed97bb6fd43.aggregator.cover_og_rolladen_alle* ready endpoint#: 24 type: WindowCovering (0x202) behaviors: ✓identify ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓windowCovering ✓descriptor
[ 2025-01-14T09:52:54.956Z ] [ ERROR ] [ Bridge / 7acd91f4bd5f4b859fae1ed97bb6fd43          ]: Failed to start bridge due to error: Behaviors have errors
  at file:///usr/local/lib/node_modules/home-assistant-matter-hub/node_modules/@matter/node/dist/esm/endpoint/properties/Behaviors.js:128:21
  at all (file:///usr/local/lib/node_modules/home-assistant-matter-hub/node_modules/@matter/general/dist/esm/util/Construction.js:375:17)
  at file:///usr/local/lib/node_modules/home-assistant-matter-hub/node_modules/@matter/general/dist/esm/util/Construction.js:365:11
  at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
  Cause #0: Error initializing 7acd91f4bd5f4b859fae1ed97bb6fd43.aggregator.cover_wohnzimmer_tur.windowCovering
    at crash (file:///usr/local/lib/node_modules/home-assistant-matter-hub/node_modules/@matter/node/dist/esm/behavior/internal/BehaviorBacking.js:48:13)
  Caused by: Validating 7acd91f4bd5f4b859fae1ed97bb6fd43.aggregator.cover_wohnzimmer_tur.windowCovering.state: Constraint "installedOpenLimitLift to installedClosedLimitLift": Value 12400 is not within bounds defined by constraint (135)
    at file:///usr/local/lib/node_modules/home-assistant-matter-hub/node_modules/@matter/node/dist/esm/behavior/state/validation/constraint.js:35:17
    at file:///usr/local/lib/node_modules/home-assistant-matter-hub/node_modules/@matter/node/dist/esm/behavior/state/validation/ValueValidator.js:155:25
    at file:///usr/local/lib/node_modules/home-assistant-matter-hub/node_modules/@matter/node/dist/esm/behavior/state/validation/ValueValidator.js:84:24
    at file:///usr/local/lib/node_modules/home-assistant-matter-hub/node_modules/@matter/node/dist/esm/behavior/state/validation/conformance.js:15:22
    at file:///usr/local/lib/node_modules/home-assistant-matter-hub/node_modules/@matter/node/dist/esm/behavior/state/managed/values/StructManager.js:135:13
    at Object.change (file:///usr/local/lib/node_modules/home-assistant-matter-hub/node_modules/@matter/node/dist/esm/behavior/state/managed/Datasource.js:172:7)
    at WindowCovering$State.set [as currentPositionLift] (file:///usr/local/lib/node_modules/home-assistant-matter-hub/node_modules/@matter/node/dist/esm/behavior/state/managed/values/StructManager.js:105:32)
    at Function.assign (<anonymous>)
    at applyPatchState (file:///usr/local/lib/node_modules/home-assistant-matter-hub/dist/backend/cli.js:1109:14)
    at WindowCoveringServer.update (file:///usr/local/lib/node_modules/home-assistant-matter-hub/dist/backend/cli.js:2205:5)
[ 2025-01-14T09:52:54.987Z ] [ INFO  ] [ WebApi                                             ]: HTTP server (API & Web App) listening on port 65084
[ 2025-01-14T09:52:54.988Z ] [ ERROR ] [ Matter / Logger                                    ]: Unhandled error detected: Endpoint storage inaccessible because endpoint is not a node and is not owned by another endpoint
  at EndpointStoreFactory.storeForEndpoint (file:///usr/local/lib/node_modules/home-assistant-matter-hub/node_modules/@matter/node/dist/esm/node/storage/EndpointStoreService.js:115:13)
  at numberPersister (file:///usr/local/lib/node_modules/home-assistant-matter-hub/node_modules/@matter/node/dist/esm/node/storage/EndpointStoreService.js:160:28)
      throw new InternalError(
InternalError: Endpoint storage inaccessible because endpoint is not a node and is not owned by another endpoint
Node.js v18.20.4
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service base-addon-log-level: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service base-addon-log-level successfully stopped
s6-rc: info: service base-addon-banner: stopping
s6-rc: info: service base-addon-banner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
lösch mal cover.wohnzimmer_tur aus den Entitäten für die matter bridge
Nur die eine Entität zu löschen hat nichts geholfen.
Nachdem ich alle Entitäten aus der Matter Bridge gelöscht habe startet das Addon.
  1. Woran liegt das?
  2. Kann ich die Entitäten jetzt wieder hinzufügen?
Nimm nicht direkt wieder alle auf einmal rein, sonst weißt du wieder nicht, an welcher/n Entität/en es scheitert.
Ich kann keinen der Rolläden - die in HA über die Overkiz-Integration integriert sind - in den Matter-Hub nehmen.
Andere Geräte, die ich stichprobenartig getestet habe gehen wiederum.
Hat jemand eine Idee woran das liegen kann?
Sobald ich ein Rolladen hinzufüge läuft zwar das Addon, die Bridge jedoch nicht.
Fehlermeldung: “Failed to start bridge due to error: AggregateError: Behaviors have errors
Hier der Log
 Add-on: Home-Assistant-Matter-Hub
 Publish your entities from Home Assistant to any Matter-compatible controller like Alexa, Apple Home or Google Home.
[ 2025-01-14T16:45:11.582Z ] [ INFO  ] [ Matter / ServerNodeStore                           ]: Opened *7acd91f4bd5f4b859fae1ed97bb6fd43* storage at /config/data/7acd91f4bd5f4b859fae1ed97bb6fd43
[ 2025-01-14T16:45:11.585Z ] [ INFO  ] [ Matter / SessionManager                            ]: restoring resumption record for node 1158377846 and peer node 1158377846 for fabric index 1
[ 2025-01-14T16:45:11.586Z ] [ INFO  ] [ Matter / SessionManager                            ]: restoring resumption record for node 501796236 and peer node 501796236 for fabric index 1
[ 2025-01-14T16:45:11.657Z ] [ INFO  ] [ Matter / Endpoint                                  ]: *7acd91f4bd5f4b859fae1ed97bb6fd43* ready endpoint#: 0 type: RootNode (0x16) behaviors: 💤parts ✓index ✓basicInformation ✓accessControl ✓groupKeyManagement ✓generalCommissioning ✓administratorCommissioning ✓operationalCredentials ✓generalDiagnostics ✓commissioning ✓network 💤productDescription 💤sessions 💤controller ✓descriptor
[ 2025-01-14T16:45:11.667Z ] [ INFO  ] [ Matter / Endpoint                                  ]: *7acd91f4bd5f4b859fae1ed97bb6fd43.aggregator* ready endpoint#: 1 type: Aggregator (0xe) behaviors: 💤parts ✓index ✓descriptor
[ 2025-01-14T16:45:11.807Z ] [ ERROR ] [ apply-patch-state                                  ]: Failed to patch the following properties:
    "global": 1,
    "lift": 1
[ 2025-01-14T16:45:11.830Z ] [ ERROR ] [ Matter / Transaction                               ]: Rolling back initialize<7acd91f4bd5f4b859fae1ed97bb6fd43.aggregator.cover_wohnzimmer_rolladen_links>#44 due to error: Behaviors have errors
[ 2025-01-14T16:45:11.847Z ] [ INFO  ] [ Matter / Endpoint                                  ]: *7acd91f4bd5f4b859fae1ed97bb6fd43.aggregator.media_player_esszimmer* ready endpoint#: 3 type: OnOffPlugInUnit (0x10a) behaviors: ✓identify ✓groups ✓onOff ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2025-01-14T16:45:11.847Z ] [ INFO  ] [ Matter / Endpoint                                  ]: *7acd91f4bd5f4b859fae1ed97bb6fd43.aggregator.sensor_temperatur_wohnzimmer_temperature* ready endpoint#: 4 type: TemperatureSensor (0x302) behaviors: ✓temperatureMeasurement ✓identify ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2025-01-14T16:45:11.851Z ] [ INFO  ] [ Matter / Endpoint                                  ]: *7acd91f4bd5f4b859fae1ed97bb6fd43.aggregator.media_player_tv_samsung_led55* ready endpoint#: 5 type: OnOffPlugInUnit (0x10a) behaviors: ✓identify ✓groups ✓onOff ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2025-01-14T16:45:11.851Z ] [ INFO  ] [ Matter / Endpoint                                  ]: *7acd91f4bd5f4b859fae1ed97bb6fd43.aggregator.media_player_spotify_t1* ready endpoint#: 8 type: OnOffPlugInUnit (0x10a) behaviors: ✓identify ✓groups ✓onOff ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2025-01-14T16:45:11.852Z ] [ INFO  ] [ Matter / Endpoint                                  ]: *7acd91f4bd5f4b859fae1ed97bb6fd43.aggregator.media_player_spotify_a* ready endpoint#: 9 type: OnOffPlugInUnit (0x10a) behaviors: ✓identify ✓groups ✓onOff ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2025-01-14T16:45:11.854Z ] [ INFO  ] [ Matter / Endpoint                                  ]: *7acd91f4bd5f4b859fae1ed97bb6fd43.aggregator.media_player_spotify_t* ready endpoint#: 10 type: OnOffPlugInUnit (0x10a) behaviors: ✓identify ✓groups ✓onOff ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2025-01-14T16:45:11.855Z ] [ INFO  ] [ Matter / Endpoint                                  ]: *7acd91f4bd5f4b859fae1ed97bb6fd43.aggregator.media_player_spotify_l* ready endpoint#: 11 type: OnOffPlugInUnit (0x10a) behaviors: ✓identify ✓groups ✓onOff ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓descriptor
[ 2025-01-14T16:45:11.859Z ] [ INFO  ] [ Matter / Endpoint                                  ]: *7acd91f4bd5f4b859fae1ed97bb6fd43.aggregator.cover_markise* ready endpoint#: 6 type: WindowCovering (0x202) behaviors: ✓identify ✓bridgedDeviceBasicInformation ✓homeAssistantEntity ✓windowCovering ✓descriptor
[ 2025-01-14T16:45:11.861Z ] [ ERROR ] [ Bridge / 7acd91f4bd5f4b859fae1ed97bb6fd43          ]: Failed to start bridge due to error: Behaviors have errors
  Cause #0: Error initializing 7acd91f4bd5f4b859fae1ed97bb6fd43.aggregator.cover_wohnzimmer_rolladen_links.windowCovering
  Caused by: Validating 7acd91f4bd5f4b859fae1ed97bb6fd43.aggregator.cover_wohnzimmer_rolladen_links.windowCovering.state: Constraint "installedOpenLimitLift to installedClosedLimitLift": Value 12400 is not within bounds defined by constraint (135)
[ 2025-01-14T16:45:11.876Z ] [ INFO  ] [ WebApi                                             ]: HTTP server (API & Web App) listening on port 65084
Das könnte daran liegen, dass das Addon noch Alpha ist. Du könntest einen Issue auf Github anlegen.
Hallo
Ich bin neu in der HA Welt.
Ich habe das Video wie man eine Matter Hub Bridge erstellt angeschaut und wollte das genau so machen.
Bei mir funktioniert das leider gar nicht. Sowohl Alexa als auch Google home sagen mir, dass keine Matter Hubs gefunden wurden.
Kann mir jemand bei meinen Versuchen helfen?
